Build Threads Details on Club Lexus IS-F owner vehicles
JT2MA71's 2014 UW build
Old Jan 23, 2021 | 02:21 PM
  #121
JT2MA71's Avatar
JT2MA71
Test fitting the headers!
Old Jan 23, 2021 | 03:50 PM
  #122
Jwconeil's Avatar
Jwconeil
Do you have some form of a lift?
Old Jan 23, 2021 | 03:56 PM
  #123
Patton6964's Avatar
Patton6964
Dear God this is an awesome build thread. You've done more mods to your car in the first 3 months of owning it than I have in the last 3 years to mine. Loving the progress and mod selection!
Want to sell me your old gauge cluster????!!!!???
Old Jan 23, 2021 | 04:37 PM
  #124
JT2MA71's Avatar
JT2MA71
Yes, I have Quickjacks 7000slx.
Old Jan 23, 2021 | 04:39 PM
  #125
JT2MA71's Avatar
JT2MA71
thanks! I should be done with all the mods by Summer this year, I’m hoping!
I only replaced the lense,
Old Jan 23, 2021 | 04:42 PM
  #126
IMAGINTHAT's Avatar
IMAGINTHAT
Love the attention to detail - this build is incredible.
Curious where you find the time to do all the work? Any tips or advice ?
While I draw inspiration from this thread I am wiped out at the end of the day and weekends are
pretty much playing catch up for me. Either way, well done sir !
Old Jan 23, 2021 | 05:14 PM
  #127
Joe Z's Avatar
Joe Z
Question
What's holding the engine ???
Are the bottom collectors slip fit or welded on your version?
Joe Z
Old Jan 23, 2021 | 05:53 PM
  #128
JT2MA71's Avatar
JT2MA71
I don’t have a very tiring job so I have some motivation and energy when I get home
Joe Z
I put rubber blocks in between the stabilizer bar and the front cover/oil pan. And when I’m not working under the car, I put a block of wood just in front of the lower pan and support it with a floor jack.
The collectors are slip fit.
Old Jan 23, 2021 | 08:45 PM
  #129
Joe Z's Avatar
Joe Z
Lightbulb
Good stuff...!! The dealership uses these special SST tool / brackets for underside support via the engine mounts while on the lift..
Circa March 2016 when I had both OEM manifolds replaced under extended warranty.
Joe Z
Old Jan 23, 2021 | 10:09 PM
  #130
lobuxracer's Avatar
lobuxracer
Tech Resource
Did you get to see how the held the engine up to install the SSTs?
I'm not about to buy the SSTs for the top or the bottom, but I can see how they'd be pretty helpful if you are a Lexus tech.
Old Jan 23, 2021 | 11:13 PM
  #131
Joe Z's Avatar
Joe Z
Lightbulb
I wasn't there that day, but maybe one at a time while lowering subframe?? Along with the trans stand..
Makes jobs that require subframe removal way easier.
Heres what I found online:
https://www.vehicleservicepros.com/d...pport-no-10700
Joe Z
Old Jan 23, 2021 | 11:17 PM
  #132
Joe Z's Avatar
Joe Z
(Novel Headers)
I never understood how they don't leak???
I get that it makes the installation much easier, but how do they seal 100% at the collectors..
Joe Z
Old Jan 24, 2021 | 04:22 AM
  #133
JT2MA71's Avatar
JT2MA71
They’d still have to temporarily support the engine via the pan with those long support stands to install the sst’s. I thought about fabbing something like those but the rubber blocks work just fine, I remove the engine mounts and brackets to remove and install the exhaust manifolds/headers anyway.
Old Jan 24, 2021 | 04:28 AM
  #134
JT2MA71's Avatar
JT2MA71
Joe Z
Maybe it’s just how they perfectly fit together. No leaks on my RC-F so far
I used double slip connectors from Burnsstainless when I used to make inline 6 headers and those are leak free. These are just single slip,
Old Jan 24, 2021 | 08:29 AM
  #135
Joe Z's Avatar
Joe Z
Lightbulb
Thanks for the breakdown...
Headers are on my bucket list if these OEM manifolds fail again... Or I should say when they do..
For cost and quality, I always seems to eye PPE.
Do you plan on any CATS on the mid pipe for smell control ??? Or will the Icode come with them already ??
I applaud your DIY garage installs.. Wish I had the time & tools..!!
Joe Z
