Hybrid Technology Unique topics related to the 2016 up RX450h model hybrid drivetrain and other features/options found only on the RX450h. Please use the main forum for discussion about shared components with other fourth generation RX models.
RX450h Mileage Thread
Old Dec 23, 2024 | 05:12 AM
  #466
nitalice's Avatar
nitalice
Originally Posted by CVG
I have a 2022 RX 450H and have never seen anything over 26. I drive in the ECO mode.
I have never got any good mileage in eco mode. Usually normal or even sport mode gave me a better mileage especially if I could use “push and pull” strategy. It helped me to utilize the coasting drive which allowed the electric motor to generate electricity from the wheels' rotation.
Old Dec 30, 2024 | 08:43 AM
  #467
jollick's Avatar
jollick
2020 RX450h fill up at 19,461 miles 12/26/24. Traveled 359.5 miles, 66% local. Weather mostly 40F to 50F.
The RX said 28.9 mpg. Filled up by Lexus due to repairing a recall.
Old Dec 31, 2024 | 03:29 AM
  #468
CVG's Avatar
CVG
Originally Posted by TechNut
How are you calculating this? You cannot rely on the dash as it is notoriously optimistic by about 1.5 or 2 MPG. Also, the dash needs to be reset and cleared for each tank in order for it to even get close.
As to techniques for driving a hybrid in order to maximize your mileage, there are numerous threads here and in many other forums for maximizing your fuel economy. I recommend you do a search here to locate those discussions. The best single recommendation I can give you is the “pulse and glide technique”. Just drive normally (but not in a spirited/aggressive) manner up to a few miles above the speed you desire, then relax the throttle just a bit to get the EV mode to engage, and then apply just enough pressure on the throttle to maintain speed. This obviously only works at speeds up to 35 mph, and shouldn’t be used in heavy traffic or with following traffic as you don’t want to be one of those “nuisance” hybrid owners. Also keep in mind, this technique only works in stop&go city traffic so if your driving is predominately higher speed or highway, you won’t do much better that the 27.3 you described above. Cold weather driving also hurts the city mileage as the vehicle has to run the internal combustion engine more/longer to maintain heat. At highway speeds it will run the ICE continuously anyway.
What is meant by :At highway speeds it will run the ICE continuously anyway."?
Old Jan 1, 2025 | 02:56 PM
  #469
TechNut's Avatar
TechNut
Veteran: Navy
When you are driving at speeds above 55MPH (what I consider “highway speeds”), the internal combustion engine never shuts off. This is in contrast to city/neighborhoods where the hybrid will shut the ICE down if you aren’t pushing it, or as you approach a stop. The street leading to my neighborhood is posted at 25 and if I’m gentle on the throttle, I can do most of it (except for taking off from the stop sign) on just the electric motor - EV mode. This street is about 1.5 miles long and level. I have seen this behavior up to about 35 MPH as long as I’m gentle with the throttle and not heading uphill. I hope that clarifies my previous comment, which is normal for every hybrid I have owned?
Old Feb 10, 2025 | 03:13 PM
  #470
jollick's Avatar
jollick
2020 RX450h fill up at 19,824 miles 2/10/25. Traveled 361.1 miles, 100% local. Weather mostly 40F to 75F.
28.8 mpg calculated. The RX said 28.7 mpg. Filled up with Sam's Club Premium 93 Octane.
Old Feb 20, 2025 | 04:03 PM
  #471
LiBeRtAs's Avatar
LiBeRtAs
2022 Lexus NX 350 H here, trying to find the best advice on how to maximize charging the hybrid battery. I seem to rarely get it past four bars but I am always trying to get the best mileage with pulse and glide etc. Would love to hear any tips.
Old Feb 21, 2025 | 08:47 AM
  #472
jollick's Avatar
jollick
From all I have read, the Lexus hybrid system is designed to charge to about 85%. This is to extend battery longevity. If you have a total of 5 bars, you may never see the 5th light up. This has been my experience on my HS, ES and now RX hybrids.
