Tesla Syle Headunit
Old Oct 4, 2019 | 03:32 PM
  #196
cobraBLACK's Avatar
cobraBLACK
When I told the Chinese seller the unit randomly mutes itself they sent me a video showing me how to use the random playback button!
They have been almost zero help.
Old Oct 4, 2019 | 03:49 PM
  #197
ShannonT's Avatar
ShannonT
Did you try setting the brake sensor to “off” or “no”. I don’t recall the specific designation.
Old Oct 7, 2019 | 06:28 AM
  #198
cobraBLACK's Avatar
cobraBLACK
What does that do?
Old Oct 7, 2019 | 06:29 PM
  #199
hien331's Avatar
hien331
Originally Posted by Kton
this is great. I hope a software update comes to the PX3 units.
How is the PX6? fast? snappy?
I had the px6 and it was nothing but problems. I don’t know about fast since the damn unit freezes everyday. Usually in the morning. It’ll change sources on it own then freeze. When it works, it’s great! Good thing the seller was cool and refunded my money. I love the way it look but I can’t be resetting the radio everyday. So I went and modded my old unit to fit a pioneer double din.
Old Oct 7, 2019 | 08:32 PM
  #200
Great77's Avatar
Great77
Do you have pics of the double din install?
Old Oct 7, 2019 | 08:34 PM
  #201
hien331's Avatar
hien331
https://www.clublexus.com/forums/gs-...n-install.html
Old Oct 15, 2019 | 04:00 PM
  #202
Superveloc's Avatar
Superveloc
Does anyone have an mcu update file for the 3GS rockchip unit they can upload for my reference? My unit is marked (zxw 860b) and does NOT have the two physical *****. I've made some improvements to the stock 4.4 rom that was sent to me from the manufacturer (debloat, root, google apps removed, tweaked touch sensitivity, sysctl.conf, build.prop etc.). Looking for the stock mcu image so I can have a better understanding of how this unit functions.
The idea behind these units is fantastic but they lack processing power. The low RAM situation isnt a big deal, 2GB is enough once when gapps are removed. It's the read and write speed to internal storage which is a problem. I ran the same benchmark on a POCO F1 and Galaxy S10+ to have something to compare to, and the phones are posting read and write speeds at least 10x higher than my unit with the rkpx3 2/64 board. Minimizing writes to disk, not having google services and other pointless background tasks seems to have improved the responsiveness and performance of the unit somewhat, but returns are diminishing.
Old Oct 23, 2019 | 09:22 AM
  #203
cobraBLACK's Avatar
cobraBLACK
Apparently the engineers are looking into my problem. They asked for a video of it happening but I can't trigger it - it just does it occasionally.
I might try leaving BT off so my phone is not connected and see what happens.
Other than that, running the CarWebGuru launcher makes for a much better experience and Poweramp is the best music player I've tried (although it needs some tweaks for in-car use).
I can't get Poweramp to launch on boot yet (best is several seconds after the home screen starts) but it's just one manual click from home.
ES File Explorer (despite its annoyances and ban from Play Store) is still the best. I've tried several others and they're either feature-light in comparison or buggy.
Old Oct 25, 2019 | 05:34 AM
  #204
cobraBLACK's Avatar
cobraBLACK
Nope. I turned off BT before getting in the car.but it muted almost immediately.
I doubt it'll make a difference but I'll try no internet next.
Old Oct 25, 2019 | 05:48 AM
  #205
cobraBLACK's Avatar
cobraBLACK
Has anyone experimented with USB devices?
First I tried a large SSD which it didn't recognize so I tried 32 GB SD cards. I bought two USB adaptors but it can only see one at a time. They definitely work individually on each USB cable, just not simultaneously. No big deal since there's plenty of internal memory but just annoying having two ports but only one being usable.
Old Jan 30, 2020 | 02:03 PM
  #206
ShannonT's Avatar
ShannonT
Default Anyone have a fix for the oil change notification on these units?
Just got an oil change and have no way to turn off the oil change alert
any suggestions!
Old Jan 30, 2020 | 07:45 PM
  #207
grdsman's Avatar
grdsman
any suggestions!
Without your foot on the brake, press the starter button twice until the idiot lights all come on. Make sure it is on ODO rather than trip. If so, turn it off. Press and HOLD the trip reset button and then press start twice to get back to the idiot lights. Keep holding reset until it comes up to 000000. You should be good now.
https://seventrumpet.com/reset-oil-m...2015-lexus-gs/
Mike
Old Jul 13, 2020 | 02:34 AM
  #208
bkcoughlin's Avatar
bkcoughlin
Originally Posted by jasons316
Can anyone help me?
I have the 10" Tesla style head unit, but have only just got around to buying a reversing camera. I have been able to test the camera by running the wires outside of the car, but can't for the life of me figure out how to route the wires from the trunk lid to the head unit.
I have a 2006 GS450H and there doesn't appear to be any obvious way to route through the hybrid battery compartment.
Has anyone done this themselves, and can offer some tips?
Thanks.
I have the exact same car. Did you ever have any luck with the rear camera install?
Thanks,
bk
Old Jul 13, 2020 | 05:42 AM
  #209
Kton's Avatar
Kton
Thanks,
bk
Its a pretty tough job. I routed through the roof liner ( Floor boards work as well) then had to take out the rear seats to remove the entire rear deck where the sunshade sits.
You don't have to remove the sunshade, but you do have to remove all the paneling. From there at the back where the rear window meets the bottom you're going to see holes. These route directly into the trunk.
To see where the holes pass through, you'll have to remove the top trunk liner and the lid liner. I routed the cable through the wire belt ( don't forget to give it enough slack) and took out the existing rear camera.
​​​​​​To place the new camera where the old one is will also be tricky. You're going to need some watertight material to prevent water from coming in. I rolled up two pieces of thick rubber foam and stuffed it into the side, and squeezed the wire between the gap of the two rolls. Because it was so packed, the friction was high enough that I didn't even need to screw anything in.
Good luck! I wish I had pictures
Old Jul 13, 2020 | 05:26 PM
  #210
bkcoughlin's Avatar
bkcoughlin
Thanks for the reply! That sounds like a huge pain in the ****. I’m still trying to figure out the OEM camera route for now, and then might have to look into a wireless one, as someone suggested above.
