Windows only work when door is open
Old Sep 26, 2009 | 09:39 PM
UpperCase's Avatar
UpperCase
Default Windows only work when door is open
Whats the deal? It just started last night. The windows will only go up or down when the drivers side door is open. It makes a buzzing sound when I try to lower it with the door closed. Help me out guys.
Old Sep 27, 2009 | 09:42 AM
ConSynX's Avatar
ConSynX
buzzin makes me second guess this, but I was gonna say that you are losing your connection at the hose the transfers wires from the cabin to the door. My civic had a similar issue with its speaker.
Old Sep 27, 2009 | 10:09 AM
Papajorgio's Avatar
Papajorgio
thats exactly what it is, does it sound kinda like a scratchy electric sound, if it does, its loosing voltage or shorting in the door harness, it sucks to fix but it only gets worst if not taken care of... when it happened to me it eventually stop working all together forcing me to resolve the problem, GL
Old Sep 27, 2009 | 06:51 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
The door harness will unplug above the footwell kick panel. Unplug it &
feed it out into the door jam. You will have pleny of room then to repair
the broken wire.
Old Sep 27, 2009 | 06:54 PM
UpperCase's Avatar
UpperCase
what actually needs to be fixed? do i need to replace the whole harness or just a wire? and if so which wire or wires? sorry for the noobness ive owned three sc's and never have had this issue.
Old Sep 27, 2009 | 07:30 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
Most likely just 1 wire. Pull the harness out from the body,
remove the rubber boot & inspect the wiring. It will be
obvious which wire is broken.
Old Sep 28, 2009 | 07:43 AM
UpperCase's Avatar
UpperCase
ok awesome thanks...ill check that out today
Old Sep 28, 2009 | 08:04 AM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Harness in the door as mentioned above. Depending on how bad the wires are usually you just need to cut and soder the wires together then shrink wrap them. Using electrical tape is more of a temp solution and the moving door could pull the tape off eventually. Most of the time is it a crack in the wire and its a easy fix.
kwb18
Aug 11, 2017 11:51 AM
Kiboater
RX - 4th Gen (2016-2022)
Oct 2, 2016 06:29 PM
loccsta187
Apr 7, 2013 09:35 AM
ScottURnot
May 16, 2009 06:57 AM
stoked
Aug 31, 2002 05:27 AM
