question CEL light
Old Jul 9, 2012 | 05:47 PM
shaka778's Avatar
shaka778
Default question CEL light
first off sorry for the long post and if this is in the wrong section i apologize.
So first off this place is awsome filled with very helpfull people. Last night had to tow the car home (92 sc400) because started bogging and then looked under and saw a red hot glowing exhaust. Came here searched and found out it could be a bad ignition coil. Replaced this morning up and running great THANKS a TON!
So now on to my new question. I was pulling codes because my CEL came on along with the TRAC OFF light right next to it. I was able to pull the TRAC code it was 51 engine control system. So i have direction there but when it comes to the CEL when i try and pull codes the CEL light just stays on no blinking nothing just ON and my OD light is constantly flashing. Any ideas as to why this is happening and how i can pull the code to find the next issue to fix?
Oh i also pulled the efi fuse for ten seconds to reset the codes but they never went off next time i turned the car on both lights were on again.
Any help would be appreciated.
Thanks again guys
Old Jul 10, 2012 | 02:51 AM
shaka778's Avatar
shaka778
anyone got any ideas?
Old Jul 10, 2012 | 07:28 AM
Vrank's Avatar
Vrank
Your ecu is prob bad. I've fixed three since the heat set in, one 1uz and two 1jz
Old Jul 10, 2012 | 07:54 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
your engine control unit is on it's way out
Old Jul 10, 2012 | 01:06 PM
shaka778's Avatar
shaka778
Thanks guys is the ecumenical some.thing i can fix or rebuild? or do i just have to source another one fringe another car
Old Jul 10, 2012 | 01:07 PM
shaka778's Avatar
shaka778
Also how long can i drive the car like this?
Bocatrip
Sep 17, 2018 08:51 AM
durps
Jun 18, 2013 10:06 PM
EXIN
Mar 6, 2005 11:48 PM
FusionMan79
Jun 23, 2002 05:27 PM
