View Full Version : SC400 / 300 Classifieds
- CA 1jz Stock Twin Turbos and all Pipes
- NY FS NY: OEM sc400 complete driveshaft
- NC Flex-a-lite fans dual 12"
- FL Anyone have this missing A/C vent plug part?
- FL WTB OEM front lip 92-95 sc400
- AZ full oem 1997 aero for sale and a few black interior pieces
- SC RC injectors & 2jzgte mani gasket
- CA WTB: Front Seats
- CA WTB: Shift Linkage 98+ SC400 Auto
- CAN-Other FS Read Black Leather Seats
- TX Q45 tb with beech performance Tps adapter
- CA FS: 1997 Cluster
- TX 97 oem Tailights clean w harness DFW area
- FL Greddy rad cap,walbro 255,short studs for a single mani,new oem belt tensioner etc et
- FL Jzz30 harness and ecu: uncut, good caps
- MD SC300 5spd ECU
- GA WTB: 2jz crankshaft
- NV Na-t Intercooler piping SmiC
- MD WTB: Roof Rack
- CA 97 front bumper cover 300obo
- CA vette cats with 2.5 size 28k miles
- AZ WTB: Boomslang AEM FIC-6 Harness BF12019
- VA Authentic Bomex rear spoiler for the SC300/SC400.
- CA Brand new turbo parts for sale
- NY wtb 2jzgte crank sensor
- FL Wtb ge ecu
- FL New oem hydro tensioner 30 shipped!
- NY FS: Mint JDM 2jzge 6spd throttle body with IAC and TPS
- NV FS: Soarer Airbag, 95 tails, and damaged 97 tails
- MO Lexus/toyota/supra goodies for sale
- TX WTB Turn Signal and Window Wiper Stalks
- CA FS: AEM V1 package.. MAP, IAT, WIDEBAND
- VA 2jz engine/ aristo ecu/ wiring harness
- GA WTB 95 sc300 heater control valve
- CA WTB engine/motor mount
- FL R154 RPS MAX STAGE 3 clutch kit
- CA Soarer Badge for sale, Ship out same day
- TX WTB: ID2000 or FIC2150 injectos
- CA FS 1996 tails
- CA 1jzgte stock ecu, greddy e-mange blue + boost sensor
- NV wtb: IAC valve
- CA *NOR CAL* _ WTB - SC400 Coilovers
- FL New authentic walbro gss342 w/install kit 100 shipped!
- NY WTB 92-96 SC300 Rear Driveshaft
- CA WTT: 25mm wheeel spacers(F/R)
- NY Tan 3 spoke steering wheel, airbag x 2, Black 3 spoke Steering
- TX alternator, starter, and injectors.
- CA FS - Vertex Rear Bumper
- FL ls400 bbk 97+door moldings
- LA wtb
- FL Built 2jz 1.5 0miles!!
- OK FS: Black Door Switches
- NV WTB: 92/93 sc300 automatic ecu
- FL WTB SC300 fuel tank sending unit
- FL WTB front lip off 92 sc400
- CO 96 sc300 automatic ecu
- FL Wtb: R154
- NM WTB Side Skirts and Lip
- TX WTS ABS Delete fittings
- WA 1JZ GTE Starter - 80$ shipped
- FL SC300 5-speed 4.08 differential
- TN FS: 2000 SC#00 Tan Perforated Seats - front and back
- FL 97+ Driver side tail light & Tan door panels
- FL Wtb, OEM Floormats
- GA FS 440cc & Apexi Neo
- CA **Complete Exhaust System - Top Speed Pro-1 SC300/SC400**
- CA 2/4 97+ conversion (Bumper w/ Extensions and Side skirts)
- TX for sale 90mm Q45 throttle body
- FL Wtb: R154
- IL WTB: Sunroof trim in black
- GA TRD Strut Bar and Chromed ABS / Canister Cover
- FL New BC valve springs,arp studs,tt head gasket and gsc vss
- TX Wtb: Used coilovers and cd player.
- CA FS: Wide Fender Flares
- NC FS: NA-T DP, Dump, 4" Intake, DM Wastegate
- NC FS: Misc GE Ignition Components, Door Trim, Pass Handle, TB
- GA WTB:97+ Sides and caps. DWP Preferred
- Looking for air dam
- IL 2jz gte header with tial wastegate
- OR Soarer sard ecu
- AZ FS: Toyota OEM 1JZ/2JZ R154 Flywheel
- NY WTB: 1JZ Flywheel
- IL WTB: USDM Supra 6 Speed TT ECU OBDII
- KY WTB: supra 6 spd tt diff with axles and v160 tripod and shift rod
- NY Exedy Stage 4 Clutch
- CA FS: LS400 BBK Calipers + Rotors
- OK FS: 1JZ flywheel, R154 1 piece driveshaft.
