View Full Version : Suspension and Brakes
- Replaced ps return hose and now it feels overboosted..
- Master-cylinder?
- Zeal coilovers
- Steering Problem
- Wheel Bearings Hub Assy.
- Suspension gurus need info and pics please! TEIN SS and D2s or CS
- Shave the rotors or upgrade?
- How much does your LS400 rotor weigh?
- stabilizer/sway bar link
- Front-end jerks and clunks when cold
- diagnosis needed
- Which way do the little blue strut dots point? (PICS)
- WTB: asap rear passenger suspension parts
- Did a brake job *pics*
- Help me to install LS400 calipers
- Clunk!?
- IS350 calipers on SC300/SC400?
- Brake lines are gone?
- Thinking of going on air
- Any toyota model brakes interchangable with Lexus SC400 Brakes?
- you guys will like this... unfortunately i dont
- Eibach or Tanabe springs?
- best riding springs
- Product Review: Prothane F&R LCA kits...
- just got is350 rims
- tien ha coilovers worth the money (500)
- sc300 highway swaying problem?
- Semi-Metallic vs. Ceramic
- Strange Clunking..
- Heavy vibration under braking
- Limit to lowering without excessive camber
- Help Help Help, Urgent (Spring Questions)
- Supra TT Rear Caliper - What is the depth of it?
- Aftermarket Headlights
- Rolling *squeek...squeek...squeek*
- Where to Buy Espelir ASDs for SC300
- Tein SS vs Flex vs CST
- 4-pot front vs. 4-pot front + 2-pot rear
- Supra suspension?
- Brake pulsing at low speed after strut change
- LS400 Brake Issue on an SC300
- One bad strut (front), replace both?
- Lowest Spring/shock combo
- Anyone experminted with trackion rods/bars
- Where the hell do you find TT sub-frame mounts
- brake issues maybe?!
- rear clearance for TT calipers
- WOOT! my new springs and shocks just came in!
- Tein Comfort Sport coilovers
- What's the best way to lower a SC400?
- SC400 differential?????
- Pix of lowered + stock rims???
- Trac 43 and ABS 54 code fixed, no parts.
- HOw DO I put on new struts
- Brakes Clicking. Cant locate noise
- OEM IV supra shocks and struts... fitment?
- Tell me if im right or wrong.
- Rear caliper upgrade for 92' SC300??????
- Spring and strut combo?????
- Strut Bar Installation ?
- Bilstein vs. Tanabe Sustec Pro Five Coilovers?
- Springs Urgent!!!
- 350z/G35 Springs on Sc300
- More sway bar junk. DO-luck......
- lightweight spare
- Help Removing rotors.
- supra brakes
- 95-00 LS400 calipers for 1992 SC300???????
- sc400 uneven?
- polyurethane bushings
- Shaking steering wheel after replacing steering rack bushing
- help remove my lugnuts!
- Suspension Mod
- LS 400 Calipers and SC400 Rotors?
- When I turned the wheel all the way to the left...
- Rough Ride with MeganRacing Coilovers...
- HELP, part # for supra sub-frame mounts
- 88 Rotors?
- Brake calipers????
- For anyone whos installed new LCA bushings...
- When installing TT wheels......?
- Life of the Lower Control Arm Ball Joint?
- Do I need new brakes...? Problem....
- Electronic Damping Control
- Coilovers or sway bars
- Steeing Rack Does it need replacement?
- Problem with rear brakes - Need help
- Shock and Springs Advice SC300 (1992)
- Brake light.....
- Front end noise MAYBE ?
- Anyone have a picture of FN01R's in titanium on a SC3/4??
- Recommendations on what to do?
- 14 inch supra brake kit?
- SC400 steering response is bland vs Supra
- TRD Hi-Performance Brake Kit
- supra springs on my sc
- Are SC and MKIV Supra Tie Rods Interchangeable?
- TT Caliper rebuild & powdercoating ?
- Annoying brake issue after LS swap
- Help! Caliper sliding pin/bolt stuck
- BBK Upgrades?
- Which coilovers, supra or sc300 coilovers?
- EBC Rotors
- $400 for a power steering repair??? no.....
- strange electrical problem
- Confused about springs....
- Where can I get a new front LCA bolt??
- Coilover Sleeves on KYB's for my SC300 HELP!
- New Member, New Owner, Need some wheel advice
- New Strut Bar
- Poor Man's brake setup ;(
- supra suspension question
- i am stuck on my suspention in the front rears are done
- Stance Coilovers.......
- Struts or what???
- squeeking i need ur help!
- Bilstein shocks
- sc300 suspension mods?
- UZZ32 Question
- How to use coilovers
- Best shock for a "Quite" non bouncy ride 93/SC400.......
- Solara wheel question
- Control Arms & Ball joints & Tubular Arms. Comeon Gurus!!!
- 1992 LEXUS SC400 BRAKE Problem ????
