3IS long term ownership concerns
Old Feb 20, 2019 | 08:16 AM
  #61
NickCaesar's Avatar
NickCaesar
Originally Posted by EZZ
If I get anything over 18 mpg, I'm driving the car wrong
i cant get better than 18mpg in the city. Every possible maintenance is up to date, tried ecu resets etc...
highway I can get 23.5 mpg but city driving mileage is horrible. Worse than my old RX350 that weighed like 600 pounds more.
Old Feb 28, 2019 | 01:35 PM
  #62
waterdd's Avatar
waterdd
Originally Posted by Tungstn-IS
The LCA bushings aren't up to the task from the get go. My '06 started eating tires early on. I did an alignment, no luck. Replaced them with new OEM bushings and another alignment, no luck. I swapped to FIGS bushings and all the terrible tire wear ceased. On my next IS I just did that on about the 3rd day of ownership and never had any issues. The 3IS has the same bushings and suspension design, it is just matter of when, not if it will happen as far as I'm concerned
Is that a DIY type of thing? 😁
Old Feb 28, 2019 | 02:07 PM
  #63
SSworks's Avatar
SSworks
Quick question, How long before you start noticing this "eating tires" issue?
I have done 13,000 miles in 7 months with no sign of abnormal wear and I don't exactly drive like grandpa.
Old Feb 28, 2019 | 02:47 PM
  #64
Flash5's Avatar
Flash5
You definitely should have seen it by now. You’ve checked the inside part of your tire recently?
Old Feb 28, 2019 | 03:05 PM
  #65
SSworks's Avatar
SSworks
Weekly along with fluid levels and a once over to make sure everything is ok.
Old Feb 28, 2019 | 05:50 PM
  #66
WhyHateTho's Avatar
WhyHateTho
No long term concerns on my end.
Old Feb 28, 2019 | 07:23 PM
  #67
Flash5's Avatar
Flash5
That's surprising. My stock summer tires were showing signs of inner tire wear (not a lot) by 8,000 miles which is when I bought my Michelin A/S 3+ for the winter. I have the GS-F/RC-F LCA bushings installed though so I'm curious to see how my Michelin's look when I reinstall the summer tires in about 2 months.
Old Feb 28, 2019 | 07:59 PM
  #68
LaZeR's Avatar
LaZeR
Unhappy
This is a Depressing thread Is Lexus Quality getting worse??
Old Feb 28, 2019 | 08:04 PM
  #69
Burrcold's Avatar
Burrcold
Nope just more people online talking about stuff. Lexus is doing juuuusst fine.
Old Feb 28, 2019 | 08:11 PM
  #70
LaZeR's Avatar
LaZeR
... My stock summer tires were showing signs of inner tire wear ...
Mine also, to the point the front tires started shredding!!
Me too so rotated the rear tires and they highly recommended a 4-wheel alignment - costs $180. Did you get an alignment?
Old Mar 1, 2019 | 01:44 AM
  #71
Flash5's Avatar
Flash5
Mine also, to the point the front tires started shredding!! Me too so rotated the rear tires and they highly recommended a 4-wheel alignment - costs $180. Did you get an alignment?
Alignment won’t help in this case. You need stiffer lower control arm bushings. That’s why I got the RCF/GSF bushings and installed them.
Old Mar 1, 2019 | 05:42 AM
  #72
SSworks's Avatar
SSworks
So the big girl is getting up in age she is at 67K and going in tomorrow for her big 60K service, What bushings do you recommend to resolve this issue before it even starts.
Just a note I had an oil change, filter and plugs changed at 65K so the ppl that will jump on me for not servicing at 60k can rest well at nights now.
Old Mar 1, 2019 | 05:47 AM
  #73
truu's Avatar
truu
You could add Paint chips forward of rear wheel to the list. TSB is referenced in thread.
Old Mar 1, 2019 | 12:11 PM
  #74
Flash5's Avatar
Flash5
Figs or RR Racing poly bushings are popular but much stiffer than stock so you’ll feel a little more vibration etc. The GSF/RCF bushings are an option too. More oem and less stiff, people seem to be getting good results with these (I haven’t put enough miles on mine to see the efffects yet).
Old Mar 1, 2019 | 12:35 PM
  #75
SSworks's Avatar
SSworks
BRIDGESTONE POTENZA RE760 SPORT
