NX - 2nd Gen (2022-current)
Wireless charging not working
Old Jan 14, 2022 | 10:00 AM
DeftLexus's Avatar
DeftLexus
Default Wireless charging not working
Any of you experiencing issues with the wireless charging pad?
​​​​​​Issue:
Does not charge. Mechanical sound coming from wireless pad when phone is trying to charge.
Devices:
Note10+
Razer Phone 2
Old Jan 14, 2022 | 10:30 AM
chumpchang's Avatar
chumpchang
​​​​​​Issue:
Devices:
Note10+
Razer Phone 2
mechanical sound is the fan under the charger engaging.
Do you have a case on your phone? Are you experiencing this while using android auto navigation?
Old Jan 14, 2022 | 11:52 AM
DeftLexus's Avatar
DeftLexus
No phone case. With and without android auto.
Old Jan 14, 2022 | 06:46 PM
Esuric86's Avatar
Esuric86
I've had problems with it as well but today, no problems.
Old Jan 14, 2022 | 07:19 PM
Jawnathin's Avatar
Jawnathin
I have an iPhone 12 Pro Max. It only works when my phone doesn’t have a case on. With a case on it does not reliability charge. I’ve tried different four cases including two Apple cases.
Old Jan 15, 2022 | 05:30 PM
jalewis's Avatar
jalewis
5th Gear
It doesn’t work on my 350h either. I have an iPhone 12. Try it with case on, case off, turn it around on the charging pad… no matter what, it charges for maybe a minute and then stops. Can’t get it to stay charging no matter what I try. Really frustrating.
Also having the problem of the driver profile not loading about half the time when I get in. Forced to go through the prompts and put in the PIN. And I’m the only driver/profile.
Those are the only two major bugs I’ve found so far. Everything else is working great.
Old Jan 15, 2022 | 07:18 PM
chumpchang's Avatar
chumpchang
I've found that if you're using Apple CarPlay navigation (any of them, Waze, Google Maps, Apple Maps) that it warms up your phone pretty quickly while you're charging it. The Qi Wireless charger is rated to stop charging the phone once it hits 95 degrees Fahrenheit.
As for the Driver Profile not loading, try waiting 10-15 seconds before you put the car in Drive. It's most likely still loading your profile from your Digital Key and starting it in Drive will cancel it. Perhaps Lexus should look into a way where the car will continue to load the profile while in motion.
Old Jan 15, 2022 | 07:35 PM
RXWes's Avatar
RXWes
Question
What happens if you can’t load the profile? Is the car still drivable? You just don’t have your presets and favorites.
Or
Will the car not move till you have gone through the security check?
Old Jan 15, 2022 | 07:47 PM
jalewis's Avatar
jalewis
5th Gear
Rxwes: its drivable, it just doesn’t load your presets/favorites/etc. Runs as guest.
Chump: thanks for the tips. I’ll see if leaving CarPlay off from the start will allow it to sustain a charge. And I have tried waiting the 10-15 seconds before putting in drive for the profile load… didn’t make a difference for me.
Old Jan 19, 2022 | 06:24 PM
miggyt1's Avatar
miggyt1
Interesting. I was wondering what that noise was. I too think it's just fickle about where the phone is placed. I notice it's about 50/50. It's been very cold since I took delivery. I don't think there was a day that it's been over 45 yet.
Old Jan 20, 2022 | 04:37 AM
Pharbor's Avatar
Pharbor
I had a wireless connection problem yesterday. My phone said it was connected but the car didn't agree, and the charge kept connecting and disconnecting. I had to reboot my phone and the car and then everything started to work again, clearly an initial release event.
Old Jan 20, 2022 | 11:13 AM
925CA's Avatar
925CA
Default Wireless charger doesn’t work
My Lexus NX 2022 350h wireless charger does not work with IPhone 13 Pro and IPhone 12 mini with Apple case. Charges for 30sec then blinks and stops charging. Works without case.
Also charger does not have any switch to turn it on or off. It is always On but does not work.
Old Jan 20, 2022 | 12:29 PM
chumpchang's Avatar
chumpchang
does this happen when you’re running CarPlay as well? It seems as if running multiple CarPlay apps like navigation and music will cause the phone to reach the thermal limits of 95 degrees pretty quickly.
this is by design
Old Jan 20, 2022 | 12:59 PM
Jawnathin's Avatar
Jawnathin
Yep, just push the charging tray in if you don’t want to use it.
Old Jan 20, 2022 | 02:21 PM
925CA's Avatar
925CA
this is by design
It looks like it is hardware issue not related to CarPlay. I also noticed charging does not work when phone is turned off.
