Lexus human interface issues and climate control discussion
Old Feb 10, 2019 | 08:36 PM
  #181
Have you ever used remote touch?
yes, i thought it was horrible for two reasons...
1) i found it too easy to overshoot or ‘mis’-navigate
2) the controller/hand rest takes up way too much space.
the newer trackpad takes up less space, and i understand it’s better but i’ve not tried it.
Old Feb 10, 2019 | 08:37 PM
  #182
mmarshall's Avatar
So if you use windshield and floor vents, you can split the air temp in my vehicles. Is this what you mean?
No. I was referring to a warm defog/defrost and a cool dash/face-level. That is what you want in summer humidity.
Since Lexus is the thread-topic, that is one reason why I asked Steve if the LS460, manual or automatic climate-control, allowed that set-up.
Old Feb 10, 2019 | 08:41 PM
  #183
1. You have to adjust the feedback force up all the way, that dramatically reduces overshooting and mis-navigating. Out of the box its set to the lowest level with 5 levels in between.
2. This I agree with, it does take up a lot of space.
Old Feb 10, 2019 | 08:50 PM
  #184
up.
What cars go face/windshield for the hvac setting? Why would warm air on the windshield be useful in the summer?
Old Feb 10, 2019 | 08:53 PM
  #185
Warm air increases the evaporation rate of water and can absorb more humidity. What's most important is that it be dry air, which is why you need the A/C Compressor on.
Old Feb 10, 2019 | 09:00 PM
  #186
how often is this need in the summer? Whereas you need warm air on the windshield and cold air on front facing vents? So bizarre.
Old Feb 10, 2019 | 09:02 PM
  #187
mmarshall's Avatar
You live in upstate NY and Toronto.....not D.C.'s summer humidity, which, in comparison, is like a swamp. Steve can verify how muggy it gets here in the summer. It is extremely humid, with frequent thunderstorms, and sometimes doesn't drop below 70 (or even 75) degrees for weeks on end.
Old Feb 10, 2019 | 09:08 PM
  #188
we go through the same spells here.
Have you ever seen windshield/face vent on any car?
Old Feb 10, 2019 | 09:31 PM
  #189
mmarshall's Avatar
Not for the length of time we do.
Not the way I'd like it. But I'm not going to dwell on it any further.....there are a lot of things in vehicle-design that I think could be improved, but that probably won't happen. Not worth losing sleep over....life's too short.
Old Feb 10, 2019 | 09:47 PM
  #190
Not trying to annoy. I was just reading your lacrosse manual earlier. And it's states, any combination of the three floor, face or windshield can be selected. Never seen this on a Toyota
Old Feb 10, 2019 | 10:05 PM
  #191
mmarshall's Avatar
Thanks, but that's not what I was saying....I don't think you understood. Yes, air can be directed any one (or combo) of three ways.....but its temperature (or A/C content) cannot be varied from one set of vents to another. You get the same-temperature air flowing though any one of a combination of three vents.
Old Feb 10, 2019 | 10:08 PM
  #192
I understand now. At a bi-level it should work this way. For example, mid level on my cars, cool goes up to the windshield, while heat goes to the floor vents. Toyotas cannot do face flow and windshield from what I gather, so your Buick might. Does this make sense?
Old Feb 10, 2019 | 10:12 PM
  #193
mmarshall's Avatar
Yes, I've seen the floor-heat/dash-cool setting on some cars before, but not the warm-defrost/cool dash that I'm speaking of. Like I said, though, I can live without it....modern cars have spoiled us enough as it is.
Old Feb 10, 2019 | 10:15 PM
  #194
Ok. So give it a shot tomorrow and just look. Some Opel and Volvo models can do the spilt you are referring. Maybe you have an Easter egg you were not aware of.
Old Feb 11, 2019 | 05:24 AM
  #195
tex2670's Avatar
tex2670
If you want to dehumidify heat, press A/C
Which, in a car, is what you'd want to do most of the time. Hence, why the AUTO climate control turns the A/C on, leaving it for the driver--such as yourself--to override it, if desired.
