View Full Version : Suspension and Brakes
- knocking noise
- rebuilding shocks.
- Blitz suspension?
- Daizen Bushing Kit. Where can i get cheap?
- greddy strut tower bar
- Question on Suspension Setup..
- Supra Coilovers on SC?
- tokico kit question - please read
- Reverse Supra brake conversion? Loosing the TT 4pots?
- Conversion to Twin Turbo Spring Shock?
- vibration above 60mph
- HKS upper pillow mounts with Tein Basics?
- Ball joint dust covers and steering rack bushings
- NEW teins for my soarer
- Thumping noise and Vibration, any help?
- clicking noise when turning
- just swapped out my spare with a supra spare
- TMEngineering.net and Daizen bushings - good stuff!!
- Attn: anyone with TT brake swap
- What is a fair price for Supra LCA's installed?
- Daizen Install Gone Wrong
- Disable ABS on SC
- Supra TT brake lines comaptible w/ ...
- struts
- Cutting bump stops with Tein Coilovers?
- Suspension (bushings)
- Wheel Alignment with 18" rims
- Daizen rear bushings
- New Strut Bar...
- Rear strut for SC300?
- TRD brake pads for cheap? We'll see...
- Squeak Squeak, Please Read On...trust Me Its Different. Help
- Fitment Supra TT Bars?
- coilovers
- Question?? Tokico illumia shock/spring kit. Anyone know about it??
- Front Strut Torque Setting (New Strut Bar!)
- Why alignment after shock install?
- Pep boys shock install labor only $13.99?????
- New goodies
- How long can shocks last???
- Replacing Rear Control Arm Bushings
- Question on shocks for 1" drop
- Need Help, Can I make my SC track competive?
- Rusty Rotors
- TRD Supra Sways on SC400
- Greddy Strut Brace over a last-gen SC400?
- Coilover adjustment?
- KYB vs Tociko
- Yay or Nay on labor prices
- Here's your chance to get LSD for cheap
- Tein Basic & Supra LCAs installed
- Installed Eibachs/Tokico ??
- rotors
- Does anyone know a good alignment place in LA?
- Control arms
- Stiff Ride on a 97 SC300. Normal?
- Brake newbie need help please
- Upper pillow ball mount same thing as camber kit?
- Rubber boots
- car alignment with 19's and dropped. will any do?
- Anyone running TT Brakes with IS300 Wheels?
- Cheap TT supra calipers
- Noise after Eibach spring insall
- Camber kit with Eibachs?
- Brake question!
- brake issues after big brake upgrade
- siaxazn-tein basics
- Where are the part #s
- Suspension newb 2 questions. Upgrades, and noise in susp.
- Sway bars for SC-400
- K-Sport Coilovers?
- The Drop
- What 1st Suspension Mod did you notice biggest difference?
- tein s techs
- lower controll arm bushing
- 19" Rims, Brakes, Tires suggestions
- Anyone got tein ss coilovers?
- Questions about Daizen Sway Bars?
- squeak squeak when turning steering wheel
- Illuminas With Tein H Springs?
- Supra Shocks & Struts
- Opinions on Suspension upgrades please
- what else to change???
- Tein CS setup...
- Stiffer rate.... Stock Height??????
- is300 on supra or ls calipers
- going next step with daizen camber kit issue...
- In search of a Cusco strut bar part #.
- Wheel play?
- any one have tein flex?
- front supra sway bar end links fit sc?
- kei office coilovers?
- anyone with pillowball mounts
- knocking noise
- New bushings or new arms
- anyone try the espelir active gt spring?
- Contact! Tire and inner fender liner
- Which supra spring drops 1 inch on sc?
- popping noise when coming to a stop during braking
- 20 inches 2 much????
- Nice coil kit?
- How many of you have changed steering rack bushings?
- Iso Shock Info For Eibach's
- Some hints for installing new springs/shocks
- Change to eibach spring
- How to adjust Hipermax dampening (or anyone who can read japanese)
- Anyone try dropping on 19s with 34 offset?
- d2 coilovers?
- Cam Bolt Adjusters
- front upper control arm ball joints removable?
- Need a Good Deal on Lower Control Arms
- Eibach or not!
- Supra Endless Big Brake Kit
- Teaser pic 2
- Very Impressed With Espelir Springs
- Pics On Factory Supra Springs Wanted
- Wheel spacers
- Are rotors on '96 SC400 & '97 SC300 same?
- Espelir springs making noise?
- espelirs installed..camber/alignment questions
- makin' a decision on brakes right now... need input
- Front Upper Strut Bar
- MKIV TT Brake Rebuild Kit
- OK I need a final answer
- Need advice for SC400
- brake light coming on?
- KYB shocks - good or bad?