- NY 92-00 lexus sc300/400 kyb gr2 shocks
- GA 350Z 6spd conversion for 1UZ.
- CA wtb supra tt swaybar front
- CA WTB: GTE aristo intake manifold
- NY wtb map ecu 2
- KS WTB 1JZ GTE water pump
- FL Looking for some parts
- VA FS: Tan OEM Floormats
- CA wtb: vertex ridge widebody kit
- AZ 2JZ OEM rod bearings
- CA FS Driver side 97 (black skirt)
- AZ 1UZFE 3UZFE ARP Head Stud Kit $300, Genuine Dellows 1UZ-> R154 Bellhousing $550 PHX
- NJ f/s megan street ezy coils.
- GA WTB: Front upper adjustable control arms
- CA so cal. 97+ oem bumpers and sides
- IL WTB: W58 trans or R154 with extended shifter
- TX Walbro fuel pump and oil feed line
- PA WTB: 92 sc400 transmission. Local near Philadelphia, PA
- FL :::: FS: 264 GE Cams *NEW* ::::
- IL AEM V1 EMS for sale
- MD 97up rear bumper, extensions, side skirt, enkei wheels, shift boot, 96 steering wheel
- CA FS: JDM GTE downpipe.
- TX Houston SC300 turbo parts,Black seats, 2JZ-GE engine, 3" exhaust, other stock parts
- AZ FS: Toyota/Aisin R154 Pressure Plate
- FL sc parts/supra parts
- CA SC Poly Control Arm bushings rear/front
- CA Looking for a sc300/sc400 shell 92-95
- Just joined club Lex. NEED Some parts. Tired of the Stealership
- FL 97+ tail lights sc300
- TX FS: RX 300 Airbag (1999-2000)
- TX FS: RX 00-03 Steering Wheel (Wood)
- CA Wtb side skirts (vertex ,auto shine etc..
- CAN-Vancouver wtb: Aem ems
- CA WTB: Stock SC400 Y Pipe (with cat)
- NH GE head
- CA SC300/SC400 Rear Eibach springs on stock shocks Strut Suspension setup
- FL 92 - 96 Wise (ebay) Front lip
- CA FS: OEM Black hood
- wtb: Who selling coilovers?
- TX WTB Climate Control
- OR Na 2j and 1uz fs/ft
- GA Injen Cold Air Intake for Lexus SC
- GA WTB 1995 sc300 valve covers
- AZ FS: 2JZ ACL rod bearings
- VA FS: BNIB- AEM Tru Boost, Bosch EV14 750cc, GM 3bar Map Sensor
- MD BW s363 bnib..
- OR Wtb 1jz twin turbos
- CA Wtb: 97+ rear bumper w/ rocker panels, also side skirts
- OR SC300 fenders
- PA WTB: Karman Vortex Mass Air Flow Sensor
- FL FS Tial gate
- CA wtb: sc300 manual shifter bezel
- MO FS: Tan 01 RX Steering wheel and airbag
- CA BoostLogic NA-T manifold, dp, mp,wg,etc
- IA GTSPEC front strut brace-like brand new!
- CA WTB; 2jzge Crankshaft Pulley
- NY WTB Manual Shifter Boot
- CAN-Toronto WTB Nak Amp for a 93 Sc400
- NY wtb looking for L/R headlight sockets and connections
- VA WTB: Driver's side Door Panel - Ivory (Light Tan)
- FL OEM 1JZGTE and SC300 parts
- CA FT 97+ Side Skirts (Black)
- CA FS: Black SC fenders Make offers!
- IA FS: Late style OEM SC tails - very clean $250 shipped
- FL F/S F/T 97+ Full OEM kit (front,sides,rear)
- CA Fs: Apr gtc-200
- CA Daizen rear upper and lower control bushing kit S1-2003
- CA F/S 97+ sides and rear bumper Is300 steering wheel, black door panel
- PA FS: MAFS SC300 2JZGE x 2 $50 each shipped 48 states
- CA WTB: trunk mat
- AZ FS: 1990 Toyota Supra Turbo MKIII R154 Transmission
- CA FS: SC door hinge
- IL ★★★ 2JZGTE Custom T6 Flange Tubular Exhaust Manifold ★★★
- PA FS: Set of 7mgte 440cc injectors
- MD WTB interior door handles
- FL 1jzgte engine (MOTOR ONLY) with some single turbo goodies
- TX DFW: 2JZ-GTE VVT-i engine and parts
- OK WTS: MANY PARTS 97 Tails/cluster/RX wheel
- CA WTT: 97+ Vertex front lip for modded 97+ taillights
- NM More SC stuff for sale
- NV 95-96 passenger side tail light (Las Vegas)
- Looking for Passenger rear window
- MD WTB: TT Supra / Soarer Power Steering Reservoir
- VA FS: 440cc Injectors and 7mgte CPS
- FL Stock 2JZGTE w/extras, Full Harness/AEM Included, GM Powerglide PRICE REDUCED!
