Prothane front control arm bushing , 53$
Old Jul 6, 2010 | 01:54 PM
  #151
socalturbo's Avatar
socalturbo
BTW, i bought the front and rear set from you guys. will i run into any problems with the rears as well??
Old Jul 6, 2010 | 02:02 PM
  #152
TougeSC3's Avatar
TougeSC3
There is a write up somewhere on here with pics. I was going to do a full write up on the front and rear bushings but I'm still waiting for a tracking number from Assaultech. I ordered a week and a half ago. Hope they are in stock.
Old Jul 6, 2010 | 02:12 PM
  #153
socalturbo's Avatar
socalturbo
the only write up that i saw was replacing sc300 LCA with supra LCA.. not bushing install.
i ordered mine from assaultech and they sent it pretty quick..
Old Jul 6, 2010 | 02:40 PM
  #154
socalturbo's Avatar
socalturbo
One more thing, do you guys know where i can buy the boot for the ball joints? oil is leaking because i cracked the boot when removing them..
Thanks..
Old Jul 6, 2010 | 03:00 PM
  #155
BostonSC4's Avatar
BostonSC4
Originally Posted by socalturbo
dan@assultech - so i finally got around to installing the bushing that i bought from you. can you please check your records if you sent me the right ones..
front uppers - I pressed out my stock bushings, lubed the inner sleeve you provided and put them in the upper control arm. question, i didn't even have the press the upper bushing, i just used my hands. is this normal?
lower control arm bushings - I was able to press these out and burn the rubber so what's left over was the inner sleeve. my problem now is that the inner sleeve doesn't fit inside the bushing. the lower control arm bushings is 2 different sizes. the stock inner sleeve DOES NOT fit the bushings you provided.
anyways, my car is up on jackstands and i cannot use it anymore until this is solved. please let me know if you gave me the right bushings or not because the front lower control arms doesn't fit.
if there's a write up on these, please let me know.. also, if anyone tackled this project on their own, please chime in because i need to use my car.
Thanks!!!
Hmmm, are you 10000% sure you didn't try to put the upper bushings in the lower and lower in the upper control arm?
Old Jul 6, 2010 | 03:55 PM
  #156
good2go's Avatar
good2go
^^ hmmm...interesting idea.
Old Jul 6, 2010 | 10:23 PM
  #157
socalturbo's Avatar
socalturbo
bostonsc4 - LOL, that's not possible at all... the uppers came with 8 similar bushings and the lowers came with 4 bigger bushings...
did anyone do this project themselves???
Old Jul 6, 2010 | 11:02 PM
  #158
TougeSC3's Avatar
TougeSC3
I'll have to give them a ring tomorrow.
Old Jul 7, 2010 | 12:07 AM
  #159
RedPhoenix's Avatar
RedPhoenix
I did it myself... i thought the 2 front lowers were the same...
Old Jul 7, 2010 | 12:52 AM
  #160
good2go's Avatar
good2go
Originally Posted by socalturbo;
...lower control arm bushings - I was able to press these out and burn the rubber so what's left over was the inner sleeve. my problem now is that the inner sleeve doesn't fit inside the bushing. the lower control arm bushings is 2 different sizes. the stock inner sleeve DOES NOT fit the bushings you provided.
In the Diazen kit that I had, the lower bushings were all the same size and the inner sleeves (that came with the kit) did fit very snugly into them. Are you sure you cleaned all the rubber off the sleeves and gotten them down to bare metal?
Can't think why your bushings would be different sizes though.
Old Jul 7, 2010 | 09:41 AM
  #161
socalturbo's Avatar
socalturbo
red pheonix and good 2 go - check out page 8 on this thread, there is a picture of the bushing kit. this is the exact kit i got except that they didn't come with the metal sleeve for the lower control arms. if you look closely, the 4 bushings on the top of the picture are not the same. they are 2 different sizes. even the inside diameter is different where the sleeve goes. I did remove the stock bushing out of the LCA, the bushings will fit into the LCA, my problem is that the stock sleeve doesn't fit the prothane bushing. the stock sleeve is much smaller than the bushing, hence, if i install it, there's a lot of play since the sleeve is not snug in the bushing.
please help.. i'm thinking assualtech might have sent me the wrong bushings.. did anyone buy prothane kit and install it themself?
Old Jul 7, 2010 | 10:21 AM
  #162
t70 supra's Avatar
t70 supra
i bought mine fron assult tech and the bushings were smaller in size than they should have been i know they expan when the sleeve is inserted. but they did not fir so i sent them back then. got a new set as well then i still had to add some exhuast tubbing and use that as a sleeve
Old Jul 7, 2010 | 02:13 PM
  #163
socalturbo's Avatar
socalturbo
t70 - i think you ran into the same problem i did. the stock inner sleeve was too small for the bushings right? i don't quite understand the exhaust tubing that you mentioned. the out diameter might be 2" but not the inner sleeve though.... how did you get the INNER sleeve into the bushing and fit it snug?
previously, you mentioned using a 2" exhaust tubing but i think you were referring to the outside sleeve. my problem is the inner sleeve.
Old Jul 8, 2010 | 06:06 AM
  #164
RedPhoenix's Avatar
RedPhoenix
I think you got the wrong one...
The 2 lowers are the same - they come with NO sleeve, you reuse your old one
The uppers are ALL the same - they come with sleeves.
The outer metal sleeve in the LCA must be removed.... I burned mine out. The LCA prothane bushing slides in the actual LCA itself, no sleeve or anything.
Old Jul 8, 2010 | 09:37 AM
  #165
socalturbo's Avatar
socalturbo
red phoenix - thanks for the info. i've been talking to jay at assault tech and hopefully he can get me the right parts.
i'll let you guys know what happens.
