Holes behind emblems
Old Jul 11, 2010 | 10:09 AM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Default Holes behind emblems
Old Jul 11, 2010 | 11:31 AM
romycha1's Avatar
romycha1
Well.. the correct way would be to weld them up.
But if not, you have other choices, one being the way you mentioned. On one of my previous cars that I debadged, I used metal-to-metal bondo.
Just make sure you sand down all the paint, and put tape and the backside of the holes.
Old Jul 11, 2010 | 11:52 AM
nolexhere's Avatar
nolexhere
If you use regular filler, aka bondo, chances are at one point in time it will be messed up. You can use a metal filler such as liquid metal. Then as mentioned you can weld it which everyone will tell you is the best way and doesn't cost much if you have someone to weld or can weld yourself. I have at one time or another done each of the options and using a metal filler will probably work for you.
Old Jul 11, 2010 | 11:59 AM
SH_JZZ30's Avatar
SH_JZZ30
I had a local body shop weld the holes and paint that part of the trunk lid from the spoiler down.
Old Jul 11, 2010 | 12:02 PM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Old Jul 11, 2010 | 12:15 PM
nolexhere's Avatar
nolexhere
Yea if you have a welder to do it that is the best solution really. As for the front bumper plastic welding is the way to go.
Old Jul 11, 2010 | 09:20 PM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Old Jul 12, 2010 | 09:43 AM
nolexhere's Avatar
nolexhere
It would take a long time to rust or anything basically I think you would just end up with a nasty trunk.
Old Jul 12, 2010 | 01:12 PM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Old Jul 12, 2010 | 05:14 PM
MrBrock's Avatar
MrBrock
Before I had a welder, I figured out a good way to fill holes in body panels on my MR2.
http://www.mr2oc.com/showthread.php?t=315017
usoff89
Mar 25, 2013 04:49 PM
ASTERiSK
Apr 25, 2012 07:17 PM
Cybereye04
Apr 20, 2009 06:20 AM
hsk73
Automotive Care & Detailing
Sep 9, 2006 06:45 AM
pilip99
Nov 3, 2004 04:05 PM
