Charging ports
Old Apr 17, 2026 | 06:43 AM
tonyroman's Avatar
tonyroman
Default Charging ports
Can these ports be used to charge Android phones, and if so , how please?
Old Apr 17, 2026 | 09:05 AM
jer's Avatar
jer
Active Streak: 30 Days
Yes, you just need to have a USB-C to USB-C cable. Amazon, Walgreens, CVS, dollar stores all pretty much carry them.
Old Apr 17, 2026 | 09:19 AM
tonyroman's Avatar
tonyroman
Thank you.
Old Apr 17, 2026 | 09:21 AM
tonyroman's Avatar
tonyroman
I hope it's faster than the wireless charger which seems to charge at a mere trickle.
Old Apr 17, 2026 | 10:19 AM
N4TECguy's Avatar
N4TECguy
Much faster. These are 15 watt chargers, the wireless charger seems more like 3-5 watt, varies depending on its mood and the astrological phase.
Old Apr 17, 2026 | 10:32 AM
tonyroman's Avatar
tonyroman
Thank you.
Old Apr 17, 2026 | 10:36 AM
HeyThere's Avatar
HeyThere
The wireless charger does nothing. I'm surprised there hasn't been a lawsuit. I made a two hour trip with the phone on the wireless charger. It showed on the screen it was charging. After two hours, no change.
Old Apr 17, 2026 | 11:31 AM
N4TECguy's Avatar
N4TECguy
Its not that it does nothing, it's just finicky. Most cases, especially MagSafe ones, will severely restrict or flat out disable the charger. Even in optimum conditions, it doesn't really add electrons fast enough to counter the phones usage rate, especially since many are now using wireless Android Auto or Apple CarPlay, which both use a ton of battery.
Old Apr 17, 2026 | 01:51 PM
jer's Avatar
jer
My salesperson did advise me that it was a very slow charger and if I wanted a fast charge to use the USB-C connections. Also, if you are using any applications on your phone- i.e., Waze, etc., that will pretty much negate any increase in battery as the phone is trying to charge while also running apps.
Old Apr 17, 2026 | 06:04 PM
Urlik's Avatar
Urlik
Of course it is.
Old Apr 17, 2026 | 07:10 PM
mikemu30's Avatar
mikemu30
Our RX came with a cable kit that includes two usb-c to c cables.
Old Apr 18, 2026 | 05:02 AM
Sonny3621's Avatar
Sonny3621
The wireless charger in mine works just fine every time. Not the fastest of course but it works as intended. A lot has to do with just the thickness of the phone case, state of health of the phone's battery, phone usage while charging, an issue with the charger itself, etc. but it does work. There are many variables but certainly nothing that would warrant a lawsuit.
Old Apr 18, 2026 | 05:19 AM
Urlik's Avatar
Urlik
The wireless charger is too low a power to keep a phone charged when it's using Waze and wireless AA/CP. Your phone will be dead after a good 400 miles of driving. The USB charge ports will keep the phone charged. There are higher power wireless chargers but Toy/Lex chose the original lower power version.
Old Apr 18, 2026 | 07:25 AM
Kensterfly's Avatar
Kensterfly
yeah.. Lexus charges about $75 for $2.50 worth of cables.
Old Apr 18, 2026 | 08:42 AM
WellsB's Avatar
WellsB
It actually heats up the phone quite nicely. The only time I use it is when I get moisture in the charging port. The heat dries it out quickly.
