Lexus human interface issues and climate control discussion
Old Feb 10, 2019 | 11:46 AM
  #151
I don’t get what you mean? It defaults to AC when you hit auto, then you are able to turn off AC
The system should automatically choose to turn the A/C compressor off if it’s true that the most efficient way to heat the cabin is to have the A/C compressor off. AFAIK the system never turns the compressor off, at least I’ve never known it to.
Old Feb 10, 2019 | 11:51 AM
  #152
southernx's Avatar
southernx
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away.
  #153
Perhaps, a modern Toyota does have this option. My 4Runner definitely does not turn off the AC. It specifically states in the manual the most efficient heating method is to have the AC off.
Old Feb 10, 2019 | 03:30 PM
  #154
tex2670's Avatar
tex2670
Just because it's the "most efficient heating method" doesn't mean that it's the most effective solution over all. In a snowy climate, when your boots are snow covered or wet when you get in the car, heating the car cabin isn't the only consideration. You want to keep the windows from getting fogged up. Turning off the A/C to heat the cabin quicker is not going to address this issue.
Old Feb 10, 2019 | 04:13 PM
  #155
So if it is not the best method. Why would Toyota say for best results? I didn’t say it. Toyota did. The whole thing is about the removal of the AC button, clearly the system works with the AC on or OFF. .
Old Feb 10, 2019 | 04:15 PM
  #156
They didn’t say it was the best method, they said it was the most efficient. Meaning it would make the car warm in the fastest way possible, which isn’t always the best way.
Old Feb 10, 2019 | 04:22 PM
  #157
Actually they clearly state. For Best Results.
Old Feb 10, 2019 | 04:53 PM
  #158
tex2670's Avatar
tex2670
What does it say about dehumidifying? Again, if you need to do more than just put out heat, then "best results" are relative.
Old Feb 10, 2019 | 04:57 PM
  #159
What does it say about dehumidifying? .
If you want to dehumidify heat, press A/C
Old Feb 10, 2019 | 05:05 PM
  #160
Done banging my head against the wall for the day.
Old Feb 10, 2019 | 05:06 PM
  #161
mmarshall's Avatar
I strongly recommend this for effective windshield defogging. If the A/C compressor is operated in the defog cycle without some added heat, the cold air from the compressor will chill down the windshield and cause moisture-condensation on the outside, which the wipers will then have to clear. Adding heat to the A/C, as Jill says, will dry out the inside air very rapidly, allowing it to effectively clear off and evaporate the moisture on the inside of the windshield. You don't have to add a lot of heat to the A/C in warm humid weather, which would make it uncomfortable for the occupants inside...just a little heat, or enough to do the job. But don't run full-cold A/C on the windshield to defog it..... that's just asking for trouble.
Old Feb 10, 2019 | 05:07 PM
  #162
To be fair, I’m the one who told Jill yesterday that the A/C compressor dehydrated the air. She didn’t know that until then, so let’s not give credit for ideas where they aren’t due lol
Old Feb 10, 2019 | 05:17 PM
  #163
Absolutely if you want to defog the window. But as stated by Toyota, for best results hearing, turn off heat. That is contrary to what others were saying
Old Feb 10, 2019 | 05:21 PM
  #164
mmarshall's Avatar
OK, no problem. I didn't notice that, but I'm not in competition with anybody here....no trying to be. We're all here to help and advise each other. In fact, that's why, years ago, the automakers started modifying the A/C systems to allow heat to be added to the cold air blowing out. When they first started linking the compressor-use to the defog/defrost mode, without the ability to add heat, people were ****ing-up the window glass with outside moisture-condensation. I remember that was a problem in my late Mom's old 1977 Plymouth Volare.....though the very definition of the Volare/Aspen was problems LOL.
What I'd like to see is the ability to vary not only the amount and intensity of air-flow through the vents, but also to be able, in warm humid summer weather, to direct warmed/A/C air through the defrost vents for defogging, and, at the same time, have cool air coming out at face-level, in the dash-vents, for driver/passenger comfort. . I don't know if you have that on your LS460 or not, but no car I've owned yet (including the Lacrosse) allows that. It's all the same temperature, no matter which vents you use.
Old Feb 10, 2019 | 05:30 PM
  #165
Curious to know, what does GM say on how to use your Lacrosse HVAC?
