Check Engine Ongoing 2001 RX300
I've had this light on for a while. Everytime I get it checked, the Evap codes come up. P0440 P0441 P0446. I also have the Trac Off, VSC, and ABS lights on. My dash looks like a Christmas tree.
Anyways, I read that this could be from an air cabin filter hose disconnected when the filter was changed. I reconnected the hose, cleared the codes, and P440 has come back after 100 miles.
If I open my door after starting the car, I usually can smell gas for a couple minutes, then the smell goes away.
How can I fix this? AutoZone says I need a new vapor canister, but I don't always trust their word. I can get a new gas cap, but I'm not sure if that's the issue either.
Answers appreciated. Thank you.
This is a good P0440 post and thread https://www.clublexus.com/forums/rx-...ml#post5230674
Since it starts with gas cap might as well start there. I agree, use a genuine one.
Replaced with genuine one, problem gone.
I damaged my parking brake because the bulb had burned out, I was in a hurry and didn't notice my parking brake was still engaged.
So I moved the good bulb from the engine indicator to the parking brake indicator: https://www.clublexus.com/forums/rx-...placement.html
Salim
evilxlexso
RX - 1st Gen (1999-2003)
Apr 27, 2017 04:57 PM
BBLexus
Mar 24, 2012 11:57 AM
nc-longhor
Mar 21, 2007 01:10 PM
