3IS long term ownership concerns
Old Mar 4, 2019 | 10:12 AM
  #91
E46CT's Avatar
E46CT
Originally Posted by JNP1227
I just replaced my front. I got 32,000 miles out of them (mainly highway and the occasionally spirited driving) rears are still good. I didn't notice the inner tire wear till around 25k or so.
Not bad. Mine started showing at 15k.
I corner and brake very aggressively though. I put the IS to work. So I make the suspension squiggle and wiggle under high turning and braking loads (many times simultaneously) which can cause the wear. It's worth it due to how fun it is.
If you're a gentle cruiser, you could go long.
Old Mar 4, 2019 | 10:55 AM
  #92
JNP1227's Avatar
JNP1227
I take exit ramps pretty fast and acceleration pretty hard as well but again I am more highway than stop and go traffic. When I get together with my Lexus group then its aggressive driving (hitting redline at 7200 and taking hard corners ) my BF Goodrich tires held up pretty well.
Old Mar 4, 2019 | 12:12 PM
  #93
E46CT's Avatar
E46CT
Are you on summer tires or all seasons? Cause the summer tires here in socal heat put a lot more stress on stuff. especially with stock F sport pads which are professional high friction german compound
i also wear front pads at around 11-12k
Old Mar 4, 2019 | 12:23 PM
  #94
JNP1227's Avatar
JNP1227
All seasons on stock F sport rims
Old Mar 5, 2019 | 01:50 AM
  #95
LaZeR's Avatar
LaZeR
Question
For those analyzing their 3IS tire wear, make sure you turn the wheel at full lock and closely inspect the inside of the tire. I've found there's a fine line between OK and HOLY S this has to be replaced that can sneak up on you fast. The very inner and very outer should be close. Look for signs of a "stripe" appearing on the very inner edge. Usually occurs around 10-15k, and maybe 20k if you drive very conservatively.
I had the exact same problem.
Say FOR EXAMPLE that you just got a (almost perfect) 4 wheel alignment, OR, your wheels are pretty much (almost perfectly) aligned, then this issue is mitigated correct?
Old Mar 5, 2019 | 04:59 AM
  #96
Flash5's Avatar
Flash5
No, you need stiffer LCA Bushings to mitigate the dynamic toe from braking and cornering. Otherwise, you pretty much will keep getting inner tire wear.
Old Mar 5, 2019 | 05:47 AM
  #97
ShrinkDoc's Avatar
ShrinkDoc
Flash, can you talk a little more about this? My tires are at around 7K, but expect to eventually show this wear.
Old Mar 5, 2019 | 06:17 AM
  #98
Sasnuke's Avatar
Sasnuke
@ShrinkDoc I think everything you're looking for is here: https://www.clublexus.com/forums/sus...led-today.html
Old Mar 5, 2019 | 06:32 AM
  #99
AtomicAWD's Avatar
AtomicAWD
To be clear, "dynamic toe" refers to the front suspension "pigeon-toeing" inwards and outwards under certain conditions, or just one direction? All or primarily due to looseness in the LCA bushings?
Old Mar 5, 2019 | 07:18 AM
  #100
JNP1227's Avatar
JNP1227
Its due the softness of the bushing. Lexus designed the LCA bushings with comfort in mind.
Old Mar 5, 2019 | 07:41 AM
  #101
ShrinkDoc's Avatar
ShrinkDoc
Are there specific bushings that are recommended for our car?
Old Mar 5, 2019 | 08:02 AM
  #102
Sasnuke's Avatar
Sasnuke
Lexus will only recommend the exact bushings that are in there.
The RCF/GSF are a direct replacement for the IS ones.
Old Mar 5, 2019 | 08:20 AM
  #103
Flash5's Avatar
Flash5
Or you can go Poly like RR Racing or Figs but those are extremely stiff and require lubing here and there. You’ll also increase noise, vibration, and harshness. These however will completely rectify the inner tire wear. I went with the RCF/GSF they seem like a good in between.
Old Mar 5, 2019 | 08:49 AM
  #104
AtomicAWD's Avatar
AtomicAWD
Yes, but was asking more about the actual mechanics of the toe -- in, out, or both.
Old Mar 5, 2019 | 08:59 AM
  #105
JNP1227's Avatar
JNP1227
Check out this thread: https://www.clublexus.com/forums/sus...bushing-4.html
I believe RR Racing explained mechanics of it there.