- New Brakes Respons Asap
- Anyone use Tein S tech Supra TT springs for their SC's ???
- Would camber kit for supra MKIV fit SC4?
- Got my Espelir prings and Tokico HPs installed today....for $120
- Front Rotor Removal (again)
- SC Control Arm Bushings
- SC Stainless Steel Lines w/ LS4 Calipers?
- popping noise while turning sharply in Rev.
- Brake Upgrade....How?
- Bolt pattern on sc400?
- new stock struts, sway bar links and bushing...BUMPY RIDE!!
- anyone know where I can get OEM front supra mkvi Turbo shocks
- Why is bushings labor so much
- Tein HA Coilover
- supra tt big brake conversion
- all the things to lower my car...
- Fitment on front strut tower bar
- Just bought Espelir springs...
- Very touchy brakes after Supra upgrade
- PS Rack Bushings
- Lowering and Daizen Sway Bars?
- Just installed Daizen bushings and Tokico Blues...and I'm in love all over again
- supra tt brakes... cheap(reman)
- Another LS 400 Brake Conversion Completed
- Drop thoughts
- Need some opinions on how much to lower my car
- Help, which lowering springs should I get?? (Eibach, Tanabe, H&R)
- vibration on the rear passenger side
- Painted Calipers
- tanabe springs
- will they fit?
- HOWTO: Coilover install with PICs
- Lowering issues continue: ( when does it end )
- EBC Green STuff Brake pad dust???
- Toyota TSB PG027-02 "Suspension Ball Joint Inspection"
- Disc brake sliders tip
- Rear bushings
- My first "official" Mod
- quick question regarding TEIN
- SC400 front Caliper removal issues
- Loose Steering
- SC300 bleeding brakes
- All SC owners with TEIN Coilovers
- Coilovers on the way, what to replace?
- I need help with rear rotor removal for sc300
- 11.5 rear wheel with stock suspension?
- lower control arms
- Torn Ball Joint Boots
- Anyone in Houston area know how to change rotors / pads??
- Brakes.... can't get any service / help!!
- Tanabe Coilovers
- The way a Soarer should ride! :)
- Oversteering SC400 - What cures available?
- WTF? Steering wheel deadspot? Help it is making us sick!
- Rear Tire Rubbing Sound. Normal?
- TT Supra rear strut assy upgrade for SC, clinic
- Handling improvements for 300?
- Factory ground clearance???
- Control arms replacement clinic
- My G35 Brembo inspired TT Calipers
- ABS issues...please help!
- Painted My Calipers
- aliga is the man, got my LS400 calipers installed.
- Supra springs and struts. Where is a beef?
- Brakes Shudder When Wet
- Staggered Tires
- jic majic
- SC400 Tower Brace Woes
- lowering springs?
- Bump steer correction
- Rear Disc Removal
- brake upgrade
- Tein HA's
- Strut Tower Bar Install HOW-TO
- Best Deal on OEM-size slotted rotors?
- i need some endlinks
- Lowering An SC400!!! Please help!!!!!!
- Tein CS coilovers
- stock 95 SC400 wheels/tires , lower sidewalls?
- how different are supra endlinks and 92SC400 endlinks?
- guys, need help...clanking noise after the drop..
- torque setting for factory sway bushings?
- do they make roof spoiler for the SC
- Opinion on lowering 94 sc300
- finally, going to lower car tomrrow..
- I need your opinions on suspension dilema
- FYI: Daizen sways for sale in the Sc400 sales section
- Suspension Questions
- sc400 eibachs in sc300 NA-T?
- HELP!! Supra LCA's part numbers...
- Need new struts...
- How are the Daizen Bushings??
- Suspension Dillema
- which springs are good for SC3???
- Is this a deal??
- Factory springs/struts out
- Different coilover setups in front and rears
- rear cross bars
- Daizen Camber Kit on Tmengineering.
- how will it look..??
- spring installation...
- Per request - pics of Lexus front bushings - Courtesy EuroJulian
- Looking to replace your old bushings???
- gs300 coilovers on sc300
- What suspension is every one running
- Thinking ahead about rack.
- brake time -- anyone know where to get a good deal??
- Some Questions About Wheels And Suspension!!!
- Daizen bushing gone bad???
- Yokohama ES100 - What PSI for comfort?
- Lower crtl arms bushings are aviable from Lexus
- Daizen Bushings and Camber Kit
- Ceramic brakes?
- Are most drilled and slotted rotors directional?
- oem TT and NA shocks?
- wierd brake ques... only one side worn!???
- Eibach Pro kit for Supra TT. Drop on sc?
- Anyone gotta JIC strut bar?
- under hard braking.....
- Need some part numbers...
- LS 4-piston Brake setup for my SC4
- LS400 brakes on SC300