Old Mar 24, 2025 | 01:37 PM
  #473
jollick's Avatar
jollick
2020 RX450h fill up at 20,236 miles 3/24/25. Traveled 411.3 miles, 100% local. Weather mostly 55F to 70F.
30.0 mpg calculated. The RX said 29.9 mpg. Filled up with Sam's Club Premium 93 Octane.
Old Apr 24, 2025 | 07:41 AM
  #474
jollick's Avatar
jollick
2020 RX450h fill up at,20,636 miles 4/23/25. Traveled 400.7 miles, 100% local. Weather mostly 65F to 85F.
31.5 mpg calculated. The RX said 31.4 mpg. Filled up with Sam's Club Premium 93 Octane.
Old May 15, 2025 | 02:08 PM
  #475
jollick's Avatar
jollick
2020 RX450h fill up at,21016 miles 5/15/25. Traveled 379.1 miles, 100% local. Weather mostly 65F to 85F.
30.3 mpg calculated. The RX said 30.9 mpg. Filled up with Sam's Club Premium 93 Octane.
Old Jun 11, 2025 | 02:32 PM
  #476
jollick's Avatar
jollick
2020 RX450h fill up at 21,410 miles 6/11/25. Traveled 394.8 miles, 100% local. Weather mostly 75F to 90F.
31.4 mpg calculated. The RX said 30.7 mpg. Filled up with Sam's Club Premium 93 Octane.
Old Jul 24, 2025 | 12:20 PM
  #477
jollick's Avatar
jollick
2020 RX450h fill up at 21,822 miles 7/22/25. Traveled 411.1 miles, 100% local. Weather mostly 80F to 95F.
30.0 mpg calculated. The RX said 29.8 mpg. Filled up with Sam's Club Premium 93 Octane.
Old Aug 18, 2025 | 11:47 AM
  #478
jollick's Avatar
jollick
2020 RX450h fill up at 22,194 miles 8/9/25. Traveled 372.6.miles, 100% local. Weather mostly 90F to 100F
28.8 mpg calculated. The RX said 27.9 mpg. Filled up with Sam's Club Premium 93 Octane.
2020 RX450h fill up at 22,455 miles 8/13/25. Traveled 261 miles, 100% highway 60 to 75 mph. Weather mostly 90F to 100F.
26.9 mpg calculated. The RX said 26.8 mpg. Filled up with Sam's Club Premium 93 Octane.
2020 RX450h fill up at 22,713 miles 8/16/25. Traveled 257.9 miles, 100% highway 60 to 75 mph. Weather mostly 90F to 100F
25.7 mpg calculated. The RX said 25.9 mpg. Filled up with Sam's Club Premium 93 Octane.
2020 RX450h fill up at 23,032 miles 8/26/25. Traveled 318.7 miles, 80% highway 60 to 75 mph. Weather mostly 90F to 100F
27.4 mpg calculated. The RX said 27.7 mpg. Filled up with Sam's Club Premium 93 Octane.
The RX450h does not provide as good mpg when driving 70-75 mph in 90-100 degree weather.
Old Sep 22, 2025 | 02:34 PM
  #479
jollick's Avatar
jollick
2020 RX450h fill up at 23,391 miles 9/22/25. Traveled 359.6 miles, 85% local. Weather mostly 80F to 85F.
29.7 mpg calculated. The RX said 29.6 mpg. Filled up with Sam's Club Premium 93 Octane.
Old Oct 30, 2025 | 06:08 AM
  #480
jollick's Avatar
jollick
2020 RX450h fill up at 23,749 miles 10/28/25. Traveled 359.6 miles, 85% local. Weather mostly 50F to 65F.
29.3 mpg calculated. The RX said 29.8 mpg. Filled up with Sam's Club Premium 93 Octane.
