Asking for YOUR help...
Old Jan 20, 2009 | 04:30 PM
ttayavibul's Avatar
ttayavibul
Default Asking for YOUR help...
Hey CL members,
I just recently bought a 3GS and I've pretty much been on this site for weeks just researching and looking at all the impressive mods everyone has done. I told myself I would stop fixing up cars, but I just cant resist.
Im lookin at lowering my car and pretty much slamming it so that I have no finger gap and im wondering if the following set up will work:
Work Varianza T1s
20x9 +35 with 235/30/20
20x10 +45 with 275/30/20
This setup originally came from a 3GS then bought by a 3IS member who is now selling the wheels(the reason for smaller tire sizing).
Does anyone have this set up or know someone who has this set up? I pretty much wanna slam the car, have no gaps, and have NO RUBBING issues at all (without modifying my fenders).
Ive been going back and forth with Rominl (who really know his stuff when it comes to offset), but hes not 100% sure about this set up either. He says there MAY be an issue with the rears rubbing. I just want to make sure before I dump the money.
Thanks in advance for helpin.
Old Jan 20, 2009 | 05:10 PM
Stormforge's Avatar
Stormforge
executive matchup
welcome to CL. try this wheel calculator below:
http://www.wheelsmaster.com/rt_specs.jsp
input your GS wheel specs on the left, and the aftermarket wheel/tire combo on the right. see the comments below. that should give you a "guideline" as to whether or not the wheel/tire combo you have in mind will fit or not. if in doubt, always go with the safe wheel/tire size. good luck
Old Jan 20, 2009 | 05:39 PM
thomastan's Avatar
thomastan
slam to the ground...how are you going drive?
Old Jan 20, 2009 | 05:51 PM
ttayavibul's Avatar
ttayavibul
Thanks, seems like the fronts are going to be fine, but the rears are questionable like Rominl had stated.
"Package is 20 mm (0.8'') closer to suspension/brakes components. Make sure that you have enough room for that. If not, consider lower offset, narrower tires or using spacers.
Fenders Package will stick out 10 mm (0.4'') farther. Acceptable for most cars.
Wheelwells Will fill out the wheelwell by extra 11 mm. Acceptable for most cars."
Not sure if this is going to be problem.
Old Jan 20, 2009 | 05:55 PM
ttayavibul's Avatar
ttayavibul
very very very carefully....haha
Old Jan 20, 2009 | 05:59 PM
rominl's Avatar
rominl
exclusive matchup
being careful and experience
Old Jan 20, 2009 | 06:02 PM
thomastan's Avatar
thomastan
well good luck and enjoy if you can make it possible to your specs...
Old Jan 20, 2009 | 07:34 PM
vietdeluxx's Avatar
vietdeluxx
My rears are at: 20” x10" offset +40mm 255/30/20 and no rubbing issues. Hope this helps
Old Jan 20, 2009 | 08:09 PM
ttayavibul's Avatar
ttayavibul
Can you fit five in your car and still no rubbing?
If this is the case, it seems like i can just mess with tire specs to have no rubbing.
Old Jan 20, 2009 | 08:58 PM
vietdeluxx's Avatar
vietdeluxx
The most I've had was 4... (sorry not enough friends). haha.. No rubbing issues with 4. I have Teins CS and it is on the lowest setting.
Old Jan 20, 2009 | 09:01 PM
ttayavibul's Avatar
ttayavibul
hahaha....Any fender work or all stock?
Old Jan 20, 2009 | 09:43 PM
vietdeluxx's Avatar
vietdeluxx
No fender work...
Old Jan 20, 2009 | 09:47 PM
ILOVEGIRLS's Avatar
ILOVEGIRLS
his tire width is 255.... so it might not work in your case.
Old Jan 20, 2009 | 10:13 PM
maying856's Avatar
maying856
Depending on how "slammed" you want to be you may have to do some fender work, or sacrifice wheel size. But since you say you dont want to have any finger gaps thats not really slammed anyways. A slammed car to me would be having the wheels tucked behind the fender and taking about 5min to get out of a driveway. If you really want that "slammed" look then I highly suggest bags, and if you live in SoCal then it will also save you a tremendous amounts of headache since their roads are some of the worst. But if you just lower it to a zero gap then you shouldnt have any problems with rubbing your tires.
truenoboy
Aug 29, 2016 08:51 PM
gwagon63
IS F (2008-2014)
Mar 7, 2013 02:02 PM
02msmg3
Jul 23, 2012 06:08 PM
octechgeek
Wheels, Tires & Brakes Forum
Dec 3, 2010 04:22 PM
t.is350.h
Nov 22, 2006 08:45 AM
