Passenger side mirror won't hold its setting
Old Jul 10, 2018 | 09:46 AM
Reggie1948's Avatar
Reggie1948
Default Passenger side mirror won't hold its setting
Every time I engage the starter the passenger side mirror rotates to the far right. I then must adjust the setting by using the controls. When I place the vehicle in reverse, the mirror does tilt (as expected). I've re-set the setting numerous times, but to no avail. Any ideas to take care of this problem?
Old Jul 10, 2018 | 10:21 AM
salimshah's Avatar
salimshah
25 Year Member
Just to rule out the possibility that there could be an issue with he setting process ..
Use other set position and set the 'working' mirror at an odd angle and then store that setting. Manually change the 'working' mirror and then recall setting to confirm the working mirror goes to the odd setting.
Once the above verifies that the 'working' mirror can be reprogrammed and the offending mirror is the only problematic one ,,, you will have to check the wiring or replace the mirror with its sensors/motors etc. A tech may be able to narrow down the problem to an internal component, but usually the tech's labor will be more than the unit price and the failure may happen again [you may not be able to source the failing part too].
Salim
Old Jul 10, 2018 | 10:36 PM
N4TECguy's Avatar
N4TECguy
Have you switched keys recently? The keys can be programmed to a certain memory position. So, it's possible that it is recalling a memory position that you had used before on this key.
Old Jul 12, 2018 | 12:36 PM
Reggie1948's Avatar
Reggie1948
I haven't changed the keys to this vehicle. However, I'll look into the matter. Thanks for the suggestion.
Eh6174
Feb 5, 2023 03:20 AM
amillion
May 26, 2013 12:42 AM
JoeKuhn
Dec 29, 2012 03:09 PM
DarkknessD
Sep 5, 2010 08:34 AM
