View Full Version : SC400 / 300 Classifieds
- CA WTB R154 1jzgte transmission.
- TX F/S - Brand New Nakamichi Factory Amp!!
- FL 11 brand new led lights in white including fogs, 26.00 shipped!
- NC WTB: Lower oil pan
- FL help help ac line needed
- WA wtb: I NEED COILOVERS!!!
- NY wtb 97+ sc rightside taillight
- FL WTB: 1 Passenger Side 95-96 tail light
- IA WTB: 1UZ intake manifold
- CO 1jz 2jz Stock Map Sensor
- IL rear tailights from 99 sc great condition
- IL 1999 sc 300 Black perforated Leather seats
- CAN-Toronto Fs Mines Ecu 600
- NY FS sc300 95 head and tail lights
- CA origin fenders/98+dwp wing trade for stock fenders and 97+ front grill
- RI wtb 97+ vertex front lip or vertex style bumper
- NY 95 SC400 Trans - 85 K miles
- LA right door lock actuator
- MD Master window switch (Tan)
- CA WTB: Rear speaker panel assembly
- MI Parts I'm looking for.
- CA WTB: shock/spring combo for sc300
- IL Almost new RPS Clutch and some auto parts.
- NJ WTB: Tan Driver Seat
- CA Garage Cleaning. 97+ Rear Bumper + Skirts and more !
- CO 1995 5spd SC300 ECU + MAF
- AZ 5-Speed Open Diff
- CO JDM 6spd 2JZGTE ECU
- CO LS400 throttle body (non-Trac)
- CA FS: (1) Passenger Side 97+ Fog Light
- MD V160 snap performance driveshaft
- WA sc300 fenders (pair)
- IL Lexus Center caps
- NC Lots of SC400 some universal stuff for sale.
- CA FS: Stock SC Front Lip
- FL oem lexus95+ ls400 pads 70% life left 25.00 shipped
- CA sc300 transmission, driveshaft, tt struts/springs, powerslot rotors
- PA sc400 1uzfe header back exhaust
- FL Set of 4 drilled & slotted rotors with calipers & pads 75.00 for all of it!!!!
- NY FS: Butterfly cupholder
- NY FS: White Wingless Trunk
- NY PART OUT 98 Lexus SC400....TONS of parts....low low mileage
- MO pair of headlights.. 150 shipped!
- OR 93 SC steering wheel and airbag good condition
- FL FS: Complete SC TSX retro package
- LA WTB full black interior
- CA WTB: ARISTO 2JZ to SC300 PNP HARNESS..
- TX OEM Toyota v160/v161 Flywheel;
- CA FS 2jzgte water pump with rear housing
- LA WTB: Front Right, Lower Control Arm
- OR ES 300 yellow foglight projector lenses
- CA WTT: Intrax Lowering Springs (Supra tt)
- WA Borg Warner turbo And Ex manifold Combo Deal
- NY WTB: Rear Supra TT Calipers
- FL WTB these 1uzfe minor parts, Pic inside
- HI WTB: Serpentine Belt Tensioner Assembly
- WA Complete Set of Injectors: Sc400 1uzfe
- CA HAWK HPS (FRONT) AND BLEEDING climate ctrl
- LA FS: 2JZ-GE Longblock, Polished TT Upper Intake, TT TB
- FL Wtb:Full 2J Na swap
- CA Wtb: Black hood bay area
- LA WTB: 95 SC300 AC Compressor
- NE Operation: Clean out my garage
- CA 97+ Rear Bumper w/ extensions for sale!
- TN FS: TRD leather shift knob
- CA FS: Clean dpw Trunk w/ 97+ spoiler
- NM FS: Door Handle
- FL Wtb inner door handle lhs
- FL WTB pass door speaker grille
- MD FS: 1jz T4 turbo manifold cheap
- FL a few sc300/ na mk4 (2jzge) parts...
- MO 97+ taillights with harness $160 shipped!!
- CA Couple tan interior parts
- WA Drivers side interior handle
- CAN-Toronto Fiberglass Hood/sunroof visor
- NY wtb sc300 clutch pedal
- FL WTB Stance gr+ coilovers
- CO 1999 SC300 Emergency Brake cover
- MD sc300 cross drilled/slotted front rotors
- FL Hks (fcd)
- CA WTT: 98+ dpw trunk w/ oem spoiler
- FL 1997 sc400 front calipers w/axis pads 60.00
- FL Full set of cross drilled & slotted rotors 75.00
- GA WTB: 97-00 climate control
- International F/S 96 LS400 Front Summitomo 4 Piston Aluminum Calipers
- PA WTB: TT Supra Fan clutch
- TX SC300,SC400,Supra NA rear axles
- TX Tein coilover adjusting wrenches
- TX Supra TT Eibachs; Extremely low mileage. Nearly new.
