Side Mirror Issue
Old Jul 29, 2010 | 01:19 PM
DarkknessD's Avatar
DarkknessD
Default Side Mirror Issue
Ok... so this is a very minor issue, but after a few weeks of dealing with it, it's getting a bit annoying.
The mirrors tilt down towards the ground when I put the car in reverse, which is exactly what they're suppose to do. Though a few weeks ago I noticed that the driver side mirror only tilts down maybe 1 degree or so, it hardly moves at all... while the passenger side mirror tilts all the way down then comes back to it's normal position.
When I manually move the mirror by using the controls it moves all around without issue, only when i put the car in reverse does it not tilt all the way down..
Is there any way to re-program or reset the mirros to start working properly?
Old Jul 29, 2010 | 01:23 PM
IXI187IXI's Avatar
IXI187IXI
there was just a thread on this. your mirror needs to be replaced because the gears are stripped. there is no way to replace the gears, you'll need a whole mirror.
Old Jul 29, 2010 | 01:35 PM
rominl's Avatar
rominl
exclusive matchup
https://www.clublexus.com/forums/gs-...e-problem.html
Old Jul 30, 2010 | 11:24 AM
DarkknessD's Avatar
DarkknessD
Hmmm... that would be a bit odd, because I can move the mirror all the way around using the drop down box controls. Only in reverse does it not move all the way down like it use to.
I'm starting to think that getting the extended warrenty may of been a good idea.
Old Jul 30, 2010 | 12:42 PM
IXI187IXI's Avatar
IXI187IXI
what year is your car? if its less than 4yrs old (from the manufactured date) and under 50k then the lexus warranty is still good.
Old Jul 31, 2010 | 03:11 PM
Modeler's Avatar
Modeler
My car just started having the same problem. I had a 2007 GS450h before that developed this problem two years into its life. Had both mirror assemblies replaced. Now looks like this one needs the same thing.
Old Jul 31, 2010 | 09:04 PM
mbasko's Avatar
mbasko
I had the same issue with my 2007 GS350 within the first year. Had the dealer replace both mirrors under warranty. No issues so far.
Old Aug 3, 2010 | 01:55 PM
DarkknessD's Avatar
DarkknessD
Unfortunately my car is 3 months out of it's warrenty.
You seem to be a regular on the boards... In your opinion is it worthwhile to get an extended warrenty?
Old Aug 3, 2010 | 02:26 PM
designo's Avatar
designo
Yup, same problem here. I am waiting for my mirrors to get here. They were not in stock.
Old Sep 5, 2010 | 08:34 AM
lexasgs400's Avatar
lexasgs400
Default mirror
Does the assembly come with the glass/ mirror also
b2884987
RX - 3rd Gen (2010-2015)
20
Nov 28, 2025 07:55 PM
Pearlpower
Sep 4, 2022 03:25 PM
Reggie1948
Jul 12, 2018 12:36 PM
varcity64
Jan 28, 2016 06:57 AM
minh
GS - 1st Gen (1993-1997)
Jun 8, 2004 09:16 AM
