IS200t tune
Hi Nuke
Pump gas only and rescue the drivetrain loss so we put light weight rims also[/QUOTE]
Totally agree FWD and FWD drivetrain loss different.
We found that the intake air temperature during the test affected the pressure value.
One of the reasons why i do prefer the Air to Air intercooler, but the Air to Water has been said to be more efficient and cuts down 0-60mph times, plus other manufacturers have gone this route on their turbo motors as well.
We found that the intake air temperature during the test affected the pressure value.[/QUOTE]
I'm sure it does when the temperature is less than 80 Fahrenheit the car feels more responsive and powerful. I wanna go dyno the car in a few months ideally in november-december to see how it runs.
Hotter IAT (Intake Air Temp) = Less power
Fix- Increase intercooler water pump timing
Turbocharger/Intercooler Cooling System Heat is one of the worst enemies for a turbocharger system and precautions need to be taken to prevent the turbocharger from constantly being overheated. Lexus has developed a dedicated turbocharger and intercooler cooling system that is separate from the engine cooling system. This system has its own radiator, electric water pump and reservoir. The ECM varies the pump motor speed based on various inputs in order to achieve an optimal coolant flow rate. The turbocharger/intercooler cooling system makes sure that the system stays at the right temperatures. If the turbocharger is constantly overheated, oil coking and turbocharger bearing failure may occur. The capacity of this system is 3.1 quarts of SLLC.
There is our RX200T dyno test with stage 1 tune IAT/boost value/Ignition timing ........Automatic correction value.ve
Ignition
About Chinese word please try to use this more easier
Engine RPM......RPM
Intake temperature........degree C
Boost request value .........kpa(Absolute pressure)
Boost actual value.............kpa(Absolute pressure)
Ignition timing.............BTDC degree
41-39C
65-45C
Ignition
Engine RPM......RPM
41-39C
65-45C
Ignition
Engine RPM......RPM
41-39C
https://youtu.be/BjdETyFicX0
65-45C
https://youtu.be/2RAWhBGdBoI
Ignition
Engine RPM......RPM
41-39C
65-45C
It looks like intake temperature is a huge factor. Reminds me of VW, they're very fickle. I did some dynojet runs and saw a 20 whp fluctuation between my 1st and 6th run. Initially outside temp was about 95 degrees, by the time we completed all 6 runs it was 98 degrees not to mention the heat soaked engine and intake temp. Tony is having a look at the dyno sheets now
