Tires
Old Feb 21, 2025 | 09:50 AM
  #496
fodalo's Avatar
fodalo
Wont hurt to ppf those rockers if not already. Will help on any kick up sand road dirt with the wider wheel base in play.
Old Mar 14, 2025 | 02:23 PM
  #497
Spyder14's Avatar
Spyder14
I apologize if it previously stated but I can not find what the OEM tires were on a 2021 with the Touring package. I am looking at one now that has relatively new Bridgestones on it but can not see the date codes or model of the tire. Thank you for your help.
Old Mar 14, 2025 | 04:52 PM
  #498
np20412's Avatar
np20412
245/40 and 275/35 if it came with 21"
245/45 and 275/40 if it came with 20"
Old Mar 16, 2025 | 07:08 AM
  #499
Spyder14's Avatar
Spyder14
Thanks--if it came with the Touring Package, what would the model of Bridgestone's be? My dealer is not being very responsive re: which Bridgestone's they installed when servicing the car for sale.
Old Mar 16, 2025 | 07:24 AM
  #500
Barncobob's Avatar
Barncobob
maybe look at used cars of the year with low mileage to find ur answer,
Old Mar 16, 2025 | 06:06 PM
  #501
fodalo's Avatar
fodalo
When they wear out, NRF's Michelin Pilot 4S or AS
Old Mar 20, 2025 | 09:00 AM
  #502
rmbrewer's Avatar
rmbrewer
My 2023 came w Bridgestone Potenzas S001L . Good tires, but I bought wider Vossens and put on Michelin AS.
Rob
Old Mar 20, 2025 | 10:20 AM
  #503
Spyder14's Avatar
Spyder14
Thank you for the details!
Old Mar 20, 2025 | 11:46 AM
  #504
LCIncline's Avatar
LCIncline
My 2021 came with Bridgestone Potenzas S001L as well. They are run flats. Saved me when I hit a nasty pothole, though would recommend the Michelin's as well.
What I noticed is that the tire pressure on the Bridgestones roses much faster vs. the Michelin's when driving. Might be a side effect of the run flat sidewalls.
Old Mar 21, 2025 | 06:31 AM
  #505
xwndycty's Avatar
xwndycty
My 2023 cabrio came with Bridgestone Potenza run flat's, too. With less than 8K miles on the clock, I've had to replace two of the four already...right rear tire had a nail in the sidewall (that couldn't be repaired ) and two weeks ago the right front tire 'exploded' when I hit a 6-inch-deep pothole @ 65 MPH in the middle travel lane of I-40 in Durham, NC. Thank God the 21" wheel was OK (Lexus told me a replacement is $4K) and the only thing needed was a replacement tire + front end alignment. I'm seriously considering swapping out the run flats for Michelins later this Summer (and getting a spare tire kit).
Old May 8, 2025 | 01:03 PM
  #506
rmbrewer's Avatar
rmbrewer
Are the Michelin Primacy Tours subpar? I'm looking for all-season non-runflat tires for my MY2023 OEM wheels, and they are the only ones I have found.
-Rob
Old May 8, 2025 | 03:08 PM
  #507
400Mman's Avatar
400Mman
Originally Posted by rmbrewer
My 2023 came w Bridgestone Potenzas S001L . Good tires, but I replaced w Michelin AS.
Rob
In your opinion what improved going from the Bridgestone to the Michelin?
Old May 8, 2025 | 03:26 PM
  #508
fodalo's Avatar
fodalo
For me a quieter tire AS4's, Longer wear time.
Old May 8, 2025 | 03:34 PM
  #509
doncoughlinjd's Avatar
doncoughlinjd
-Rob
I wondered the same thing. A while back, I noticed a Canadian forum member installed them. I wonder if he'll see this and comment how he has fared. The only difference I could discern is that the Primacy only has a "V" speed rating (up to 149mph) and since the max LC mph is 168, they won't be listed by any tire manufacturer for it.
But my question is since I won't be driving over 100mph, does it matter? The only other choice is installing the wrong size front tire (255s) which I know a lot of guys do without any trouble. However my Lexus Dealer refuses to sell 255s to me. They say I'm on my own if there is a transmission, odometer, speedometer, etc warranty problem.
P S I have a 2024 LC with 21" wheels, but I just noticed you have a 2023 with maybe 20" wheels? So you would have more choices?
Old May 8, 2025 | 04:18 PM
  #510
400Mman's Avatar
400Mman
Definitely positive attributes. Better ride quality?
