Build Threads Details on Club Lexus IS-F owner vehicles
JT2MA71's 2014 UW build
Old Mar 21, 2021 | 06:09 PM
  #211
JT2MA71's Avatar
JT2MA71
All buttoned back up!
Also, started the car and let it warm up and went through the process of setting the ATF level. I filled the transmission up with 6 qts after changing the strainer and the pan. Removed the level check plug as soon as the atf temp. showed 96F, nothing came out. Let it warm up some more to max. required, still nothing. Added 2 more quarts and went through the process again this morning, still nothing. Added 2 more qts. so that is already a total of 10 qts. Went to through the process again and finally, about 1 qt. came out.
Old Mar 22, 2021 | 06:46 PM
  #212
lobuxracer's Avatar
lobuxracer
Tech Resource
That's beyond weird. The entire system dry only holds 11.1 quarts according to the Service Manual on TIS. I'd really like to know how you got the torque converter emptied out. That's a feat.
Old Mar 22, 2021 | 07:28 PM
  #213
Jwconeil's Avatar
Jwconeil
How do you like the Swift springs on the 14 shocks? I took them off my 13. They didn’t absorb well to me.
Old Mar 24, 2021 | 11:36 AM
  #214
JT2MA71's Avatar
JT2MA71
feels pretty good on mine. But, I had just replaced my road and track ohlins on my RCF and I am having the rears converted to fit the IS-F. So, the swift springs are
coming off after that.
Old Mar 25, 2021 | 05:52 AM
  #215
JT2MA71's Avatar
JT2MA71
Fresh off of my RC-F, they’re going on the IS-F just need some upper and lower spring perches!
Old Mar 25, 2021 | 09:43 AM
  #216
JT2MA71's Avatar
JT2MA71
Old Mar 25, 2021 | 10:26 PM
  #217
KenISF's Avatar
KenISF
A diffuser would complete the exterior nicely.
Old Mar 26, 2021 | 05:18 AM
  #218
JT2MA71's Avatar
JT2MA71
I agree! That's why I have one on order from Alpheyga.
Old Mar 26, 2021 | 06:46 AM
  #219
Jwconeil's Avatar
Jwconeil
Did you go with the CCS rep? They have had a more aggressive diffuser under development for a while. I haven’t been following social media lately, so I don’t know if they ever finished it. It looked promising.
Old Mar 26, 2021 | 01:57 PM
  #220
JT2MA71's Avatar
JT2MA71
Oh I didn't know they're working on another version. Yeah, I ordered whatever they have in current production, if that's the CCS rep.
Old Mar 28, 2021 | 07:08 AM
  #221
breed's Avatar
breed
JT2MA71
I was wondering if you would mind sharing were you got your undercarriage hardware? Pretty please 🥺
Thank you so much by the way your build is amazing!
Old Mar 30, 2021 | 09:58 AM
  #222
JT2MA71's Avatar
JT2MA71
Originally Posted by breed
JT2MA71
Hi. Thank you! The aluminum screws are from Proboltusa.
Old Mar 30, 2021 | 10:45 AM
  #223
Lend0's Avatar
Lend0
What suspension will be going on the RCF?
Old Mar 31, 2021 | 11:46 AM
  #224
JT2MA71's Avatar
JT2MA71
ohlins TTX
Old Mar 31, 2021 | 01:27 PM
  #225
Jwconeil's Avatar
Jwconeil
You don’t play. Do you track the RCF?
