Just install this Android Stereo and need help
Old Feb 21, 2019 | 01:20 PM
  #181
bamCL's Avatar
bamCL
5th Gear
Default anyone try this model? 268$
Following this thread with interest, I'm at work and just found this...sorry if it's a dupe post. But this is super cheap. The only negative I can see so far is the 1GB of RAM...has anyone tested this model?
https://www.aliexpress.com/item/Chog...918133747.html
Currently US $268.80
Old Feb 21, 2019 | 01:52 PM
  #182
linkzx's Avatar
linkzx
It looks like the same model just the lower end spec version using the Allwinner T3 instead of the T8
"There are 3 different non-compatible versions of T3 hardware and software, Default one (sleep mode added later and not so good), New one (firmware is a development of R16 branch), and K2001 (usually very compact and cheaper). Allwinner T8 head units continue and develop the same firmware branch - V9.x.x on T8, V8.x.x on T3 New (V8.3.x with Android 7.1) and V7.x.x on R16. Most tips and tricks from T3 (new one) will work on T8." -XDA Developers
It might be worth looking into which version it is, asking the seller might get you the info
Old Feb 21, 2019 | 03:03 PM
  #183
metaleckz's Avatar
metaleckz
android 7.0 lol
Old Feb 22, 2019 | 05:58 AM
  #184
ianbis's Avatar
ianbis
Default A fool & his money are soon parted
So topnavi001 told me that the $35 cost of the USA CanBus was for current customers and $70 for non customers. So I asked what would it cost to purchase an Android Unit with USA CanBus and an additional USA CanBus and they tell me the cost of the Android unit ($456) plus shipping plus $80 for the additional USA CanBus unit plus $20 shipping. So If I become a customer the additional USA CanBus is now $100 😤🤬🤯
Old Feb 22, 2019 | 03:05 PM
  #185
linkzx's Avatar
linkzx
Originally Posted by zcollier
Yes, that's also what I found. Only the left channel, sent to all speakers. Very disappointing!
Does anyone have an idea of what's causing this or how to fix it? I'll be asking my vendor soon.
Just confirmed that mine does too, really sad. have you heard from the vendor?
Old Feb 24, 2019 | 07:11 PM
  #186
grevierx's Avatar
grevierx
Just received my unit from topnavi. I really want to test it out at home with an external 12v power supply before I install it in my car, does anyone know which pins to connect +12v in? Based on the wiring label sticker on the unit, is it pin 1? and ground pin 6? anyone know what "power cathode" means?
Thanks!
Old Feb 24, 2019 | 09:07 PM
  #187
DennisMik's Avatar
DennisMik
Old vacuum tube terminology... Anode = positive, cathode = negative.
Old Feb 24, 2019 | 09:20 PM
  #188
grevierx's Avatar
grevierx
So I connect pin 1 acc with 12 volts and pin 5 "power cathode"? Or do I use the ground?
Old Feb 24, 2019 | 11:26 PM
  #189
xxmariolxx's Avatar
xxmariolxx
This is why I stay far away from these POS Chinese units. Have a audio shop do a custom install not one of these POS horrible sounding units. There for people who don't listen to music
Old Feb 25, 2019 | 10:30 AM
  #190
DennisMik's Avatar
DennisMik
In the case of automobile usage, the "power cathode" is the 12 volt negative connection or ground.
Old Feb 25, 2019 | 10:46 AM
  #191
BabyGate's Avatar
BabyGate
You need to connect #1 and #5 to +12V, then #6 to negative.
Old Feb 25, 2019 | 10:49 AM
  #192
grevierx's Avatar
grevierx
Thanks DennisMik. If "power cathode" is negative (yellow wire may be indicative of constant 12v too...) any idea what pin 6 ground is used for? Does that me I can use either pin 5 (power cathode) or pin 6 (ground) to power the device?
Old Feb 25, 2019 | 10:53 AM
  #193
grevierx's Avatar
grevierx
Thanks for clearing that up BabyGate!
Old Feb 25, 2019 | 10:58 AM
  #194
BabyGate's Avatar
BabyGate
Damn, that's crazy.
Old Feb 25, 2019 | 11:00 AM
  #195
grevierx's Avatar
grevierx
BabyGate, will that power on the the button lights as well? any idea what the voltage for the panel light pin 11 signal is? I want to turn on the LEDs lights bc I just changed all the leds to white and want to test the unit before I install it in my car
