Any special features I should know about?
Old Mar 15, 2019 | 04:32 AM
Dizordered's Avatar
Dizordered
The little stick handle on the left side of the steering wheel is to activate the flasher... up to go right and down to go left. Many people ignore that this function exist in every car! But Lexus makes it better, they added a lane-change function to that stick handle. Hit it half way and it blinks only 3 times!! WOW!!! LOLLLL joke aside....
I don't know if this wiper feature is considered as a hidden feature. So there are 4 levels on the handle: manual (hit up), intermittent (with sensitivity switch), continuous and fast. When wipers are in continuous mode and car is stopped, wipers will slow down their rhythm if sensitivity switch is not at the highest level. When sensitivity switch is at highest level, wipers will not slow down even if car is stopped.
Old Mar 15, 2019 | 07:53 AM
dojoman's Avatar
dojoman
Another hidden feature most people probably don't know is there's a padding between the seat and center armrest where people tend to drop stuff like keys, phone and coins. The padding prevent things going down the gap.
Old Mar 15, 2019 | 08:08 AM
JDR76's Avatar
JDR76
One of the things I really liked on my IS was that there is a grab/pull handle on the inside of the trunk. You can grab on to this to shut the trunk, so you don't have to fingerprint the outside anywhere. It's the little things...
Old Mar 15, 2019 | 06:14 PM
HOMER350's Avatar
HOMER350
While in drive mode (including eco, normal, sport) you can use paddle shifters for a quick shift up or down.
Helpful for hitting passing gear real quick or to lower rpms when sport mode has me stuck at 4500rpm.
Itll remain in that gear until you press the accelerator for 4 continuous seconds.
Old Mar 15, 2019 | 09:14 PM
pngo's Avatar
pngo
I was wondering how to do this! I had it set to such on accident before, but didn’t know how. Thanks
Old Mar 15, 2019 | 09:47 PM
dojoman's Avatar
dojoman
I set mine to blink 5 times instead of default 3. Max is 7 blinks it can be change with Carista app with ODB dongle or dealer can change with a fee.
Old Mar 15, 2019 | 09:51 PM
dojoman's Avatar
dojoman
You can actually get out of manual mode by pulling and hold Up shifter for 3 sec and transmission will go back to auto. I don’t believe this was in the manual. This only works only in Drive mode.
Old Mar 16, 2019 | 12:51 AM
pngo's Avatar
pngo
You can also follow these steps to do it yourself manually:
https://www.clublexus.com/forums/is-...me-change.html
Old Mar 16, 2019 | 03:08 PM
CarlitoIS's Avatar
CarlitoIS
Menu to rewind and pause radio is hidden until you click this arrow.
That's pretty cool. Does it work for Sirius XM as well? I rarely use the AM/FM radio.
Old Mar 16, 2019 | 06:26 PM
dojoman's Avatar
dojoman
Only for FM/AM.
Old Mar 17, 2019 | 09:21 AM
NickCaesar's Avatar
NickCaesar
yup! I use to drop stuff outta my pockets constantly in between the seat in my old Rx350... I discovered these padding’s first day and it’s something so simple I don’t get why every car doesn’t have it
simplecar
RX - 1st Gen (1999-2003)
Oct 26, 2018 04:24 PM
HappyUp
NX - 1st Gen (2015-2021)
Sep 24, 2018 02:15 PM
250aznboi
Jan 15, 2008 10:00 AM
silkiechic
Apr 1, 2007 03:57 PM
Petrie2001
Sep 15, 2006 12:52 PM
