I recently found out how to lock the doors by touching the handle. Before I only knew how to unlock the doors. I'm not sure if this is common knowledge or not.
The electronic key must be nearby (e.g. in your pocket).
At the upper part of the handle there is a notch, that's the lock sensor,
touching that should enable the door locks.
You can also speak commands via the speak button on the steering wheel. Example, press the button and after the beep say “I am cold” and it will automatically warm it up via the climate control. You could also say “I am hot” and it will do just the opposite, or “I am hungry” and it will pull up restaurants near by via the navigation if so equipped.
Hold unlock to roll all windows down. Almost all Lexus have this feature, but many owners are still unaware. On the 3rd gen IS, it is off by default because of people complaining, so you need to enable the function at the dealer/techstream/carista.
I wish there was a way to hold down lock to lock all the windows with the remote though.
Thinking I wasn't going to learn anything as I thought I knew all the features. You proved me wrong and I'm going to try that tomorrow. lol Thank you. Another not really hidden feature is when you connect your phone you could get texts read aloud to you. Although alot of people knew that im sure there are those who are still learning. Also if you lock your car using the lock sensor on the handle, and left your keys in the car. It wont lock and will let you know by making a noise and informing you on the dash. Happened to me once lol.
It won’t lock with them in the trunk either... don’t ask. 😅
Another feature I use quite often when traveling, as part of the Enform subscription, if you press the sos button at the upper/moonroof console, you can have them send directions to your navigation system to anywhere or anything you’re wanting to find. An example, I was looking for a particular sporting good store, I told them the name and found three in that city and sent directions to the nearest one. Never had to take my eyes off the road or pull over to input the information manually. Likewise, they can connect you to hotels or even book as well.
I thought the SOS button was just for emergencies?
