Tesla Syle Headunit
Old Aug 19, 2019 | 03:11 PM
  #136
verly6565's Avatar
verly6565
do you have pics of your unit and harness
Old Aug 19, 2019 | 03:41 PM
  #137
MX73's Avatar
MX73
Originally Posted by Token1
Sorry not installed yet. I just unboxed it yesterday but didn't have time to install. Will likely put it in this coming weekend. It came with a lot of adapter harnesses and a canbus decoder box + android "DVD" (but apparently Android Auto/Apple Carplay) converter box thing.
Excited for Android Auto- I had it in a rental and I liked it.
I'm actually disappointed with android auto. It's very laggy when you have nav and any streaming music on at the same time. Carplay is awesome though. It won't be the full screen since Android auto or carplay are not built for the vertical screen. Carplay will fill the screen but it gets laggy like the android auto. Have to change the setting for Carplay to not auto-launch and set the dongle to compatibility mode for it to work normally.
Let us know the specs. I see that the PX6 units are out on aliexpress. It could be a fake but you never know.
Old Aug 25, 2019 | 02:53 PM
  #138
Token1's Avatar
Token1
Update:. The bad.
Hazards does not work
Rear camera does not work (this really peeves me)
Aux in is so weak it's worthless
Rear speakers seem to work? I get music in the speakers in the rear doors and the rear OEM sub under the rear window bumps, but when you use the balance feature to shift all the music to the back the music just drops off.
Canbus decoder box was included, it also has a two lead harness to be plugged into the OBD2 plug- not sure what it is getting from this, I guess other canbus data.
The OEM gps (I'm assuming) antenna is not used but instead theirs. Too bad. There is an un-used OEM harness and I can't help but wonder if that is for the backup camera
There are some flying leads in the aftermarket harness, maybe for aftermarket speaker installs?
The not so bad:
Easy to change C to F, and I do get temp not just high/low, and duel seems to work
Little bit of learning curve, climate is not intuitive
Settings I changed to North America radio and it scanned automatically
Gotta update the boot image, it's a cheesy lambo
Pending checks:
Android auto box thing
Get within WiFi range to setup Google account band update maps and apps
Old Aug 25, 2019 | 03:39 PM
  #139
verly6565's Avatar
verly6565
whar year gs is yours
Old Aug 25, 2019 | 03:49 PM
  #140
Token1's Avatar
Token1
Crap, I keep coming to the wrong thread lol, I have a 2006 IS250.
Old Aug 25, 2019 | 04:31 PM
  #141
MX73's Avatar
MX73
Does your IS have Nav? I believe they ofter an adapter\harness that fixes the Hazard button.
Old Aug 26, 2019 | 01:45 AM
  #142
PewieM's Avatar
PewieM
I would be cautious about the Chinese tactics/marketing. Remember about my findings from here https://www.clublexus.com/forums/gs-...#post10383686?
So to see if there really is a newer gen model with faster CPU and stuff, need someone with it to run AIDA64 and post a screenshot for me to see. I wouldn't mind upgrading my current tesla head unit, since it's pretty slow to me and boots up very slow (sucks when I need to adjust A/C right when car turns on, but have to wait for the head unit to fully boot up first, lol).
After looking at aliexpress for the PX6 units, I see they say its Android 8.0, so the AIDA64 should say API level 26 or above, which I highly doubt.
Old Aug 26, 2019 | 07:54 AM
  #143
Token1's Avatar
Token1
I'll try this when I get some decent wifi. The home screen has a big PX6 in the radio graphic.
I really hope so, I have an email out to Rhino
Old Aug 27, 2019 | 12:32 AM
  #144
Token1's Avatar
Token1
Seems legit this time, or they upped their spoofing game, I donno.
Old Aug 27, 2019 | 12:52 AM
  #145
PewieM's Avatar
PewieM
Maybe they up their spoofing game, can you try one more thing to see if it's really Android 8.1. Try this, https://www.androidpolice.com/2017/1...topus-remains/
If it shows that correctly, then I guess it's really Android Oreo. Also, can you take a picture of the SYSTEM tab and CPU tab of the head unit from AIDA64, I want to see if it's really updated CPU and 4GB of correct ram (sometimes they spoof the ram too).
Lastly, how long does it take for you to boot the head unit? With the older head unit model, it takes me about 40 seconds or so before I can start touching the screen.
Old Aug 27, 2019 | 10:38 AM
  #146
Token1's Avatar
Token1
Posted here:
https://www.clublexus.com/forums/is-...xus-is-15.html
Takes about 8 seconds to boot, can time it later or even vid of it.
Old Aug 27, 2019 | 10:46 PM
  #147
Token1's Avatar
Token1
Old Aug 28, 2019 | 02:42 AM
  #148
PewieM's Avatar
PewieM
Thanks for the updates @Token1. Seems like they are going more legit now and not trying to scam with fake android versions. Now I will most likely upgrade mine, cause mine is the old px3 version and it's extremely too laggy for me.
Question, do you know if your unit has 5ghz wifi? Or does it still only connect to 2.4ghz wifi only?
Old Aug 28, 2019 | 06:40 AM
  #149
MX73's Avatar
MX73
Damn. I'm tempted to upgrade mine as well.
Old Aug 28, 2019 | 07:37 AM
  #150
Token1's Avatar
Token1
Good question... I think I can specify my hotspot to be just one or the other so I'll try with that.
The boot thing is interesting as a member in the IS specific thread of this topic recently bought an Alibaba supplied unit (not sure if px3 or the new one) and he has zero bootup, zero. Sounds to me like there is either a hidden setting or a firmware out there that keeps the unit in some sleep mode instead of turning it off.
On my unit there was a "run background processes" I turned on, but it did not affect the boot up- maybe just lets more apps stay in RAM and be snappier vs. aggressively clearing memory.
I've installed screen filter to dim the screen better and Waze because dark mode with google maps is not working on this unit (freshly updated the app too...). Hopefully the next update fixes this. But with screen filter I can't actually get into the app, I tap it and the screen fades a bit, but there isn't a way to change settings. Worse yet, it does not seem to start on boot, one has to manually enable it every startup. So I'll be looking for yet another screen dimming app. Maybe one of the flying leads is for an illumination input.
Almost seems like a FAQ could be made from these multiple threads on these units and complimentary mods to shore up their short comings. Lots of info out there in this regard. I will be much happier with the unit if it just had a few shortcomings, not a laundry list haha