- TX W58 Flywheel OEM Toyota; Less than 1000 miles
- TX RPS Max Series Clutch W58. Supra NA and SC300; Less than 1000 miles
- CA FS: Supra TT big brakes
- OH WTB 1jz/2jz coil packs/MAP sensor
- CA precision injectors 850 cc top fee so cal
- FL F.S hks evc iv
- FL F.S 1jzgte engine
- CA FS Wingless Trunk
- IL FS: New TT Oil Pump, NEW TT Valve Cover and other new rebuild parts plus others.
- FL Apexi , greddy , hks !!!!!!!
- MD mk4 resistor pack
- NY FS: Black Seatbelts
- NY FS: 97+ Grill
- NY FS: 96 Lexus SC400 Partout
- NY FS: Driver 97 Tail and Set of 95-96 Tails
- CT 2jz bellhousing w58 trans, clutch, flywheel and driveshaft for sale
- FL FS: Camry Throttle Cable for 1jz and 2jz swaps
- OR Factory SC license plate bracket
- NY Spare NA-T parts cheap
- NY wtb: tan sc300 interior minus front seats
- NY FS: Phenix Target Knock off bumper
- CA WTB: 97+ Front Bumper A.S.A.P
- CA Authentic VERTEX Front Lip - Renaissance Red -
- CA WTB: VIS V-LINE CF hood
- CA FS: TRD B.A. Red Front Sway Bar + MKIV Rear sway
- CA FS: TRD Twin Disc Clutch for 1JZ/2JZ R154
- NC WTB: sc coilovers
- MA WTB R154 rebuild kit
- CA WTB: Tan Butterfly Cup Holder
- IL FS: 2JZGE engine
- WV wtb: front bumper marker lights
- NY WTB Trunk LID
- IL Supra Non Turbo cloth front seats black-gray
- GA WTB: Passanger side window regulator
- NY 98 sc300 cluster, low mileage
- FL New front& rear Hawk hps pads mkiv tt 145.00 shipped!!
- NY FS: 94 SC400 Coolant Reservoir
- CA SC300 Repair Manual 1&2
- CA FS: Supra Passenger Side LCA and Pass JDM Sidemarker
- FL intercooler
- FL Wtd: a couple things
- FL WTB: manual shifter bezel w/boot
- VA WTB: Front sway bar links
- NY FS: LS400 Calipers
- AL 1992-1994 Climate Control
- AL Complete Set of OEM Stock Springs
- CA 1JZGTE Soarer Auto ECU-$60
- CA Used TT coil packs-$120 FIRM
- TX Q45 90mm TB and 97-01 rear bumper, extensions and sideskirts
- MI WTB-Driver Side Door Panel & Passenger Side Window Trim
- VA FS: Chrome Door Pillars // 2JZ MT ECU
- NY WTB: Driver Door Panels
- MD fs: jdm 2jz 440cc injectors x6
- DC Bnib trd sway bar kit with bushing and brackets
- CA WTB: Eibach Pro Kit for my SC300
- FL WTB Driver inner door handle
- GA WTB:RHD Soarer Front Windshield
- CAN-Vancouver WTB: Coilovers
- FL wtb sc300 shroud n 97 grille
- FL Brand new oem sc400 motor mounts 140.00!
- OR 1jz/2jz turbo drain oil pan fitting
- CA FS: Daizen Sway Bar and 97 A/C Control
- CA WTB: lowering springs
- NH Wtb ls400 calipers
- AL Driver side floormat
- MI WTB center console trim-tan
- VA WTT/WTB: 95(F) BUMPER + WISE LIP for 97+ BUMPER
- DC Fs trd strut bar bnib
- WV wtb: w58
- FL Wtb: Driverside headlight
- IL Aristo swap great condition, new oil, and water pumps
- IL F.S. Tanabe Sustec Springs w/ KY-GR2 Struts New Mounts
- KS FS: JIC MAGIC REPLICA FULL FRONT BUMPER-unmounted/unpainted
- NY WTB - gauge cluster needles dead or alive
- CA Garage Clean Out: MISC Parts FS
- CA WTB: parts for gte swap into sc300
- OK WTB: W58 Complete swap
- MA 99 sc300 ECU, Ignitor, Coils
- IL FS: 2JZGE T70 Turbo Kit with 50mm wastegate and midpipe
- IL Fs: Mkiii r154
- MA Tan butterfly cupholder
- CA FS: rear tan panels and A pillars
- MD fs: 1jzgte stock twins
- CA Quantum Auto W58 kit & Vlamos Bushes
- TX 1jz going single sale
- CAN-Toronto wtb: aftermarket steering wheel hub
- CA WTB: body kit
- NC FS: OEM 2JZ Harmonic Balancer
- FL New Precision Billet Wheel 6765 Turbo
- CAN-Toronto wtb: used coilovers for sc
- NC WTB - Pre 95 1uzfe
- NY VPC with 2jz plug n play harness
- NY WTB nakamichi amplifier
- OK OEM 2JZGE parts & Misc MKIV items..
