IS200t tune
It confuses my why the car feels livelier but is running slower, but maybe its all in my head (placebo effect). I'm trying to run logs but the data logger keeps crashing and closing once I connect to the car. I also tried re-flashing the car incase I did something wrong the first time, but def. says successful at the end of the process. I also tried re-downloading the data logger and rebooting my computer but it still crashes as soon as I connect to the car. At this point I don't think it makes sense to even dyno the car until it actually runs a better time. I will send OVTune a message about the logger crashing but I'm feeling pretty bummed at this point
I also wanted to add that the gearbox is still shifting at about 5800rpms in both Sport and Normal, and fuel/ignition cut is still at about 6200rpms. The paddles don't respond as quickly as they did on my GTI so I have to send the request at around 5800 rpms to get the shift at 6200 rpms or I'll bounce the limiter.
Really unsure why you are seeing slower times, but i think the shifting is the issue. We are still working on this part because some cars will not shift at the higher limiter even when we set it to. So on our current files we retain the stock limiter and it should automatically shift for you at about 6000
Edit** due to some TCU issues, the current update files will remain with the stock limiter for now.
.Had the same problem with the logger. Running program compatibility fixed it for me
From May 1rst to May 12th we were down for a major software update, and update to the tune.
Now that this is all complete, 1.01 version G is the final release version. We are working this week to get ALL files on this version. This will be the last update for a while until our next patch, but that's not expected until later this year.
We apologize for the delays through this point, we tried to push these updates out as quickly as we can to get the car where we want it, and now we finally have it (as you can see with our latest results).
After looking over the car, they felt as if it would not be cost effective to do a custom kit. They will be doing some research on the turbo to see if it can be modified for more power.
I will post the info they provide once I hear back. They mostly do builds for Audi, Porsche, BMW, Mercedes, Lamborghini, and Ferrari. Hoping they can come up with something for this platform.
Larger fuel injectors would also be needed. This entire setup with the right tune will put the car right at the 300whp mark.
If anyone is interested in this, let me know and I can see if they would be willing to do some sort of group purchasing discount.
Great news......so you’re saying I’ll get the tune this week?
I've used OV's tune for close to a month and a half now and have used TTi's tune for almost a year. I've driven both tunes on spirited mountain runs, bumper to bumper traffic, and pretty much everything in between.
TTi has better low- and mid- range grunt (until maybe 2500-3000 rpm) and snappier shifting. The transmission is more eager to downshift in auto mode, too.
OV has better pedal response and absolute top end power, helped in a big way by raising the rev limit, which TTi could never do. However, you can get pretty deep in the accelerator in auto mode, and it still wouldn't downshift. This could be confined to the NX's 6AT and inapplicable to the IS's 8AT.
OV has posted recently that their latest update should improve the 2500-3000 range, though I'm not sure when that will start trickling out to customers.
