Florida Lexus Club The place for Florida Lexus enthusiasts
Tech support post your question here...
Old Jan 16, 2011 | 04:03 PM
  #316
SH_JZZ30's Avatar
SH_JZZ30
What size and offset wheel?
Old Jan 16, 2011 | 07:34 PM
  #317
blk&blu*j's Avatar
blk&blu*j
Originally Posted by Punky
Need some tire/ wheel advice. I have 255 35 19s on the rear of my car and with the offset its just fitting by the grace of god. I came across a really good deal on some 265 30 19 tires. Can anyone give me their opinion if it will fit or not?
Call John LRD//
Old Jan 19, 2011 | 11:20 AM
  #318
YeA 2jZ's Avatar
YeA 2jZ
Punky I got 10" wide rears on 265/30/19 and i had cut (you could roll) my rears........
question to Rodger and or MR. Jordantune here is the math.
GE block & Trans + 2J GTE head + small single = what ecu ???
Old Jan 19, 2011 | 04:05 PM
  #319
RawkusX187's Avatar
RawkusX187
I believe you can keep your GE ecu, it's auto right?
Old Jan 19, 2011 | 07:00 PM
  #320
blk&blu*j's Avatar
blk&blu*j
GE ECU but you definetly need some way to tune it, and will you be using the GTE harness??? as there are some issues like COP vs distributor, Cam sensors on head with no plugs on ge harness etc,etc you definately will need to do some more research but it is acheivable
Old Jan 20, 2011 | 04:27 AM
  #321
RawkusX187's Avatar
RawkusX187
^^^ exactly what I had in mind...
Old Jan 20, 2011 | 07:53 AM
  #322
YeA 2jZ's Avatar
YeA 2jZ
Anoyone know where i can get a good deal on Supra TT rotors local without needing to order them?
Old Jan 27, 2011 | 12:41 PM
  #323
keskipper's Avatar
keskipper
Tech question...
Just got an alignment from a local shop. I have a 93 SC400. I noticed towards the tail end of the process that he had the computer set up for an LS400 - he mentioned the caster (I think) had a spec of like 9.33 (or something) and he thought that was incorrect as mine was at 3.25. That's when I told him (because that's when I noticed it) he had it set for an LS not an SC. He plugged in SC and it showed the specs were 2.75 with a .75 range, but did not change anything else, just said it looked fine. Everything did look fine, but it was set to LS. Should he have set it back up and tested again? Are the tolerances really that close between the LS and SC that it wouldn't matter or should I take it back and ask him to redo it?
Thanks...
Old Jan 27, 2011 | 01:33 PM
  #324
SH_JZZ30's Avatar
SH_JZZ30
Quick question
Does anyone here use valvoline VR1 racing oil in their cars? It's a conventional oil but from what I've been reading, our cars (1jz/2jz) don't need synthetic. I saw it at advance auto in 50w and 20w-50.
Old Jan 27, 2011 | 02:25 PM
  #325
Devor's Avatar
Devor
QQ
My car wont pass smog Ive swapped the plugs wires distributor cap n rotor. It still didnt pass could the EGR valve be the cause of this dilema? on my results sheet it said the o2 sensors and cats were ok so I'm kinda stuck right now on what to do next to hit the street =/
Old Jan 27, 2011 | 07:04 PM
  #326
RawkusX187's Avatar
RawkusX187
Originally Posted by SH_JZZ30
Quick question
I had similar talks with Anthony about this but lighter weight would be best for turbo lubrication wouldnt it?
Old Jan 27, 2011 | 07:05 PM
  #327
RawkusX187's Avatar
RawkusX187
Originally Posted by Devor
QQ
Where are you located?
Old Jan 27, 2011 | 07:56 PM
  #328
Anthony85's Avatar
Anthony85
To xavier I'm definitely making the switch to synthetic next oil change. I'm going with what I know best from dealing with the germans so much. Mobil 1 but in 15w50 or 10w40 viscosity. I use mobil 1 5w30 in my vw and it is great....
Old Jan 28, 2011 | 02:18 AM
  #329
frogboy's Avatar
frogboy
I just recently purchased some wheels for my car. They are work euroline dh 18x9.5 -1et all the way around square setup. I drive a 98 gs400 lowered on tein flex coils. My question is "Is it going to be hard to make these wheels fit?" Ive looked at many pics of the gs models with aggressive offset wheels but I havent seen any tutorials of what they had to do to make them fit.
Old Jan 28, 2011 | 03:53 AM
  #330
lexforlife's Avatar
lexforlife
Quick question
shameed
vr1 racing oil is good stuff but its racing oil designed to be changed after each race like they do in the pits at the track... alot of people dont realize the diff between things applicable to racing may not be the best for the street in terms of whats in it for daily driving ...
10w40 would be ideal for its not to thick to prevent oil from getting to the wrist pins and up thru the head during cold start but yet wont turn to water under heat breakdown.. i use mobil 1 15w50 from day one for i found it to be the best compromise between enough viscosity and the ability for it to reach the wrist pins and prevent that start up famous rattle but does not break down quickly from the heat but still thin enough to not be a problem for bearing clearances and create a drag on the crank
10w30 5w30 way to thin and breaks down quickly hence why some people exp spun bearings , no real lubing on the bearings and crank
bottom line check your oil often and if you know your going to run hard change the oil beforehand
