IS200t tune
Old Feb 27, 2020 | 03:45 PM
  #4471
Thirst16's Avatar
Thirst16
Originally Posted by Miintt
I’m really curious why they stopped offering the tune. I’m glad I got mine when I did.
I asked Matt about an ETA for the big turbo and he told me that they stopped working on the project for now to focus on other things.
I wonder if they’re dropping the Lexus platform altogether.
This wouldn’t surprise me. Even RR Racing has shelved their 8AR-FTS efforts for a while. I think the reality is that there just isn’t enough demand for this platform. It’s a great car but it’s not really suppose to be a “fast” car. You can’t just flash a tune and have the same gains you would with BMW, Audi, and VW. It’s intended for a different market. Lexus stands for reliability and that’s what they were going for. I, like most of us on here, really wanted this platform to push some good numbers. I’ve come to terms with the fact that if it’s power I want, I need to switch cars which I plan to do this fall. But still, I think both the IS and the RC are great cars and would love to see the return of the ISF one day with a twin turbo I6. That would bring me running back to the brand.
Old Feb 28, 2020 | 03:45 PM
  #4472
jaycedog's Avatar
jaycedog
I had a tuning box for my IS 200T and it definitely made a difference in performance. However, I do think that many posters here are right; the car isn’t made to be fast. The timing box made more of a difference in the torque department.
Old Mar 2, 2020 | 07:34 PM
  #4473
tnilc's Avatar
tnilc
I want to dyno my RC but not sure if I should wait on another tune from OVT after sending them a data log with all parts installed.
Old Mar 2, 2020 | 09:46 PM
  #4474
Is200tnc's Avatar
Is200tnc
Has anyone reached out to tti motorsports usa about their tune? Their site is showing unavailable as well. They created a "hybrid"turbo for the is200t at 1 time and have the tune to go with it. Not sure if they plan on releasing another one or not.
Old Mar 2, 2020 | 09:47 PM
  #4475
Is200tnc's Avatar
Is200tnc
Originally Posted by idleninjaz
Okay so I've sent in a data log on 2/11 and received a new tune with throttle response adjustments on 2/16. After a few days of driving, it definitely feels more alive and eager to move on re-acceleration. I'll probably be doing another data log to see if any fine tuning can be done.
what are you using to data log with? I need to do the same as i am testing some things for another company and need some info to send in.
Old Mar 3, 2020 | 06:37 PM
  #4476
idleninjaz's Avatar
idleninjaz
The one supplied by OVTune
Old Mar 3, 2020 | 07:15 PM
  #4477
Is200tnc's Avatar
Is200tnc
gotch . Dont have their tune so im looking for other data logger to use. Thanks.
Old Mar 7, 2020 | 02:05 PM
  #4478
NikNikNik's Avatar
NikNikNik
2018+ tune rr racing update
Old Mar 8, 2020 | 06:18 PM
  #4479
Minitech's Avatar
Minitech
I have emailed Matt myself to see if he can send me a 1.02 revision. i too did try the learned idle sequence using the OV p5flash utility (reset LV, and reset AT, then, start the car, let it idle for 15 minutes without doing anything no ac) but still no luck, I am still getting code P0505 Idle Air Control System. Has anyone had to replace the vacuum regulator valve for this code recently? I know they go bad, but i do not set a fault with 1.01g-c so i think its just an issue the 1.02 tune file.
Old Mar 8, 2020 | 07:28 PM
  #4480
tnilc's Avatar
tnilc
How did you read your P0505 code? Have you gone back to stock and is the CEL still there?
I had a P0001 code with my tune, I used a cheap Harbor Freight reader but when I went to a Lexus Specialized shop, the code was actually a P0137 for my downstream O2 sensor. Turned out my sensor had become loose. If you haven't already, I'd get the CEL read by a shop with TechStream to make sure it's the correct code. I had to replace my vacuum regulator but it did not cause any CELs.
Old Mar 9, 2020 | 07:34 AM
  #4481
Thirst16's Avatar
Thirst16
Very different from what I was told on the phone. However, I have a 2016 so maybe the newer models will release first. I really hope RR sticks with it. They are our only hope for a tune that actually works.
Old Mar 9, 2020 | 08:16 AM
  #4482
Minitech's Avatar
Minitech
Thanks, @Thirst16 yeah I actually have a cracked version of Techstream but i scanned it with both P5flash (the one that Matt gives with the OV set up) and a Innova scan tool. I agree the cheap scanners can be wrong, i might check it again with TechStream to be sure if it pops the same code. So far no it never triggers on stock or with tune 1.01G-C only triggers with the higher boost tune 1.02.
Old Mar 10, 2020 | 06:54 AM
  #4483
paulmantis's Avatar
paulmantis
Default IS200T OV TUNE 1.02 demonstration
had a lot of people ask how the tune performs for our cars, so decided to make a quick video
Old Mar 10, 2020 | 09:28 AM
  #4484
jaycedog's Avatar
jaycedog
I personally like tuning boxes better simply because of the fact I know I can easily remove it and leave no trace.
Old Mar 10, 2020 | 09:59 AM
  #4485
Thirst16's Avatar
Thirst16
https://vimeo.com/396580676
I see you are running 1.02. Most of the things I have seen so far is that this version has several issues. Have you experienced any of these issues and if so, how were they resolved?
