Tires
Old Feb 19, 2025 | 06:25 PM
  #481
Enzo954's Avatar
Enzo954
Originally Posted by Timado404
I personally didn't feel like it was worth the coilovers, all I do is drive it to get groceries, lol. There is a lot less body roll when going hard through a corner. That's without a doubt an improvement over how it took corners before. I totally disagree with these ruining the ride, I haven't experienced anything like that. The ride is still VERY comfortable, even in Sport+. If anything I actually wish it was a bit stiffer ride. When I dropped my Maserati on springs there was a huge difference in the ride, that got WAAAAY stiffer. Lexus ride comfort is just a thing, and these springs don't bother that, at all on my 2018.
A few more questions and I'll leave you alone. LOL
Do you feel like lowering it caused any issues with speed bumps or inclined/declined driveways?
I assume you're still able to change how the suspension behaves to a certain degree when changing the drive modes because you essentially only had the springs changed, correct?
Have you considered spacers? I've seen a few photos and when lowered the wheels look extremely tucked into the body. Maybe it was just the angles of the photos.
Thanks!
Old Feb 19, 2025 | 06:55 PM
  #482
np20412's Avatar
np20412
Thanks!
I can help on the last one.. Here's before and after spacers once lowered. 20mm all around.
FWIW I don't have any trouble in Florida on my Springs, the tein drop is 1.25" front and 1" rear. I think RSR may be a hair lower overall.
Old Feb 19, 2025 | 07:48 PM
  #483
Enzo954's Avatar
Enzo954
Looks good. What brand spacers did you get?
Old Feb 19, 2025 | 07:58 PM
  #484
np20412's Avatar
np20412
Adaptec speedware... Got them from https://www.motorsport-tech.com/spec...jrxqxbFdkE1F_M
Old Feb 19, 2025 | 08:24 PM
  #485
Enzo954's Avatar
Enzo954
There are 4 different designs. Which is the correct one?
Old Feb 19, 2025 | 08:26 PM
  #486
Sundriver's Avatar
Sundriver
Veteran: Air Force
np, which design is best and what is the determining factor(s)? TIA
Old Feb 19, 2025 | 08:29 PM
  #487
np20412's Avatar
np20412
Therea re 4 different designs. Which is the correct one?
For 2024+ you would need design 2 with longer lug bolts. Other LC that use traditional lug nuts should use design 3, where the spacers attach to existing studs using the lugnuts they'll supply, then wheel attaches to the studs on the spacer with the factory lug nuts.
Old Feb 19, 2025 | 08:34 PM
  #488
Sundriver's Avatar
Sundriver
Veteran: Air Force
... your LC is very impressive!
Old Feb 20, 2025 | 05:47 AM
  #489
Timado404's Avatar
Timado404
Veteran: Marine Corps
Thanks!
Fire away with the questions, not a prob for me. 👌🏾
Yes, only springs. I have zero issues with speed bumps of any size, no scrapping. My driveway is very level with the street so no issues there, either. I installed the 15mm Akata AK-W series spacers, all around. $86/pair. Car rides as smooth as it did when stock.
Old Feb 20, 2025 | 05:53 AM
  #490
Timado404's Avatar
Timado404
It was 5 hours labor plus shop supplies so got dinged for almost $1000 install, including the post install alignment. I didn't shop around much but the lowest quote I got was $750, the highest was $1800.
My boys here in ATL got me for $1,100.00 on the install, (Butler in Buckhead), and had the car all day.
Old Feb 20, 2025 | 05:58 AM
  #491
Timado404's Avatar
Timado404
My 2018 I went with the 15mm Akata AK-W series,(studded). They're on sale now for $86/pair.
https://www.akataspacer.com/default....Lexus&model=LC
Old Feb 20, 2025 | 06:01 AM
  #492
np20412's Avatar
np20412
My 2018 I went with the 15mm Akata AK-W series,(studded), the ones you're talking about that mount onto the cars studs. And yes they supply the nuts that attach it to the car. They're on sale now for $86/pair.
Akata is definitely a good brand and that's a great price! I see they have the S-series in stock now too (this would be for 24+). They were out of stock when I bought mine but glad to see there are more options for newer model year owners!
Old Feb 20, 2025 | 07:46 AM
  #493
Enzo954's Avatar
Enzo954
Why 15mm over 20mm?
Old Feb 20, 2025 | 07:50 AM
  #494
Timado404's Avatar
Timado404
Old Feb 20, 2025 | 07:51 AM
  #495
Timado404's Avatar
Timado404
Why 15mm over 20mm?
Have a buddy in North GA. that went 15mm on his LC, looked good to me so that was my point of reference. That was the only reason.
