View Full Version : SC400 / 300 Classifieds
- CA 93 sc400 parts for sale
- IA WTB- Interior pieces
- CA WTT: black rear speaker deck w/o 3rd brake light for one with 3rd brake light
- WA 92 5 Speed M/T SC300 ECU
- CA FS: supra mkiv lowering spring/shock combo
- NY FS: Poly Diff Bushings - 10 sets on hand
- CA FS: DM CT26 SINGLE turbo kit 400.00
- FL WTB: Pioneer Subwoofer Amplifier
- CAN-Vancouver FT: BLACK 92-96 trunk for 97+ (and possibly a FREE 97+ spoiler!!)
- GA WTB. Clutch Master Cylinder and line
- CA Tan Master Window/Door Lock Switch -$50
- HI Wtb: 2jzge at na ecu & maf
- CA Sc400 stock parts
- OR FS: Fuel pump, fuel ECU, 550cc Injectors
- NY FS: 92-00 SC300/400 DOOR PANEL LH or RH black or tan..we got them ALL
- CA Supra 6 speed rear end subframe and pumpkin , sway bar mounts,Greddy MBC, TT Igniter
- FL ZO6 6piston BBK setup for SC/GS/IS/Supra
- FL 200 mile old outer tie rod ends w/geease zerks,traction rods,rear toe arms 95 shipped
- CA fs: jic magic coilovers and brand new steering rack bushings
- CO WTB: sc300 auto shifter
- CA FS: GE 264 Cams, rebuilt LS400 BBK, -8/-6 fuel system, Dual pumps w/ hanger, Blk Inte
- AR WTB: late model w58 tripod piece with linkages and shifter
- NY FS: 95-96 Tails
- NY FS: Homelink Visors - Black/Grey and Tan
- CA 1JZ single turbo parts Holset, T4 manifold, HKS wastegate, Apexi EBC and more
- FL FS: Stock SC,1JZ,R154 Parts...2J T4 Manifold, SAFC2, 3"D/P for Twins, HKS FCD
- FL WTB stock caliper rotors and pads for sc300
- GA Turbo XS dual Stage Boost Controller, Black HKS EVC V, Tial Wastegate Precision Turbo
- CA So Cal : WTB Sunroof for 2000 SC400
- WA WTB A/C Condenser for 92 sc300
- KS WTB W58 Tripod Short Shifter
- KY F.S. Stock auto trans
- NY WTB 92-96 non-vvti SC300 Engine harness & MAF
- OH wtb passenger side driving light for 95 SC
- CA SC300/400 LED turn signal covers
- CO Glass High Beams GREAT Glass Lenses
- VA FS: DC/MD/VA - 97-00 Rear Spoiler w/ LED (Black)
- FL SC400 drive shaft yoke 40.00 shipped!
- FL WTB 1JZ spark plug cover
- OK WTB: SC clutch and brake pedal set
- CA FS: SC300 stock parts
- NJ Wtb: oem fuel filter
- CAN-Toronto WTB: R154 front shaft/bellhousing
- AL FS: Boost gauge with everything to install
- Hi
- GA WTB: Drive Side Regulator, Etc.
- CA Wtb: Black/tan cup holder butterfly
- FL Parts f/s
- NC WTB Marlin Crawler R154 Parts, Drive Shaft
- UT FOR SALE//97 LS400 Calipers
- CA Wtb rear bumper lip Sc3/400 . 5x114 spacers
- GU 1JZ and 2JZ Parts.....etc..
- FL FS : supra tt brakes and rotors ( front )
- Looking for a VVTi auto ECU from a 2JZGTE
- CA 93 5spd ECU - 93 5spd Engine Harness - Garage Clean Up
- FL steering problems
- CA HKS FCD (fuel cut eliminator) - This was used on my 1j and 2j set ups
- NC WTB Transmission Crossmember
- MD FS: 1j Left Over Parts
- NV WTB: Name brand wastegate (4bolt preferred)
- MD Gummy Bears and sushi D:
- WTB - 1JZ Intake side Valve Cover
- TX WTB driver side seat back cover
- TX 2jzge flywheel clutch and pressure plate.
- CA Socal - Powered Black Suede Toyota Supra Seats $450
- CA WTB:JZ Rear sump lower oil pan
- FL FS: Titan Sway Bars w/ new Supra endlinks and Mounts for SC's
- NY FS: 97+ SC Front and Rear Bumpers
- CA FS: some stock stuff
- OR 1997 front bumper and headlights for pick up only
- OR Fs: Dr tweak harness/1jz swap parts/interior part out
- TX ORC single plate clutch (r154)
- TX New Gates Belt K060763RB, New OEM Oil Pump, 6spd Driveshaft, New Poly Diff Bushings
- MA Corbeau TRS with sliders and brackets
- CA sc300 front seats - black
- CA WTB-drewgo t4 2jzgte manifold
- CA wtb 97 on up factory rear wing. Azusa Ca
- CA Wtb:3" mid pipe
- NY wtb 97+ door moldings
- TX Wtb black driver seat back cover.
