Build Threads Details on Club Lexus LS400 owner vehicles
LS400 Supercharger Project
Old Oct 21, 2007 | 02:02 PM
  #166
Ca12los69's Avatar
Ca12los69
Hey guys,
Video was to demonstrate low end torque. Even with big wheels and new tires on the back they will light up easily. On acceleration the car will take off without losing any traction.
I need to tune it ASAP. It is leaning out at about 3500 RPMs. I am sure I could hit 6 sec. 0-60 when it is tuned to about 12.0 @ WOT to redline. Maybe the regulator aint working right?? I am using the SMT6 piggyback, but I am having problems getting the car to run with it completely connected. Anybody have any experience with it???
Thanks.
Old Oct 21, 2007 | 03:54 PM
  #167
stevechumo's Avatar
stevechumo
Originally Posted by Ca12los69
Hey guys,
Thanks.
Nice...It could be the regulator or the FMU. If you tune it right at 6 or 7 psi and the traction is good, you can run in the mid 5 second from 0-60.
Old Nov 12, 2007 | 12:15 AM
  #168
Bill Dowd's Avatar
Bill Dowd
There is a lexus back east with a super charger running a 1000 horse power and the engine is running fine. The story is that the lexus motor is so strong you really don't have to rebuild the bottom end to put on a super charger. I would also run synthetic oil with a super charger giving more proctection to the motor. I also heard a story ( not sure how much truth it holds) that the lexus engine is the only car engine in the world that can be put into an airplane and is fully FAA passed.
Old Nov 12, 2007 | 02:17 AM
  #169
909LS's Avatar
909LS
it sounds like you probably need a bigger fuel pump i'm not sure what the LPH flow rate on the stock lexus fuel pump is? but where i work at we dyno tune a lot of different cars and lately thats been a common problem most of our honda customers come in with set up's that seem street fast but on the dyno thaty always run way lean we change out the fuel pump and that usually always solves the problem same thing with the nissan sr20 swap only on a sr20 you can tell the difference with the pump and w/o it. I recommend trying the Walbro 255 LPH thats what we use for the hondas and nissans works great!
Old Nov 12, 2007 | 02:27 AM
  #170
909LS's Avatar
909LS
oh yea and are you running an adjustable fuel pressure regulator?
Old Nov 12, 2007 | 02:38 AM
  #171
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
that hold somewhat true for the pre 95 (LS) and pre 97/98 (SC) and none of the GS4 motors, the first gen motors had much thicker rods.
Old Nov 12, 2007 | 11:42 AM
  #172
sonyman's Avatar
sonyman
1996 was the year that the SC400 received the revised motor, so it would be 1992-1995 for the SC400, 1990-1994 for the LS400.
Old Nov 12, 2007 | 11:54 AM
  #173
PureDrifter
BahHumBug
CL Folding 100,000
no, 95 for hte LS and 96 for the SC were when the heads were redesigned (became interference, know for a fact on the LS, pretty sure for the SC) and the rods were SLIGHTLY changed. big change in rods came with the VVTi motors.
Old Nov 12, 2007 | 12:33 PM
  #174
sonyman's Avatar
sonyman
That's what I was referring to. The only 1UZ-FE's with fat, overkill rods are the ones found in 1990-1994 LS400's and 1992-1995 SC400's. Also, I have yet to see a comparison of the lightened rods from 1995 LS400's (1996 SC400's) with the VVTi models. They may very well be very similar.
Old Nov 12, 2007 | 01:08 PM
  #175
PureDrifter
BahHumBug
CL Folding 100,000
ohh, i see what ur saying now, the SC4 got redesigned heads/rods in 96 instead of 95?
Old Nov 12, 2007 | 01:13 PM
  #176
sonyman's Avatar
sonyman
Yes.
I don't know why, but Lexus waited an extra year before updating the SC400.
Old Nov 12, 2007 | 05:13 PM
  #177
steveski's Avatar
steveski
Awesome to see an LS roasting the tires Wish mine could do that nice custom job bro
Old Nov 21, 2007 | 05:37 PM
  #178
stevechumo's Avatar
stevechumo
Originally Posted by sonyman
Yes.
There's a pro and con to this change. For a boosted SC400 with stock engine, the pre 92-95 is more preferrable due to their stronger beefy rods. They're less likely to break. The 96 SC400 somewhat gains a few more ponies, but with skinner rods.
Old Nov 21, 2007 | 06:08 PM
  #179
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
lol u guys should look at Carlos's other video....
Old Nov 28, 2007 | 02:55 PM
  #180
akxx's Avatar
akxx
Well, don't forget the Mooney PFM's (PFM=Porsche Flug Motor) which roughly translates to ''Porsche aircraft engine". While the aircooled porsche engines were already setup for flight use, they discontinued the model because them motors weren't cheap!
