Mark Levinson audio
Old Mar 17, 2025 | 11:35 AM
  #526
355F1's Avatar
355F1
back to the ML audio itself... i've noticed there's a GIANT gap in my perceived 'quality' from the system depending on how old the music is, even it's a high quality recording/stream. i think modern music is mixed for much bigger dynamic range than in the past. so to me, old music sounds pretty poor on ML no matter what.
Yep. My high-rez Sam Cooke albums do not sound nearly as engaging as my high-rez Taylor Swift albums.
Old Mar 17, 2025 | 02:39 PM
  #527
you admit you have those?
Old Mar 17, 2025 | 02:48 PM
  #528
Enzo954's Avatar
Enzo954
That's just the way it is with some older music and the way it was mixed for some reason. Old school Hip Hop always sounds less clear and plays at a lower volume. Method Man tracks sound like that and one of worst offenders I've ever run into is Digable Planets "Rebirth of Slick". Classic amazing track but sounds like ****. 80's Hip Hop is even worse.
Old Mar 17, 2025 | 02:57 PM
  #529
fodalo's Avatar
fodalo
you are correct Bitka. todays technology, studio equipment recording equipment is so superior than the old day technology. So the result in the recordings are so much crisper, cleaner than the 50's-90's.its like tv high def 1080p vs. 4K, so much cleaner to the eye is the viewing today vs. years ago.
Old Mar 17, 2025 | 04:21 PM
  #530
Timado404's Avatar
Timado404
Veteran: Marine Corps
^^^ you must play seriously loud.
I stretch the legs of the ML system from time to time. Qobuz high-res tracks from the likes of Usher, Notorious B.I.G., Lauryn Hill, Outkast, The Chronic album, Nelly Furtado, or some TLC turned up to about 54, 55 usually gets the job done. 👍🏾
Old Mar 18, 2025 | 08:05 AM
  #531
ragabnh's Avatar
ragabnh
whaa??? is this a coupe or convertible? and did you replace missing seat with anything?
Coupe, good riddance, no one wants to sit there anyway.
Update: removing back window did not do it for me, now I am thinking dropping the transmission
Old Mar 18, 2025 | 12:39 PM
  #532
TTBomB's Avatar
TTBomB
Did you make a rear seat delete kit or anything? photos?
Old Mar 18, 2025 | 09:39 PM
  #533
355F1's Avatar
355F1
We flew to London almost last-minute to see her concert in July.
Old Mar 18, 2025 | 09:40 PM
  #534
355F1's Avatar
355F1
Most of 2Pac’s albums suck for dynamics too—even on Tidal Hi-Rez.
Old Mar 26, 2025 | 07:42 PM
  #535
akshunj's Avatar
akshunj
I was searching this thread for the instructions that user ASONG1 had posted on how to improve the ML sound system. Somebody with an LC wanted to know what I did to make mine sound better. After searching I realized that he deleted every post on Club Lexus for some reason. Knowing how I am, I figured that I mostly likely snapped a pic of my PC screen with my cell phone so I could quickly look at the instructions in my car while make the suggested adjustments. Bingo...found the pic! Figured I'd post it here in case it can help someone else tweak their system because it worked well for me.
Thanks for posting this. I was really concerned there was some weird digital processing going on in my 25 convertible I wouldn't be able to work around. It seemed to me the bass would just cut out between 40-50 mph at any volume over 40 or so. I tried disabling surround and auto sound leveling to no avail. At first I was convinced that front door speakers might be wired out of phase. That's how strange it sounded.
Old Mar 27, 2025 | 05:21 PM
  #536
akshunj's Avatar
akshunj
So I checked out the guidance from the screenshot. It's a little better, but I think the stereo is cutting back on the bass as speed increases. I'm not sure what's going on, but the bass pales in comparison to the ML system that was in my GSF.
Old Mar 27, 2025 | 06:01 PM
  #537
Enzo954's Avatar
Enzo954
There's definitely something wrong because the bass in mine really booms.
Old Mar 28, 2025 | 02:07 AM
  #538
akshunj's Avatar
akshunj
Coupe or Convertible?
Old Mar 28, 2025 | 05:03 AM
  #539
akshunj's Avatar
akshunj
I just went for a ride early this morning. I tried top up/down, cruising at 40/50/60 mph. Two things for sure;
1. I just need to get used to this system doesn't hit as hard as the ML did in my GSF.
2. Turning off the surround sound definitely helps.
Old Mar 28, 2025 | 11:31 AM
  #540
2959's Avatar
2959
For me, turning off the Surround Sound was the biggest improvement. I've also adjusted Treble/Bass almost to max. Another thing I've found, is with the top down and windows up (yea, anathema for some) it makes a big difference in the acoustics.
https://www.dsf.my/2022/01/here-is-w...s-superlative/
https://newsroom.lexus.eu/cabin-calm...c-convertible/
