IS200t tune
Old Jul 12, 2018 | 09:59 AM
  #3121
TTITony's Avatar
TTITony
Former Sponsor
Hello Everyone,
Due to health complications I've had to put R&D on projects on hold. For now i am trying to get better and will be continuing my work soon. Thank you all for your patience on this matter.
Old Jul 12, 2018 | 10:47 AM
  #3122
tnilc's Avatar
tnilc
I finally got my BMS Stage 1 tune...no time to install it till Saturday tho
Old Jul 12, 2018 | 12:17 PM
  #3123
tnilc's Avatar
tnilc
Originally Posted by Sheddy
Most welcome! Please do share your experience.
I've heard this several times where the user didn't feel a difference until they removed it. I have dyno proven results that it works.
The BMS with a DP works very well!
Thanks for all your input. With your help I've gotten the PPE downpipe (no more CEL for now...I hope) and the BMS Stage 1 tune. Going to install tune Saturday. Also got an Injen Short Ram Intake. I think up next will be a TMD when available, charge pipe and probably the apex'i or Invidia midpipe. I haven't found enough sound clips of the midpipes but I'm leaning Invidia for a more subtle growl.
Old Jul 12, 2018 | 03:39 PM
  #3124
Rob200t's Avatar
Rob200t
did you go highflow cat or cat less?!
Old Jul 12, 2018 | 10:01 PM
  #3125
Nuke's Avatar
Nuke
Originally Posted by TTITony
Hello Everyone,
get well buddy
Old Jul 13, 2018 | 08:55 AM
  #3126
E46CT's Avatar
E46CT
it installs incredibly fast. 1-2 min max. the plugs are right on top can't miss them!
Old Jul 13, 2018 | 04:28 PM
  #3127
Flash5's Avatar
Flash5
I ordered my BMS Stage 1 tuner today; I can't wait. I also ordered the HPS Silicon intake tube and the F Sport filter. I hope I can feel a difference with all this installed (I don't expect anything crazy, just something decent after $600 lol).
Old Jul 13, 2018 | 06:30 PM
  #3128
Sheddy's Avatar
Sheddy
It's the best bang for your buck. You'll enjoy the extra power that the BMS adds.
Old Jul 14, 2018 | 08:23 AM
  #3129
WhyHateTho's Avatar
WhyHateTho
HPS intake tube worth it? Anyone care to share there experiences with it. I have f sport filter and bms stage 1.
Old Jul 14, 2018 | 09:03 AM
  #3130
Nuke's Avatar
Nuke
i don’t suggest, it mess up with MAF calculation and for stage one a drop in filter is much more than enough, and if u wanna be more fancy go for BMS intake
Old Jul 14, 2018 | 09:15 AM
  #3131
Sheddy's Avatar
Sheddy
Doesn't the MAP sensor also send a reading to the ECU on forced induction cars? I've had my HPS for some time and I never had any issues thus far. I've never tested it on the dyno, but HPS did their testing and saw some minor gains throughout the powerband.
Old Jul 14, 2018 | 09:23 AM
  #3132
Nuke's Avatar
Nuke
am talking about the MAF (Mass Air Flow) not MAP, Its responsible for sending the air readings to the ECU, And based on those readings the ECU calibrates the map, which includes throttle that the nation and fe and based on those readings the ECU calibrates the map, which includes l fuel and timing, and in new cars the MAF reading is sent to the TCU to control the amount of pressure applied when shifting.
in small setups like ours its no biggy since we are playing way under the safety line, but once u speak turbo swap and bigger setup forget these useless pipes since its nothing but vitual appeal and possibly slight power loss am sorry to say, but again in our case power loss might be neglectable
Nuke
Old Jul 14, 2018 | 09:24 AM
  #3133
Nuke's Avatar
Nuke
And to further clarify my point MAF sensor is located just after the intake, so when you change the pipe which comes after wards you need to do something called MAF scaling which is a nightmare for most inexperienced tuners
here is a link that elaborate on the same topic
https://www.evolutionm.net/forums/ec...really-do.html
Old Jul 14, 2018 | 10:37 AM
  #3134
Sheddy's Avatar
Sheddy
Got it. I know what the MAF is, I was just under the impression that the real reading is done by the MAP sensor on forced induction cars. Therefore having the HPS tube doesnt affect it as much.
Old Jul 14, 2018 | 10:43 AM
  #3135
Nuke's Avatar
Nuke
nope that theory is not correct, in forced induction cars the MAP sensor helps to compancate the readings and assist the ECU but its not the same as having the correct sacling