- LS430 Tanabe NF210 Springs
- SC400 Stock Suspension Vs. Tein CS Inquiry
- Weird greasy stuff...
- Bushings --- not may offerings huh
- LS430 brakes??? anyone
- lightweight spare ?
- How to clean the rotors
- Rear Suspension Overhaul
- Brembo bbk question
- Tiens or K-sport
- need help diagnosing problem-fully stock setup
- problem breeding brakes
- LS400 vs TT calipers
- Changed my Rack Bushings .. Crazy Pictures
- JZX100 Apexi power FC???
- Horshy or bad brake rotor company Cquence Motorsports ?
- Painting brake caliper.
- Coilover Q (HKS)
- 3D CAD of Subframe Bushings??
- help problem w/ my 97 SC400
- Stainless Steal lines CHEAP
- Front suspension noise remains after replacing most of the suspension
- Making brake system feel brand new...
- Rear Rotors SC400 Supra Fit?
- Coilover input
- coilovers
- kyb agx or tokico
- Caliper Paint Removal
- caliper paint
- So what exactly was "retuned" in '95?
- Tie Rod Ends Inner & Outer
- Want the look of lowered, but not the stiff ride
- Attn Lex Owners... Cheapest Supra Brakes New!!!
- Rotora Rotors
- clearance question
- shortening KYB struts..
- Am I stoopid...
- Is it possible
- NEED help with buying used coils (PICS INSIDE)
- I have a huge favor to ask
- Problem. Breaks?
- Anyone completely replaced their suspension?
- Suspension mod suggestions
- Brake Problem! Help Please. Driveable?
- Camber plates?
- Stance coilovers for SC
- Supra / SC400 Suspension Q's
- I was wondering if I could drop it 2inches w/o having it rub
- Those w/ LS400 fronts, what pads to use?
- Ikeya Formula w/pics
- Wheel sensor rusting into the hub assembly
- Megan Coilover SWEAKING in rear.. HELP!!
- Steering Rack Bushings Carson Toyota
- Tokico or Kyb
- Steering rack bushings
- KYB GR2 Ride Quality
- will is300 springs fit a sc300
- CHEAP LS400 IS300 Brakes
- CHEAP LS400, IS300 Brakes
- Clearance Question????
- Hawk HPS = Squeeky?
- Newb Quest: Front rotors on rear?
- Toe adjustment........
- Steering wheel is killing me
- help me diagnose my tire wear pattern
- Stupid Tein Flex !!
- Need favor! Rear stabilizer(?) picture.
- Carbing Strut Tower Brace/ Bar on SC300?
- Stabilizer Bar Bushings Lubricate? Oem Lexus bushing
- Rear Lower Control Arm Removal (Ball Joint)
- Please Help!!!!!!!!! (power brake booster ??)
- Control arm bushings
- K-Sport Big Brake Kit
- Help: One Side Higher Than Other (more Info Inside)
- Help: Tein CS and EDFC installed, but something is missing
- New OEM Shocks now?
- just found some of the newer LS400 Calipers for cheap if anyone is interested...
- Where to buy Brembo Blanks?
- a dreaded bushings question..
- Suspension rebuild questions
- Steering Wheel Question..
- SC Common Torque Specifications
- Brake Fluid Flush?
- Struts or Springs??? Now... which is my problem???
- TRD big brake kit?
- Car moving up and down on low speed
- Cross Member? Hard to install? What's involved?
- Suspension Problem Diagnosis
- question for STANCE coilover owners
- throw out bearing install *help*
- what is the best way to lower my SC 1'' or 2''
- supra tt or LS brakes?
- Need input (Brake Fluid Leak)
- Help with Coilovers.. tein SS, D2 RS, others??
- NAPA rotors
- shock removal ?
- Brembo blanks/Hawk pads 93 SC4
- Break (brake) Master Cylinder
- HELP: I had a bit of a scare at 90mph
- NEWB suspension install question....
- ls400 calipers
- TT Rotor sizes?
- Rear Supra TT brake upgrade question
- Favorite Coilovers
- performance coilover advice
- ATTENTION AIR SUSPENSION GURU'S- I need your help!
- Lexus SC 300 High Performance Brake Upgrade
- Calling All SC owners- Name Top 10 Reasons for clunking noises-- list your results--
- Suspension and what? Information please!
- Bump stop question
- Tanabe Nf210
- 95-00 LS400 front brake caliper or only 95
- 97 sc400 ride problem
- coilovers
- Jeeze what an expensive alignment
- New HKS Hipermax III - Hipermax II Discontinued
- HKS Hipermax RS coilovers for a 93-98 Supra
- Tokico/Espelir Combo
- Carbing strut tower brace
- Do the LS 400 Calipers fit under aftermarket 16's
- Upper shock mounts on TT suspension swap
- Weird braking problem??
- Any1 heard of Andrew Vllamos Bushings?
- Which kind of struts should I buy?
- upper rear control arms for jza80 to jzz31
- Can I use Soarer Suspension Parts??
