projector retrofit questiones!
Old Jan 17, 2009 | 08:54 PM
optionii's Avatar
optionii
Default projector retrofit questiones!
Hi guys, I have seen couple guys here have installed Nissan Q45(cima) projector on zenki ls430, and it looks great. I was wondering how hard is it to do? and anyone offer retrofit service? Oh, and does anyone make a clear lens for 01-03 ls430 headlight? thanks!!
Old Jan 18, 2009 | 04:36 PM
optionii's Avatar
optionii
no one can help me?
Old Jan 19, 2009 | 07:59 AM
ELL Y's Avatar
ELL Y
Try HIDPlanet to get some ideas, being that I'm unfamiliar with the LS430. I was under the impression that the LS430/460s are some of the best HID projectors around, perhaps with a lens swap, but perhaps I am wrong.
People who offer retrofit services usually charge several hundred for labor alone, and that's assuming that you have all the parts for a retrofit already.
Old Jan 19, 2009 | 08:13 AM
So Philly1's Avatar
So Philly1
Check this link for cheap parts
http://www.eliteautostyle.com/products/lighting.htm
Old Jan 19, 2009 | 08:56 AM
bonafyd's Avatar
bonafyd
Here ya go www.lightwerkz.net www.retro-solutions.com
Any good retro fitter is gonna charge a lil grip but it's worth it since you don't want leaks or fogging.
Old Jan 19, 2009 | 10:17 AM
GS3Tek's Avatar
GS3Tek
I'll take the LS430 projectors over the LS460 any day for brightness factor.
The 460 and the Q45 have the cool factor, but not as bright.
As a matter of fact, I'm going to put the LS430 projector in my sienna.
There's lots of threads on retrofitting. Put in "retrofit" in the lighting section and also the 2GS section since it's a very common thing to do.
Here's a quick run down on what it takes to retrofit:
1. Heat up the headlight in oven to remove the cap.
2. Shaving of the chrome bezel/housing might be needed for clearance. This
is the most time consuming/labor intensive part.
Not sure how much room the 01-03 has. If you're lucky, you might not
to shave much.
3. Mount the headlight onto the bowl, possibly allowing the autolevel to still work. Be careful not scratching the chrome housings along the way.
4. Make sure alignment is proper.
4. When everthing is A-OK, Put headlight back in oven to reseal.
Sounds easy enough but wait until you do it
Just to give you an idea, it took me about 4 weekends, Saturday and Sunday about 3-4 hours each night since I took my time.
This must be the inspiration, right???
Old Jan 19, 2009 | 11:44 AM
gs eddy's Avatar
gs eddy
Racinstyles is usually the inspiration. aint he?... just be warned, Racinstyle is a baller/auto madman. He aint the type to just rock some wheels and some suspension and be cool with it. He's those cats that sends their **** away for months at a time till it's just right. you know? and then sends it away again for the interior. it takes alot of effort as well as $$$ to get your ***** like that^^^. good luck....
Old Jan 19, 2009 | 12:44 PM
So Philly1's Avatar
So Philly1
^^ Aint that the truth!!!!
Old Jan 19, 2009 | 04:46 PM
optionii's Avatar
optionii
Thanks you guys! I have done some retrofitting before, so I am going to find a pair q45 projector for cheaper and try it out. I don't think I am ever going to be on the same level as Racinstyles, maybe just a little bit! haha
Spyder78
Mar 29, 2014 10:33 PM
IronCobra
Lighting
Dec 29, 2010 10:34 AM
LiCelsior
Lighting
Dec 27, 2009 12:50 AM
URDONE
43
Oct 8, 2008 07:31 AM
Kaluna
Lighting
18
May 30, 2008 12:19 AM