- CA FS:R154: ACT clutch & slave cylinder
- CA FS: ACT clutch, R154 slave cylinder
- NY wtb: Precision 6266 .81 ar
- LA 2jz / 1jz Starter $70 shipped
- FL FS: Motec M8
- CA WTB Climate Control
- CA FS: 1992 Sc300 stock shocks and springs
- MO WTB Passenger Side Interior Door Handle
- VA WTB: SC300 Fan Shroud
- FL Lots of parts for sale, Resistor pack, ECUs,GT47-88.. come inside!
- NH WTB: obd2 harness
- FL ebay greddy replica intake
- NY WTB power steering pump
- NY WTB: used Coilovers and ls400 BBK
- MI 97+ parts for sale.
- GA WTB: 92-96 rear fujin lip, 97+ sideskirts
- CA ge rebuilt head ported and polished
- CA LS400 Brakes - 98-00 Taillights - Black Back Seat
- NY Extra NA-T Parts
- CA FS: Supra Turbo Auto LSD
- FL FS: door actuator and regulator w/ motor
- FL Fs:sc300 ecu
- CO FS-Oem Gte water pump & oil pump & a few other parts.
- GA BC cams, Gray interior pieces, garage clean, map sensor, lots of parts
- CA FS: 97 + Fog Lights
- TX FS: Cluster Needles for SC
- GA FS - Black wingless trunck
- TX 2jzge turbo manifold
- MN FS: Misc Black Interior Pieces
- CO rebuilt r154 [24hr]
- CA FS: gs300 steering wheel with airbag
- MD WTB Back Seat Upper Portion Leather TAN
- TX Tial 38mm with flange.
- CA WTB:TT ECU Mod parts
- FL sc300 wire harness section from mid fire wall to ecu w/all plugs for a tweak conversi
- wtb: My SC 400 Output Air Conditioner, center panel #55660-24071
- CA FS: Roof Spoiler and Carbon Trunk Lid
- FL FS::: Map ECU V1 with everything.
- CA WTB: LEXUS SC300 Fan Blade and Shroud
- AZ WTB: SC300 Engine bracket Left/driver side
- CA aeromotive stealth 11142 fuel pump 340LPH
- CA wtb: stock 92 dogleg style shifter for w58
- PA WTB: A/C Condenser in Philly Area
- CA WTB: 97+ Front Oem Bumper (Black Onyx)
- FL FS: 6 new ID1000 high indepedance
- NC WTB: Rear bumper extension
- FL FS: 1jzgte drewgo single turbo manifold!
- GA F/S 98+ Gated shifter and Ashtray
- GA WTB 97 sideskirts, clutch pedal
- NE WTB 98+ gated shifter!
- CA Tan ripped rear seats $10
- GA 2JZ Auto Transmission w/ Torque Converter
- CA 1 lexus sc300 headlight $100
- TX WTB fan blade sc300 (Houston)
- MA Kyb agx/eibach complete suspension
- PA Tan Butterfly Cup Holder
- CA 95-96 Fog lights & OEM Mud Flaps
- FL WTB Black rear cupholder
- CA 95-96 Tails + Harness & Lamp failure unit
- CA OEM BLACK rear set set.
- NJ wtb:sideskirtsand front lip
- TX FS: Black "Butterfly" Cup Holder $35
- NC Wrecked my car and have too many spare parts sale (SC400)
- GA Bc 264s, springs, trd motor mounts
- CA Looking for OEM full exhaust pipe for SC400
- CA rebuilt vvti ge engine
- TX WTB. Harmonic Balancer
- MD FS Bw 9179 aka S366 Cheap!!
- TX WTB: Supra/Soarer side mount intercoolers, Houston, TX
- FL MVP Headers
- MO WTB OEM SC300 exhaust center pipes
- MD WTB 3rd brake light-tan
- PA FS: 2jzGE a/t ECU
- CA stock radiator sc socal
- WA 97 Black steering wheel & AT ecu
- PA WTB sc300/400 front bumper
- PA Sorry not enough history for partout