- CA I need a few parts...you got em (WTB)
- TX 2JZ-GE Complete Engine with automatic transmission, W58 Short shifter Houston
- wtb: 92 sc300 AT ECU
- CA WTB: 97+ vertex lip
- MD Fs: 2jzge m/t ecu
- CA WTB: SC300/400 cluster part.
- NY Testing waters want to trade my Espelir Springs
- CA WTB Tanabe NF210 Springs for SC300 shocks
- CA Fs sc400 lip
- NC WANTED - Pass. Side Window Motor Assembly
- OR Turbosmart electronic boost controller
- OR Fs: 1jzgte aem
- AZ Stock R154 Clutch (Disc Only)
- CA WTB black door panels and black window switches
- CA FS: Nakamichi radio, amp and CD Changer + other goodies
- CO COMPLETE AC Heat Under Dash Climate Controll Unit
- CO Toyota Factory Dealer Option Roof Spoiler
- FL FS: 2 Soarer Trans (one rebuilt with MC parts), Spec Twin Disc, Flywheel, GTE Plenum
- CO SC300 Vented under Tray and Radiator Cover Plastic
- FL BBK Calipers for sale!!!
- NY WTB: GTE Valve Cover,spark plug cover and Ge T6 manifold
- CA FS: megan racing lowering springs Supra/Sc3-400
- WTB: Air flow meter
- OR climate control unit
- OH WTB Nakamichi amp And rear deck speakers
- CA Clear Headlights and High beams
- OR FS: Complete 5spd pedal set
- NJ Wwanted: oem side markers
- OK wtb: Coilovers
- IL FS: Boost Logic custom built 3" exhaust for SC300
- NC Wtb: 2jzge or 1jzgte
- NV WTB: Exhaust hangers, Rad crossmember etc
- NY Few Leftover Aristo, r154 and usdm parts and blitz turbo timer
- CA WTB- 1996 sc300 auto tranmission or/and 96 manual ecu
- OH 5 speed pedels
- OR Sc300 starter and Sc300 rubber shifter boot
- AL WTB: Right Hand drive OEM black SC Carpet and NEW Cluster
- TX 2JZGTE Forced induction mini sale
- AL WTB: AEM Digital Boost Gauge
- FL New Viper 5501 remote start 120.00 shipped!!!
- AL FS: Black OEM console arm rest lid
- NJ Wtb: 1993 auto ecu
- CA WTB:Front Lower Control Arms
- FL WTB :2jzgte engine
- NJ Selling:Supra TT springs
- TX WTB Bad or damage Sc300 ECU
- AL FS: Seatbelts with hardware
- CAN-Toronto FS: door handles, window motor, jdm folding mirrors, pedal, left overs....
- NY Wtb soarer parts
- FL f/s intrax full coilover set avail
- LA WTB: Welded Diff
- NY Lexus sc400/sc300 black interior**92,99
- NY WTS 97+ Black Side Skirts
- CA WTB fujin lip...other lips may interest me
- GA WTB: 5speed pedals and master
- MD Fs: 99 lexus sc300 partout
- TX cheap items for sale
- MN WTB: SC300 flex plate
- TX HVAC unit (behind dash), ducting and vents
- CA WTB:PPE Long tube Headers 1998 SC400
- TX WTB Running Low Miles 2JZGE engine
- NY FS: Interior Pass Door Handle
- FL SC300/400 trunk with pre 97 spoiler
- NY FS: Clear Headlight Lenses (RidesLow Group Buy)
- AL FS: Two Subwoofers, one is Nak and other is Pioneer
- PA WTB: Wood Trim for Gated Shifter
- FL FS 99 Black 3 Spoke Steering Wheel & Airbag
- TX WTB: SC300 5spd swap parts, excluding transmission, Houston, TX
- FL FS: Tan Steering Wheel and Passenger Airbags with Computer
- GA WTB: Coilovers
- OR FS: Complete R154 setup
- CA WTB Lower Control Arm
- TX WTS: new meth kit, map ecu 2, aero stealth pump
- TX emanage ultimate w/ pnp harness/map sensor ($450 shipped) and 850cc injectors ($250)
- TX WTB 97 sc300 engine harness
- AL WTB: AEM digital boost gauge, bumper seal, vents with or without woodgrain
- FL Trd lsd
- TX WTB: trashed/broken(cheap) center console
- FL WTB: Factory amp and head unit
- CA Wtb wise front lip.
- FL FS: IACV and Airbag
- OK FS: Black steering wheel with airbag
- CA WTB: sc300 or supra OEM CA spec precat
- TX WTB 92 black dash
- NY FS: 750cc High imped. injectors with fuel rail
- NY wtb: Stock Jza70 1jzgte manual ecu
- CA FS: 1997 Gauge Cluster + Harness for conversion.
