3IS long term ownership concerns
Old Mar 5, 2019 | 09:03 AM
  #106
AtomicAWD's Avatar
AtomicAWD
Originally Posted by JNP1227
Check out this thread: https://www.clublexus.com/forums/sus...bushing-4.html
I believe RR Racing explained mechanics of it there.
Thanks, but I've read many threads on it. Was just a simple yes/no question as to the meaning of the term.
Old Mar 5, 2019 | 09:18 AM
  #107
arentz07's Avatar
arentz07
TL;DR - The car toes OUT during braking and cornering, which causes the inner tire wear.
Old Mar 5, 2019 | 09:31 AM
  #108
AtomicAWD's Avatar
AtomicAWD
There we go, thanks!
Old Mar 5, 2019 | 09:44 AM
  #109
arentz07's Avatar
arentz07
To elaborate on this a bit...
My dealership service department decided to get creative with my car (with my consent obviously) and change the alignment slightly to mitigate inner tire wear. They essentially gave me a slight adjustment toe-in. I think it's too early in my tires to tell if that's working. I checked the inner wear recently but it still seemed uniform. Only about 6 months and 5000 miles on the tires so far. (Sorry I didn't take a picture but sue me )
Old Mar 5, 2019 | 01:50 PM
  #110
E46CT's Avatar
E46CT
The only mitigation there is is to zero out the front toe. It will help during static driving. But dynamic change will still take place at the same rate/degree. It's just your static wear (driving normally down the street) will be mitigated as most factory alignments on sport/luxury cars call for toe-in. Usually a tenth of a degree.
Old Mar 13, 2019 | 04:55 PM
  #111
pngo's Avatar
pngo
Originally Posted by Sasnuke
I know the bulletin mentions replacing the hose with the updated part as well, so I would think the hose is critical to the overall fix.
And I would agree that it's possible the updated part has failed. It has happened a few times that Toyota/Lexus has a bulletin with an updated part to fix an issue, and the new part fails in the same way...or creates a new problem.
It doesn't happen often thankfully, but it does happen.
At least the engineers now know what didn't work, and usually get it right the second time.
I just had my regulator valve and hose R&R'd after a "factory tech" test drove my car and experienced the surging.
They replaced the regulator with the same part number (25819-0W010) and the hose with part number (25760-36051). I am not sure if the hose is a revised part, but they referenced the bulletin released in September 2017.
Old Sep 5, 2019 | 09:19 AM
  #112
E46CT's Avatar
E46CT
That's the thing w/ entering into the big boy german turbo arena. and entering into more tech/goodies in general. you have to pay to play. mo parts, mo tech, mo problems
Y'all want them fancy competition so your car can do good in motor trend mags and instagram posts showing off cool car features, well there is a cost. lol
There was something nice about simpler cars in simpler times. something very charming about driving an old car. i miss my 1987 E30 3 series manual with 247,000 trouble free miles when i sold it. fully mechanical and everything presents itself for you in the engine bay.
Old Sep 5, 2019 | 09:26 AM
  #113
WhyHateTho's Avatar
WhyHateTho
No one mentioned motor trend, Instagram and showing off features.
Old Sep 5, 2019 | 09:29 AM
  #114
EZZ's Avatar
EZZ
Thats the reason Performance EVs will dominate this segment in the future. Relative to a turbo BMW, the Model 3 Performance is dirt cheap to run. No scheduled maintenance, electricity is dirt cheap, brakes usually last past 100k miles, super reliable drivetrain (batteries last 300k miles), and its stupid fast for $50k range (you'll completely annihilate the current M3...i know ). The tires will go at 20k miles like any other performance car though.
Old Sep 5, 2019 | 12:10 PM
  #115
AtomicAWD's Avatar
AtomicAWD
Y'all want them fancy competition so your car can do good in motor trend mags and instagram posts showing off cool car features, well there is a cost. lol.
Wrong. The problem with your "big boys" at Audi, BMW, Mercedes, Volkswagen, etc. is not simply that they put in more tech, but that they implement it poorly with parts that don't last and systems that break down. Argue whether or not Lexus is "behind" in technology, but they have not near the problems. Why? Because they don't use cheap plastic, over-engineered tolerances, and over-implemented processing on every conceivable system.
I had a 2004 Z4 and it was generally reliable. My mechanic said that was about it for German cars, because since then they have put in so much tech and used cheaper and cheaper parts that you're only asking for trouble if you buy one. Yet somehow companies like Toyota and Honda are able to do so and maintain quality AND longevity. Why? Because they don't use cheap quality parts, put in unnecessary tech "just cuz they can", and actually put their systems through thorough long-term testing.
Old Sep 6, 2019 | 08:21 AM
  #116
E46CT's Avatar
E46CT
I added F Sport gauge cluster to the list
Old Sep 6, 2019 | 08:34 AM
  #117
EZZ's Avatar
EZZ
There is literally only one that broke. Perspective please.
Old Sep 6, 2019 | 08:43 AM
  #118
arentz07's Avatar
arentz07
Probably still valuable to document how much it costs to fix/where to get parts if it does break. I'd say it's valid info, but it would be good to state that it's a rare issue.
Old Sep 6, 2019 | 08:53 AM
  #119
E46CT's Avatar
E46CT
patience, grasshoppa. patience.
even when the car was new, all the automotive journalists commented.. cool feature but this is certainly going to break in a few years. didn't exactly take a psychic. a ribbon cable can only flex so many times.
relax, I drive a Lexus too. no need to get tribal. cars are just things that inevitably break. nice to have a data point on the things that do break
Old Sep 6, 2019 | 09:48 AM
  #120
EZZ's Avatar
EZZ
I just don't think it will ever be an issue because nobody moved it after their first week of ownership. In the 5 years i had my car, i've maybe moved it 20-30 times and most of that was in the first month of ownership
