IS200t tune
Old May 14, 2018 | 08:38 PM
  #2971
Nuke's Avatar
Nuke
Originally Posted by Sheddy
Got the JB4 bluetooth connector so i can monitor readings, perform data logs and change maps on the fly.
Now thats Nifty
Old May 14, 2018 | 09:19 PM
  #2972
Sheddy's Avatar
Sheddy
Originally Posted by Nuke
Now thats Nifty
The final product will be a very sophisticated plug and play tune. It will have a fail safe program that would switch back to the stock settings if a reading is too high/off and also a CEL code reader. It is still not a re-flash, but will be the best alternative for some.
Old May 14, 2018 | 09:20 PM
  #2973
Nuke's Avatar
Nuke
I agree for what you pay this is really nice package
Old May 15, 2018 | 07:09 AM
  #2974
PATCHEZ's Avatar
PATCHEZ
im super excited for this!!! Any idea on how much it will be to upgrade?
Old May 15, 2018 | 08:18 AM
  #2975
Sheddy's Avatar
Sheddy
Based on the Infiniti Q50/60 pricing it should be $100 for the JB4 upgrade for existing Stage 1 customers and $479 for the JB4 standalone kit. Data cable is an additional $35 (laptop) and bluetooth adapter (mobile) is $140. Again we are only in the testing stage, so no definite release on this product.
Old May 15, 2018 | 11:20 AM
  #2976
PATCHEZ's Avatar
PATCHEZ
not bad at all!
Old May 15, 2018 | 01:26 PM
  #2977
E46CT's Avatar
E46CT
I believe the delay was an attempt to keep the 0-60 times higher compared to the 350/300 “ who needs the more expensive worse on gas car when they can get the 200t
you might think of that cause i was the first to think of and mention that coast to coast
Old May 15, 2018 | 05:07 PM
  #2978
PATCHEZ's Avatar
PATCHEZ
lol wasn’t sure who said it but makes makes sooooooo much sense
Old May 15, 2018 | 08:13 PM
  #2979
Sheddy's Avatar
Sheddy
Terry and I have been doing some more testing and we noticed that when you press the pedal down its only opening throttle to around 84% but once you press down further at the "kick down" point then opens throttle to 100%. He was able to make an update to allow 100% without hitting the kickdown on the JB4.
Old May 16, 2018 | 04:55 AM
  #2980
WhyHateTho's Avatar
WhyHateTho
Before my is200t I had a 335i, this is exciting news.
Old May 16, 2018 | 08:20 PM
  #2981
Sheddy's Avatar
Sheddy
Nice, so you are well aware of how good BMS products are.
Old May 16, 2018 | 08:39 PM
  #2982
E46CT's Avatar
E46CT
I always wondered if the car made full power right before kick down. interesting.
So far in your testing, does the JB4 prototype make more max power and under the curve? Or is it more of a safety thing?
Does it run richer or the same afr wise?
Old May 17, 2018 | 08:00 AM
  #2983
Sheddy's Avatar
Sheddy
From our discovery the kick down is necessary for 100% pedal. As of now i am running a stacked tune (re-flash and BMS), but i do not want to add more than 2 PSI on top since i am still running 93oct (pump fuel). I plan on reverting to the stock tune this weekend and just do testing on the JB4 system. I don't expect to make as high numbers as the TTI re-flash on pump gas, but definitely more power under the curve with the use of higher octane fuel (E30 mix) since the JB4 reads engine's parameters for safe useage. I do think that the ability to adjust boost per engine speed on the JB4 would help make more top end power as well.
Old May 18, 2018 | 07:02 PM
  #2984
Sheddy's Avatar
Sheddy
Old May 20, 2018 | 08:25 PM
  #2985
E46CT's Avatar
E46CT
Anyone know what that horn looking thing right on top of the airbox is? couldnt figure it out the other day... the actual horns are behind the bumper (two of them) and the alarm chirp is behind the cowl on the drivers side somewhere... can't for the life of me figure out that that device is.