- AZ black ebrake handle
- CA Bomex sideskirt and rear lip Price Reduced
- AZ stock aristo twins
- AL FS: Spare Tan steering wheel with airbag
- Searching for 1jz stock turbo oil outlet hose replacement
- CA socal : SC400 lip
- KS WTB Emergency brake handle assembly
- AL WTB: Black OEM floor mats, Complete black seat belts with buckles and hardware!
- GA Tial Wastegate LS400 Calipers Black Dash 97+ Body kit
- MD Soarer Griffin Badge and Red Cluster Needles Only $45 shipped!
- AL WTB heated seat button for 1997 sc300
- AZ mk4 550cc injectors $220
- CA FS NEW/USED Megans EZ - socal 91770 - 91746 area $600 PICKED up
- CA socal : BLACK INTERIOR
- GA WTB" Precision 6766 or similiar
- MO FS - Supra TT Auto LSD
- MO Rear Lower control arms
- FL Brand new Spec Stage 3 6 puck Clutch Kit for W58, 1JZ Alternator+A/T Tranny,MSD Tach
- MD Blitz Nur Spec Dual Exhaust For Sale
- WA wtb airbox
- FL injector dynamics id2000 and id1000
- MO holset h1c turbocharger $400.00
- CAN-Toronto WTB SC 400 Front Bumper Toronto
- FL FS: 97+ Spoiler 1JZ Parts: Intake,Injectors,Fuel Rail...Apexi SAFCII, HKS FCD, 3" D/P
- AZ Brand New Lexus SC300 mats
- CA (2) Soarer griffin badge (1) soarer emblem
- FL WTB 97+ Taillight Harness
- FL brackets to mount the 97 1uzfe engine cover 16.00 shipped!
- NC FS: GE Cruise Control Motor, Coil, GE plug covers, ect
- AL FS: Fuel Pump ECU
- PA OEM Suspension (Garage Clean-Out)
- AL FS: TRD Shifter
- CA FS: OEM low beam headlights
- CA Ft: Megan ez coilovers with upgraded springs
- CAN-Toronto Torsen 3.26 Auto TT LSD
- IL WTB: Cigarette lighter/ashtray assembly with flip-up lid
- CA FS: 97 Kit ~ Bumpers ~ Skirts ~ Trunk/Spolier ~ SOCAL LOCAL ONLY !
- FL TT Clutch Fan / RX300 Steering Wheel
- CA Wtb: 5 speed diff
- CA WTB SC400 crank pulley
- CA FS: Local pick up SOCAL Interior Parts
- AZ 97 SC400 differential bushing
- CA WTB Bra
- MD Soarer Badge and Red Cluster Needles Only $60 Shipped!
- OK FS: Stock Supra MKIV TT Springs 69k Miles
- MD WTB: sc300 motor mounts and engine harness for 93
- FL FS: Driftmotion, Spec Clutch, Flywheel, W58 etc.
- TN WTB: 2JZGTE Parts (factory parts)
- NJ For Sale VVTI coilpacks, wingless trunk, oem suspension
- FL WTB - OEM 5speed shift knob, OEM 1JZ power steering reservoir
- CA WTB: Black interior passenger seat belt assembly
- KY Black passenger seat
- FL SC300 black interior parts
- TX Complete black interior, will not part out, Houston, TX
- NV wtb: FMIC piping
- NY wtb..usdm tt cams machined for 1jzgte
- NC 97+ Sides and Rear Bumper
- CA Extreme Dimensions Need A SC300/400
- CA Supra TT auto LSD Pumkin w/ axles
- AZ WTB Sc300 auto drive shaft
- CAN-Toronto OEM Mud Flaps and 93 OEM Tan steering wheel with AIR BAG
- MD FS: Q45 Throttle Body non Traction Control (Ideal)
- FL FS:SC front lip and ls 400 caliper
- GA Wtb 2jzgte lower & mid timing cover
- NY wtb: 1jzgte aftermarket cams
- OK Wtb: Steering Rack bushings
- TX WTB: 97+ front bumper in DFW
- MD WTB: 1jz Throttle Cable Bracket, All 1jz vacuum lines/hoses/tubing, 1jz starter
- ID SC CD Changer, Stock Sub, Airbox, fan clutch, keyfob, & more
- FL Soarer Griffin Badge
- FL Garage clean up sale gte sc400 sc300 etc etc all cheap!
- OH aliga private message box full
- IL Vibrant Exhaust Duel Setup
- NC Wreck my SC FS Thread
- GA Ikeya Formula sc300 subframe spacers 140$ brand new
- FL 2jzgte new headgasket 75.00
- TX 92-95 JDM tails
- CA FS 97+ front bumper with rideskinz fujin lip and sideskirts
- OH FS:AEM Gauges - Boost, fluid pressure, serial
- FL Super low mile 2jzgte valve springs 30 shipped!
- AL need some parts!!
- GA 97+ Rear Bumper & Valances
- DE Wtb goose neck shifter anyone has one