- MA F/S A/T trans's
- MA F/S 3.92 rear differential
- VA WTB Bucket Seat rail/bracket
- NY FS: 94 SC400 Engine and Trans
- FL WTB working antenna for a 1997 sc400
- TX Wtb mkIII r154 speed sensor
- AL Black Dash/AirBag, 97 Fog, Personal Whee/hub, Window Switches, Turbo Kit Na-t
- TX Cleaning Garage Out
- MO Wanted TPS for 92 sc400
- MA Supra tt springs needed!!!!!!
- FL WTB dirt cheap/blown sc400 auto trans in fl
- TX GTE Auto ECU ODB1
- FL 1jz parts
- IL 99 wing
- FL 1jz-gte Stock Twin Turbos in Good Condition CT12A
- TX FS: sc 2jz hard pipes
- WI WTB: Driver side window regulator
- NY FS: 97 Fogs and Grill
- TX FS: Greddy style intake manifold + Q45
- WI WTB: Crank Pulley/ Harmonic dampner
- FL WTB interior window/door trim piece in black!
- OR W58 and stuff, Stage 1 clutch, and Sc300 seats for sale.
- GA WTT - 25mm spacer for 20mm spacer
- VA 95 Car/Tan Int Partout
- IL FS: FFIM INTAKE / 80 MM TB / 880CC Injectors and Fuel Rail Stock
- FL WTB: Auto tranny FL area
- OK Twin Turbo Coil Packs, HKS DLI and Igniter For Sale
- FL project 95 sc300 w/1jz r154
- TX Custom Red & Clear Tail Lights
- UT **F/S**(2) Nitto Extreme Drag Tires 275/40/17
- IL Tan MKIV Leather Supra seats 200
- CA FS: stance super angle kit
- CA Tan back seat bottom and passenger seat
- GA Well blow my HG damn! looking to buy a 1jzget or 2jzget asap.
- CAN-Toronto Nakamichi amp
- CA WTB: Stock sc400 headers.
- GA wtb automatic shifter
- CA MKIV parts: oem TT airbox, NA fan, oem cat, RHD dash piece, HKS boost gauge & more...
- FL Wtb 1uzfe/sc400 valvacovers in central fl
- MN WTB:Spoiler Brake light for my 97sc300
- CA wtb: heater control valve sc300
- FL FS: Prothane Front LCA bushings
- TN Tanabe NF210 springs
- NJ sc300 oem clutch master cylinder
- CA WTB : TPS and Distributor connector housings
- CA FS: head seats pair
- CA FS:Tan front seatbelts with bars
- FL FS: SC300/400 Radio Bezel
- NY FS: 2jzge vvti harness, ecu, misc........
- UT Greddy BCC & SLC, fan + clutch, TT head gasket + misc seals
- NC USDM 550s and resistor pack
- FL FS: New RPS sprung 6 puck disk/Dual Walbros/Fuelab filter sock/5" chromed intake tube
- IL 2JZ-GE, FFIM, Turbo Manifold, Precision Turbo, Koyo Radiator, MK3 440s, Custom Intake
- CA WTB: Airbag Sub Harness 09082-00760
- NV tan steering wheel 25$
- MD Brand new tt front/rear caliper rotors
- NY WTB: 95-96 tails with harness
- WA WTB big ish turbo.
- FL Wtb dildo-matic shift knob in black!
- NY Fs: Misc black parts
- TN WTB: 95+ AC hose
- CA free tan rear seat back part with rips (local pick up only)
- AL Misc. items for sale
- IL FS: Dashboard and trim beige - SC300
- IL FS: Power steering and ABS modules
