Build Threads Details on Club Lexus IS-F owner vehicles
JT2MA71's 2014 UW build
Old Dec 6, 2020 | 05:02 PM
  #91
JT2MA71's Avatar
JT2MA71
Diff is back on. I’ll have to call DSS tomorrow to verify if this gap between the u-joint and adapter is OK/normal. This is with the driveshaft fully extended. I can tighten the bolts and the gap will close, but im
not sure what I’m pulling on at that point. The diff is also as far forward as possible already, there’s a small adjustment. Once I loosen the u-joint bolts, the gap opens up again by what’s shown in the picture (about 3/16”)
Old Dec 7, 2020 | 08:44 PM
  #92
JT2MA71's Avatar
JT2MA71
Made this thing years ago. It has served its purpose many times!
Old Dec 7, 2020 | 10:19 PM
  #93
Joe Z's Avatar
Joe Z
^^^ Neat tool..!! I know at the dealership they just gun them down..
What did they say in the driveshaft fitment?
Joe Z
Old Dec 7, 2020 | 10:35 PM
  #94
lobuxracer's Avatar
lobuxracer
Tech Resource
I need to make a tool like that for crank dampers. Love the Snap-On torque wrench. I have one just like it...
Old Dec 8, 2020 | 12:24 AM
  #95
ultimase's Avatar
ultimase
That is gorgeous.
I made one not too long ago with just some flat metal, drill three holes, and make a Y shape with a bolt at the pivot point, and one at each end of the Y. Cheap and very effective at the crank pulley/damper.
Old Dec 8, 2020 | 05:21 AM
  #96
JT2MA71's Avatar
JT2MA71
Joe Z
I was told to take a measurement between the face of the shaft end to the face of the CV joint once everything is buttoned up, spec is 3.25"-3.75". I got 3.875", so, I'm definitely pre loading the CV. I'll have to call them again today to give them that information. Bryson, the guy I've been dealing with there, has been very helpful so far, we'll see what he has to say.
I have the SST one for Toyota dampers from my days with 5M, 7M, and 2J engines. Love my Snap-On torque wrenches, especially the angle feature.
Originally Posted by ultimase
That is gorgeous.
Thanks, yeah, that works too.
Old Dec 10, 2020 | 06:26 AM
  #97
JT2MA71's Avatar
JT2MA71
After the front UCA bushings, there’s no rubber bushing left to replace!
Old Dec 10, 2020 | 07:44 AM
  #98
steeven001's Avatar
steeven001
Awesome build man!
When you reassemble the rear before installing the shock assembly do you think you could move the suspension up and down to see if and where the poly joints bind?
Old Dec 10, 2020 | 08:43 AM
  #99
Rossi's Avatar
Rossi
Great job for sure, wondering what kind of effect all this will have on ride quality. Back in the day a swapped bunch of my bushings to poly from Energy suspension on my Eclipse, the ride quality became unbearable.
SuperPro are supposed to be the best in this regard, but really looking forward to your feedback.
Old Dec 10, 2020 | 05:21 PM
  #100
Joe Z's Avatar
Joe Z
Lightbulb
Any plan for the UCA ball joints??? I replaced mine many years ago with the SPC and it's been set to ZERO ever since.. Hope to dial it in on next tire and wheel alignment
Joe Z
Old Dec 11, 2020 | 05:29 AM
  #101
JT2MA71's Avatar
JT2MA71
Originally Posted by steeven001
Awesome build man!
Thanks! None of them bind, I made sure I used plenty of their grease during assembly. How long before they need re-greasing? I hope a long time..
Thanks. I sure hope the ride quality will not be unbearable, I've prepared myself for some increase in NVH, but we'll see!
Joe Z
No plans to replace them unless they go bad. I actually want to run a little negative camber so I even got the offset inner bushings, and set them to max negative (-1 degree)
Old Dec 12, 2020 | 01:36 PM
  #102
JT2MA71's Avatar
JT2MA71
A little bit of titanium.
Old Dec 12, 2020 | 02:16 PM
  #103
Joe Z's Avatar
Joe Z
Nice would have been fun to see what a cup full weight comparison on OE vs Ti
Joe Z
Old Dec 12, 2020 | 04:54 PM
  #104
JT2MA71's Avatar
JT2MA71
Joe Z
I did some comparisons when I did the RC-F. Titanium is half the weight of the same size steel fastener.
Old Dec 13, 2020 | 11:46 AM
  #105
steeven001's Avatar
steeven001
I thought swift made springs that fit the 2012+ shocks properly? The oem 2012+ springs are flat on the bottom right?
