Prothane front control arm bushing , 53$
Old Mar 9, 2010 | 05:19 PM
  #136
t70 supra's Avatar
t70 supra
aye what i did was went to autozone and bought some exhuast tubbing about 2" and it fit
Old Mar 11, 2010 | 01:01 PM
  #137
socalturbo's Avatar
socalturbo
Dan - would you know when you are receiving the items? i'm looking for bushings for the control arms both upper and lower, left and right. i'd rather shoot you over the payment when you do have it in stock. sorry but i don't want to send money and not know when i will receive the product.
thanks!!!
Old Mar 17, 2010 | 05:36 PM
  #138
Dan@Assaultech's Avatar
Dan@Assaultech
Former Vendor
thanks!!!
We just got 5 18-207-BL and 3 18-304-BL into stock.
Call me
Old Mar 21, 2010 | 11:21 PM
  #139
NSeagle78's Avatar
NSeagle78
My car makes a scrubbing sound when I hit minor bumps in the road and when I make sharp turns with moderate speed. I just replaced my shocks and that did not help. It sounds like the rear wheels are scrubbing the fender but the fender or tires show no wear and tear. I do have wide tires but the guy that sold those tires to me said he had no problem with his sc and those tires. I have also had my fenders rolled. HELP in GEORGIA!!!!!!!!!!!!!
Old Mar 22, 2010 | 02:06 PM
  #140
RedPhoenix's Avatar
RedPhoenix
you are rubbing. shave or roll your fenders,
Old Apr 29, 2010 | 09:25 AM
  #141
monsterfac's Avatar
monsterfac
i was just wondering if the rear prothane kit comes with subframe bushings??
Old Apr 29, 2010 | 09:34 AM
  #142
t70 supra's Avatar
t70 supra
same looking to good a set soon dan
Old May 4, 2010 | 10:39 PM
  #143
Vincent123's Avatar
Vincent123
still no diy write up for this? about to order a set
Old May 6, 2010 | 08:36 PM
  #144
Maeve's Avatar
Maeve
No it doesn't.
Old Jun 23, 2010 | 02:14 PM
  #145
TougeSC3's Avatar
TougeSC3
So...Update on these? In stock. If so I'm finally gonna order front and rear. Guess I'll do a full write up also. I just need my S. FL SC brothers to help.
Old Jun 25, 2010 | 08:17 PM
  #146
t70 supra's Avatar
t70 supra
so much worth it
Old Jun 26, 2010 | 07:20 AM
  #147
roc's Avatar
roc
just ordered a set this morning,the red ones are discontinued
Old Jun 26, 2010 | 01:14 PM
  #148
Vincent123's Avatar
Vincent123
does anyone know approx how much a shop would charge to install these? front/rear
Old Jun 27, 2010 | 08:51 PM
  #149
t70 supra's Avatar
t70 supra
my fronts were only 65.00 to install make sure that u keep ur metel sleeves that came with your previous bushings or u will have to use exhaust tubbing like i did
Old Jul 6, 2010 | 01:53 PM
  #150
socalturbo's Avatar
socalturbo
dan@assultech - so i finally got around to installing the bushing that i bought from you. can you please check your records if you sent me the right ones..
front uppers - I pressed out my stock bushings, lubed the inner sleeve you provided and put them in the upper control arm. question, i didn't even have the press the upper bushing, i just used my hands. is this normal?
lower control arm bushings - I was able to press these out and burn the rubber so what's left over was the inner sleeve. my problem now is that the inner sleeve doesn't fit inside the bushing. the lower control arm bushings is 2 different sizes. the stock inner sleeve DOES NOT fit the bushings you provided.
anyways, my car is up on jackstands and i cannot use it anymore until this is solved. please let me know if you gave me the right bushings or not because the front lower control arms doesn't fit.
if there's a write up on these, please let me know.. also, if anyone tackled this project on their own, please chime in because i need to use my car.
Thanks!!!
