IS200t tune
Old Sep 15, 2018 | 11:44 AM
  #3316
Sheddy's Avatar
Sheddy
Originally Posted by mvaldez24
https://youtu.be/fNW5o15zQlw
What do you guys actually think about this run? Feel my car is lacking. Idk why. This is with the BMS Stage 1.
Your boost gauge is reading pretty high with the BMS. Try raising the boost to +5 psi and see if you feel a difference.
Old Sep 15, 2018 | 12:37 PM
  #3317
Sheddy's Avatar
Sheddy
BMS stage 1 with data cable up for grabs. PM me if interested.
Old Sep 15, 2018 | 03:45 PM
  #3318
Flash5's Avatar
Flash5
Send me that data cable! lol jk
Old Sep 16, 2018 | 05:56 PM
  #3319
mvaldez24's Avatar
mvaldez24
I have to download a program to my laptop for that, right? How do I do all of that?
Old Sep 17, 2018 | 01:53 AM
  #3320
Lexus989's Avatar
Lexus989
You need to buy the JB4 Upgrade Kit together with BMS data cable or JB4 Mobile Connect kit to connect to your existing Stage 1 via laptop or mobile.
Old Sep 17, 2018 | 06:12 AM
  #3321
Flash5's Avatar
Flash5
You don’t need the JB4 to change boost levels. Just the data cable and a computer.
Old Sep 17, 2018 | 07:32 AM
  #3322
mvaldez24's Avatar
mvaldez24
Found the thread here with directions on installing the software and wiring directions for both laptop via data cable or smartphone Bluetooth connection via JB4 connect kit.
http://www.n54tech.com/forums/showthread.php?t=35256
Will try to get to this during the week. Gonna be busy packing. Vacay starting Friday!
I'll try Map2 for 5psi @Sheddy and let you know if I feel a difference.
Old Sep 17, 2018 | 09:42 AM
  #3323
Sheddy's Avatar
Sheddy
Once you download the JB4 application on your laptop, connect the data cable and you can adjust the boost settings (Boost safety/Boost failsafe) on the Stage 1 to 5 psi. The Stage 1 only has 1 map, so the boost adjustment has to be done under the user settings tab, Map 2 doesn't exist on the Stage 1.
Old Sep 17, 2018 | 10:09 AM
  #3324
IS200TFOWL's Avatar
IS200TFOWL
Found this ecu company. Even at 15% drivetrain lose they’re still respectable numbers. @dimsport on IG
All of these other ecu tunes look pretty accurate too
Somehow the Rx pulled out more power than this 330i
Old Sep 17, 2018 | 11:23 AM
  #3325
DiverseIS's Avatar
DiverseIS
This is the company RR Racing is supposed to be working with to create a device to tune the IS200t. So obviously they have a tuning solution if they're able to get that much horsepower out of the 2.0. Also, what is"P?" trying to find a way to convert that to horsepower is very hard. Unless that is what they're saying is the horsepower 318. Hopefully they are not hot tuning it to get the numbers and it's actually a reliable tune.
Old Sep 17, 2018 | 11:59 AM
  #3326
Sheddy's Avatar
Sheddy
Hopefully RR Racing can finally release their tune once they are able to get a handheld unit (see below) to work.
Old Sep 17, 2018 | 02:30 PM
  #3327
IS200TFOWL's Avatar
IS200TFOWL
They have the tune ecu flash but not the handleheld. They might be difficult to communicate with maybe it’s possible to get flashing tools from them. Dimecu/dimsport has many different vendor websites but www.kmdimecu.com looks to be the first to post for the 8arfts. The “p” looks like a typo for ps. If you check out their website their other tunes are advertised as ps. Worst case scenario they’re quoting it looks like 266whp
Old Sep 17, 2018 | 03:13 PM
  #3328
DiverseIS's Avatar
DiverseIS
318ps is 313bhp which is 317whp. So 317 is an amazing number if not questionable on a stock turbo.
Old Sep 17, 2018 | 03:20 PM
  #3329
DiverseIS's Avatar
DiverseIS
FYI you can use Google translate to get an idea of what thry are talking about.
kmdimecu.com
Old Sep 17, 2018 | 05:13 PM
  #3330
WhyHateTho's Avatar
WhyHateTho
