RX450h Mileage Thread
Very cold or very hot outside temperatures do degrade the efficiency of internal combustion engines. So, I would suspect some of the reduction in fuel economy experienced in hot weather is due to the ICE. For example, the electric-operated radiator cooling fan works much harder in very hot weather.
As an experiment, a couple weeks ago I took an approximately 15 mile R/T (on essentially level ground on city streets) in the early afternoon on a very hot day. My 450h was parked outside and the cabin was quite warm when I started the vehicle. It did not take long for the ICE to reach normal operating temperature. The indicated MPG for the first five miles was not great. However, after the interior cabin cooled to a pleasant 72 degrees, the indicated MPG began to rise dramatically. When I got home, I parked the car in our garage which was more than 15 degrees cooler than the outside temperature..
An hour later, I repeated the same trip. The outside temperature was about the same as the first trip. The indicated MPG for the second trip was much higher than for the first trip.
I’m averaging 11-12 L/100km on 2016 RX350 which is the same until 2022
Edit: for what it’s worth, I do use premium fuel in the 450. Simply my choice to follow the manufacturer’s recommendation.
If you are going by a realworld 25mpg for the 450h, then what 350 stat are you comparing to? It shouldn't be the EPA 27hwy. It should be also the real world 19-20mpg. So that's still a big 25% difference in fuel savings (not to mention an extension in max range).
Next the hybrid mpg is going to vary based on your driving habits and not solely just the driving style.
The hybrid will often achieve the EPA ratings and it's easier to meet them. Beyond the usual lead foot stuff, since city vs hwy mpg is about the same, you are shielded from the poor city mpg, I don't think that is not really where the mpg discrepancy comes from.
Where I found a hidden part of mpg will be greatly affected is initial startup as it will run the engine to attempt to quickly get it up to temp and ready to go for emissions purposes, even if battery is available.
So if you are a short tripper, you will get worse mileage than advertised... e.g
drive 10miles, off for several hours, 10miles on, several hours off. If you did this for 200miles you'd get much worse mpg compared to if you did the exact same route with 15min stops
. Maybe warmups are a big factor in canada that gets you to that 25mpg on the 450h.
That being said, you'll also see a mpg hit the 350 side as well with this driving pattern will probably drop the 350's mpg wrll below 20. This driving pattern actually is best suited for a phev or ev where you can be all electric
However, if you aren't driving that much, the short trip mpg doesn't matter in your tco, your long drives will hopefully make the majority of your miles.
The rest of the Canada lower mpg you cited I cannot explain, you can look on fuellly to get a better survey of real world mpg from mostly US users is around 28-29mpg for the 450h and 19-20 for the 350.
The only other idea I have for a factor in canada other than warmup probably is winter/ 3pmsf tires or rolling resistance/roads taking some mpg, but this would also something that hits the 350.
https://www.clublexus.com/forums/hyb...ml#post9049237
https://www.clublexus.com/forums/hyb...rt-2-cost.html
So far with the hesitation issues the 350 has been experiencing, I am glad I went with the 450h. Although I passed it to my parents and am now driving a different beast.
32.8 mpg calculated. The RX said 31.5 mpg. Filled up with Sam's Club Premium 93 Octane
Fast forward to now, we've been driving 2022 RX450h for just about one year. Bought it brand new, and first 3-4 tanks we had approximately 26-26.5mpg in mixed driving. Now it's average of 28-28.5mpg again in mixed driving. We use premium fuel only, never filled it up with regular. On all-highway trips we get 26.5-27.5mph, haven't done all-town trips yet, but I noticed that it's sweetest spot is driving on FM roads at around 40-55mph with minimum amount of stops. I mostly drive in normal mode, except in residential areas where speed limit is 25-30mph with frequent stop signs and lights, then I switch to Eco mode. I use Sport mode exclusively on highways when passing or when hard merge is required. While we haven't hit 30mpg (average tank that is, we've seen plenty of 30+mpg but overall per tank it's never gotten above 28.7mpg yet), we are aware that it is an older hybrid system and it's mated with the NA 3.5L V6 which is one of the biggest reasons we decided to get this RX before the switch to turbo-4s. Overall we're very happy with it so far and we plan to keep it for a long time if it proves to be reliable.
