IS200t tune
Old Aug 7, 2017 | 05:35 AM
  #1426
TTITony's Avatar
TTITony
Former Sponsor
The advantage is to make the engine output balance and stability, the most important thing is to allow VVTI to enable it to achieve high performance,
Our YAMAHA 8ARFTS engine really powerful.
My hybrid turbocharger will be finish end of this month.
Don't forget about it.https://www.clublexus.com/forums/per...nd-modify.html
Old Aug 7, 2017 | 05:44 AM
  #1427
Sheddy's Avatar
Sheddy
Originally Posted by cosmo1
It's hard to tell but it seems the torque seems to hold longer throughout the rpm's with the reflash and or the dp's compared to just the bms piggyback.. With the bms it peaks and then gradually lowers throughout the rpm's to where the reflash and dp's maintain throughout the rpm's.
Yup, that's the major difference with the re-flash. A lot of variables are adjusted to make more power throughout the power band.
Old Aug 7, 2017 | 06:23 AM
  #1428
cosmo1's Avatar
cosmo1
Tony I couldn't find a link for your downpipe for the 200T. Could you post a link, price, and availability?
Old Aug 7, 2017 | 08:51 AM
  #1429
TTITony's Avatar
TTITony
Former Sponsor
With sport catalyst.....http://www.pchomeusa.com/product/CJ9400Z1DRJ
Smooth type.....http://www.pchomeusa.com/product/CJ9700XUDP4
Vortex type....http://www.pchomeusa.com/product/CJ9900XSDEF
FYI
Old Aug 10, 2017 | 04:05 PM
  #1430
IS200TFOWL's Avatar
IS200TFOWL
PPE installed valved exhaust
props to aem on this intake. Gives you plenty of turbo sound and keeps the intake temps down
Old Aug 11, 2017 | 12:08 AM
  #1431
PGARazor's Avatar
PGARazor
Update after service visit at Lexus dealership. I reverted to stock ECU before taking car into service and they didn't say a word about having sport downpipe and cold air intake. I just emailed Tony, so he could check if they updated ECU while service visit, but they didn't touch it. Still doesn't hurt to take ECU to stock before doing any work at dealership, better to be safe than sorry. Tony said "This tune is 100% stock as same as before they wasn't change anything so you just put the stage 2 tune back via flash tools."
On a different note I took a trip of 500 miles in the last couple days and was getting 30-31 MPG going at 80 MPH, on Stage 2 flash from TTI(Tony). Loved the power on the open highway , glad I had my radar to assist me. Lol
ill add pics when I get on desk top, still trying to figure out how to post pics up from mobile.
Old Aug 15, 2017 | 08:58 AM
  #1432
Sheddy's Avatar
Sheddy
That's great! Glad to hear it went smoothly with the dealer.
I am about to change another vacuum regulator. Came back from vacation to boost fluctuations.
Old Aug 15, 2017 | 11:54 AM
  #1433
E46CT's Avatar
E46CT
I am about to change another vacuum regulator. Came back from vacation to boost fluctuations and radiator fan being constantly on.
how many miles do you have? i'm at 11k and so far on the original regulator. am i lucky or are you unlucky?
Old Aug 15, 2017 | 01:23 PM
  #1434
Sheddy's Avatar
Sheddy
I am at 28K. There was a thread regarding the buzzing sound issue and a couple members who are not tuned had to get it replaced a second time.
Old Aug 16, 2017 | 10:54 PM
  #1435
busy0201's Avatar
busy0201
The saddest point about that issue is that most of the time, we discover/rediscover the issue because we killed by a slower car
Old Aug 17, 2017 | 06:05 AM
  #1436
Sheddy's Avatar
Sheddy
I've had the fluctuating boost symptom before, but the buzzing/humming sound is a first. As you can see i replaced the 1st myself and positioned it in an easily accessible spot just in case it goes again.
Old Aug 17, 2017 | 08:33 AM
  #1437
PGARazor's Avatar
PGARazor
Here a copy of Dyno results done yesterday, been busy so finally got it done. Running TTI Stage 2 with sport downpipe. Also at 5,500 in elevation, running on super premium unleaded. Only choice in desert far as I know.
Old Aug 17, 2017 | 09:03 AM
  #1438
Sheddy's Avatar
Sheddy
Thanks for posting.
Are these the Stage 2 with down pipe results? What type of fuel are you running and the temperature? I see that they are the SAE numbers which gives you a lower reading vs STD.
Old Aug 17, 2017 | 09:47 AM
  #1439
Sheddy's Avatar
Sheddy
I am sure those factors made an impact on your results. It would of been nice to get a comparison between stock and stage 2, but you feel the difference in power and response, so that's where it matters.
STD:
Air Temperature: 60F
Absolute Pressure: 29.92 inches Hg
Relative Humidity: 0%
Relative Horsepower : 104.8%
Air Density: 1.223kg/m3
Relative Air Density: 99.8%
Density Altitude: 67feet
Virtual Temperature: 60F
Vapor Pressure: 0 inches Hg
Dyno Correction Factor: .955
SAE:
Air Temperature: 77F
Absolute Pressure: 29.23 inches Hg
Relative Horsepower : 100%
Air Density: 1.157kg/m3
Relative Air Density: 94.4%
Density Altitude: 1952feet
Virtual Temperature: 77F
Dyno Correction Factor: 1
Old Aug 17, 2017 | 10:57 AM
  #1440
PGARazor's Avatar
PGARazor
I did figure the results would be more misleading because, I definitely notice the difference between stock and Stage 2. Especially in acelaretion has decreased in the delay, on my daily drives I have loads of fun. I'm patiently waiting to see what new Stages Tony come out.
