Tires
Old Aug 8, 2022 | 06:43 AM
  #346
RysLC500's Avatar
RysLC500
Originally Posted by wfw
I'm new to this forum; just bought a 2022 LC 500 convertible. I have a couple of comments/questions regarding the tire discussion.
My understanding is that once a RF tire is used without air pressure (running flat), it should be replaced regardless of where the puncture is located, if it was driven on for any distance. This is because, even though the tire allowed for limping home, it has been over stressed due to operating without air pressure support and may have suffered internal structural damage to the point of compromising safety. So, does anyone have experience with a Lexus dealership repairing a punctured RFT?
Regarding changing the tire OD for the front tires, wouldn't that affect the speedometer or possibly the electronic stability control?
Thank you, I'm already learning a lot on this forum.
I would just take it to a tire store you trust to take a look. I doubt the dealership has any special knowledge. Actually probably have less knowledge since they aren't a tire shop. My Benz's all had RF's and I usually replaced them with NON-RF's like many in this forum. Unless you are driving places without cell service or great distances then NON-RF's are the way to go.
Old Aug 8, 2022 | 08:18 AM
  #347
MLMLC52K18's Avatar
MLMLC52K18
No reputable shop wants to deal with the liability associated with repairing a RF tire. If you want to fix it, assuming that the tire didn't go below recommended pressure levels, you more than likely will have to DIY and assume the risk.
Old Aug 8, 2022 | 12:12 PM
  #348
wfw's Avatar
wfw
Based on this thread, I'm leaning toward replacing my RFTs with regular tires once these wear out.
Old Aug 8, 2022 | 01:23 PM
  #349
RysLC500's Avatar
RysLC500
Good idea. I had 13k on my RF's and the dealership told me I needed them replaced. I called BS and have almost at 17k and they are fine. Don't let them motivate you to replace them too soon. I seem to find tire shops are getting more and more aggressive with "making" people replace tires too soon. I live in Arizona so granted I don't need a ton of tread. I just don't drive in wet weather.
Old Feb 15, 2023 | 09:59 PM
  #350
NiceCars's Avatar
NiceCars
What are the 22 and 23’s coming with on the touring pkg? While looking for a 23 I seem to always find the B-stones. Personally I prefer Michelins but I did have potenzas that came on a new at the time Carrera S and they were pretty good. Have the Dunlop’s been discontinued for the LC or are they for the 20” wheels only. Not a fan of D’s, they came on my both my XKR’s and immediately replaced them with Pilots…night/day difference. The Jags are conventional not RF’s.
Going from a RF to non will help with a softer/smoother ride, none of the typical crashing sensation over bumps and will help with handling due to less unsprung weight. My choice would be the PS4’s in summer form.
Old Feb 16, 2023 | 06:51 AM
  #351
RysLC500's Avatar
RysLC500
Why did you move from a Carrera S to a LC?
Old Feb 17, 2023 | 05:32 AM
  #352
BruceinFla's Avatar
BruceinFla
Originally Posted by MLMLC52K18
Don't think the dealer will ever repair a RF tire. Replace only.....I caught a nail in mine and plugged it myself even tho I wasn't supposed to. But in my case, tire never lost pressure and No subsequent problems with tire.
I don't know where you all are getting this incorrect info from. At least if the tire Has Not been driven while totally flat, Discount Tire, a Huge tire dealer, will have no issue repairing a puncture in a RFT as long as the puncture is in the usually repairable puncture area. They certainly did it just fine for me.
Now. I did catch the puncture Right At the First lowER pressure warning and Did keep the air pressure up using a mini pump and they're certainly was no other damage to the tire other than the puncture.
It is very unusual for a tire to Blow Out without being low pressured for sometime. They most often blow out from the increased Heat from the low pressure Not from the puncture itself. The LC will usually alert you to a Low tire in Plenty of time for you to air it up.
I also don't believe Fodalo's statement that Most of us are switching to non RFs. I'm pretty sure he can't back that up.
Bruce in Fl
Old Feb 17, 2023 | 08:15 AM
  #353
MLMLC52K18's Avatar
MLMLC52K18
Hey man…..Don’t shoot the messenger…..Its not just me .….Under certain conditions RF’s can be repaired….Reread previous posters who’ve commented on this similar issue…..And even tho you can’t believe everything on the internet, Mr Google has said the same a million times be it rite or wrong. There are always 2 sides to a issue. I fixed mine, Discount fixed yours....Consider yourself blessed.
Old Feb 17, 2023 | 07:46 PM
  #354
huh? you wrote: No reputable shop wants to deal with the liability associated with repairing a RF tire.
so you're not just a messenger. as bruce points out, reputable shops like Discount Tire can and will repair a RF tire, no problem.
anyway, glad you were able to fix yours yourself. I'd rather drop by my local friendly discount tire! they fix flats for free.
Old Feb 17, 2023 | 09:08 PM
  #355
MLMLC52K18's Avatar
MLMLC52K18
Sorry….That’s just the way I was raised…..Maybe it's a man thang….But I’ve never asked anyone to fix anything for me that I could fix myself…..I know you glad that somebody will do you for free.....
Old Feb 18, 2023 | 05:27 AM
  #356
BruceinFla's Avatar
BruceinFla
I doubt Most of us have a tire changer bolted to our garage floor.
I have plugged a tire on the side of the road and banked my life on that plugged motorcycle tire because I had to to get home. That's Not in the same Galaxy of Safety as having the dealer Remove the tire from the rim and use a combo patch/plug.
You were Partially correct. No reputable dealer is just gonna stick a gummy worm plug in your $100k car tire and send you on your happy way.
Bruce in Fl
Old Feb 18, 2023 | 06:24 AM
  #357
MLMLC52K18's Avatar
MLMLC52K18
.....You make an excellent point….Plugging is never the preferred method to repair any tire.....But for some industry specialists, repairing a RF tire isn’t either....
Old Feb 18, 2023 | 06:56 AM
  #358
BruceinFla's Avatar
BruceinFla
Show me those Specialists please.
The Specialist For My Tire agrees with Me under the low air conditions I already stated.
Bruce in Fl
Old Feb 18, 2023 | 08:20 AM
  #359
MLMLC52K18's Avatar
MLMLC52K18
Hey B…., I have no plan to keep going back & forth with you…..You have access to the Internet just like me…..Google it….Reading is Fundamental.....
Old Feb 24, 2023 | 04:57 PM
  #360
NiceCars's Avatar
NiceCars
C2S was years back, going from M850 to LC
