Sponsored by: CARiD
RX 300 clear corners... help
Old Feb 6, 2002 | 07:27 PM
spinteews's Avatar
spinteews
Default clear corners... help
ok guys.. i need help now
I just got my clear corners from ebay...
I wanna install it but got no idea...
i think last time i read that you have to go under the wheel well and then stick your hand in and pull it out... but i'm not sure... any help would be very useful.. thanks guys
Old Feb 7, 2002 | 10:04 AM
hleo1's Avatar
hleo1
Spinteews,
Yes, you're right! You just need like a flat (-) screwdriver to gently open up the fender flares. Stick your hand inside to unscrew the bolt inside, becareful not to loose/drop the screw as you loosen it. The driver side should be very easy to do. The passenger side can be more challenging, esp if you have a big hand. There's like a water pump located close to the passenger side corners, so it can be hard to remove the screw from inside.
Be patient, do it slowly, I'm sure you'll get it done... I have already done it...
good luck!
Hendry
Old Feb 7, 2002 | 01:54 PM
spinteews's Avatar
spinteews
cool thanks, i'll try that when i go purchase my bulbs
which bulbs did you get for those?
i was thinking of the polarg m2's i think or m4 one of those
the b1hybrid ones
Old Feb 7, 2002 | 05:27 PM
hleo1's Avatar
hleo1
Hello,
I used a standard yellow bulb for those clear corners. I still want them to have yellow light, 'cause I don't want to risk having problem with the police. I just don't like the yellow lenses. So at night when it's on, it's still yellow, but when it's off, it's clear...
Old Feb 7, 2002 | 07:16 PM
01VaporBlueRX's Avatar
01VaporBlueRX
Can you post some pictures of the Clear bumper lights please Hleo1? Thank you.
Old Feb 8, 2002 | 07:32 AM
hleo1's Avatar
hleo1
Here are the pictures I promised...
Old Feb 8, 2002 | 07:35 AM
hleo1's Avatar
hleo1
Another one from the side...
Old Feb 12, 2002 | 06:16 AM
malhokc's Avatar
malhokc
spinteews,
WHat brand are those clear corners.
Old Feb 12, 2002 | 08:22 AM
DJ SprinklesNJO's Avatar
DJ SprinklesNJO
ahhhh you got the rod millen grill, very nice. i love that grill. was it hard to install. how about painting it. what color did it originaly come in?
Old Feb 12, 2002 | 09:57 AM
spinteews's Avatar
spinteews
not much of a brand... i'm at work now but when i get home i'll check...
i got it from autobac on ebay... they sell plenty of em...
later on if i do decide to change my rear ones also i'll prob bid on it again
Old Feb 12, 2002 | 11:02 AM
hleo1's Avatar
hleo1
DJ,
Thanks! Yes, I love the RMM grill too... It's made of polyurethane (wrong spelling???) black color, not fiberglass. The Lexus white color is very hard to match, so I took off the lower side of the grill from the car, give it to the bodyshop, so they can try to match the color as best possible. Install was not hard, the mesh grill was also provided to cover behind it, and the emblem is also provided, since different size than original...
Old Feb 12, 2002 | 06:20 PM
PlanetAudioRX's Avatar
PlanetAudioRX
I also bought the clear corners off "autobacs." but i had a question to the one person that did install them..
How long did the installation for both sides take?
Old Feb 12, 2002 | 06:24 PM
PlanetAudioRX
INSTALLATION ON THE REAR SIDE MARKERS?
Would the installation be like the installation for the front clear corners? Where you would use the screw driver to get under it?
Old Feb 12, 2002 | 07:07 PM
hleo1's Avatar
hleo1
just use a screwdriver to kind of pry up under the wheel fender flares... Then you should be able to slide your hand and reach the back of the clear coners to unloose the screw.
The driver side was very easy to do, probably less than 10 minutes. The passenger side is more difficult, since there's the water pump (don't know exact term to use) that gets in the way... need more patience... took me like almost 20 minutes 30 minutes....
I don't know if the back corner lens is the exact same size and fit as the fronts... anyone knows?
Old Feb 12, 2002 | 07:57 PM
PlanetAudioRX
wHEN YOU SAY SLIP IN WITH SCREW DRIVER, DO YOU MEAN UNDER THE BUMPER, OR LIKE THE SIDE OF THE FENDER FLARE?
