code 13
Old Mar 5, 2005 | 08:35 PM
EXIN's Avatar
EXIN
Unhappy code 13
I'm having a check engine/ trac light on. I checked the code and it's code #13 which is Ignition signal. Does anyone know what this means and how to fix it?
Old Mar 5, 2005 | 10:18 PM
Buttercup's Avatar
Buttercup
The distributor connector and the NE terminal of the ECM connector must be checked for the following:
1. Loose connections
2. Dirty connector terminals
3. Loose connector terminals.
Basically the computer momentarily didn't get an RPM signal, but it went back to normal.
Old Mar 6, 2005 | 11:48 PM
EXIN's Avatar
EXIN
Thanks Buttercup,
The day before I posted this question I got the most reputable toyota/ lexus mechanic in my town to check my car out. $93 later he told me the trac light and check engine light were on for 2 different reasons. He said the check engine light was on because of my gutted cats and I have the receipt right here that says I need a new traction control pump to fix trac light. When I got home I pulled the code myself and got 13- ignition signal which to me didn't look like gutted cats. With your help I was under the hood for 30 min and fixed the problem- my belt had rubbed the installation off of one of the wires comming off of the distributor causing it to short. I guess I lost that hundred bucks- I wonder how he got his rep.
Thanks,
Cory Purcell
karan1193
Jan 7, 2015 08:33 PM
73446
Jun 29, 2012 11:03 AM
aceboogie6
GS - 1st Gen (1993-1997)
Feb 13, 2011 10:28 PM
Pirates81
RX - 1st Gen (1999-2003)
Sep 14, 2006 03:55 PM
FusionMan79
Jun 23, 2002 05:27 PM
