Engine Movement
Old Nov 3, 2017 | 12:21 PM
johnnyg66's Avatar
johnnyg66
Default Engine Movement
Trying to see if this is too much motor movement. Anyone think this is normal amount? Are do the mounts need replacement??
Old Nov 3, 2017 | 12:50 PM
sha4000's Avatar
sha4000
I don't think that's alot of movement. If the mounts are original they could be bad depending on how the PO drove the car. When I changed the mounts on my 400 the engine moved just like yours.
Old Nov 3, 2017 | 01:56 PM
JLAWS's Avatar
JLAWS
You are suppose to put it in drive and reverse and observe the movement going in and out of gear and also give it a little gas while holding the brake. Does it feel like it slams into park or drive? If so the mounts might be bad. I've never changed mine. I hope it is not as bad as a 2GS 400/430 where you hardly had room to get to them.
Old Nov 3, 2017 | 02:43 PM
comotiger's Avatar
comotiger
Very clean engine bay
Old Nov 3, 2017 | 03:05 PM
Doublebase's Avatar
Doublebase
Looks fine to me but it'd be better if you put it in drive and held the brake, then gave it gas.
Old Nov 3, 2017 | 03:54 PM
johnnyg66's Avatar
johnnyg66
Thanks. I didn't remember to do it that way. I will have to try that next. I am thinking they are fine some info i read say after so many years its good to replace them. Its 10 years old now.
Old Nov 3, 2017 | 03:55 PM
johnnyg66's Avatar
johnnyg66
Smile
Thanks. I try.
Old Nov 5, 2017 | 06:58 AM
mckellyb's Avatar
mckellyb
Unless they're broken, or worse, you hear/feel something hit something else when you accelerate, I'd not worry about them.
Old Nov 5, 2017 | 07:05 AM
Looks totally normal to me
98GS430
Oct 9, 2022 06:04 PM
hypervish
RX - 1st Gen (1999-2003)
Nov 9, 2013 06:49 AM
98GS430
Northeast
Jul 31, 2008 08:39 PM
hyperopt
Sep 7, 2004 09:16 PM
Lexozz
Oct 17, 2002 02:14 PM
