Prothane front control arm bushing , 53$
This is an example of a good ball joint, if there is a slit in the rubber and grease is coming out, then it's toast. If your ball joint is good, check to see if it moves nicely in all directions.
By the way guys, why are you all supporting big brother and ordering from JEGS? So what if it takes a couple more weeks to get them from assaultech?, sure it took them about 2 weeks to ship out the LCA bushings to me, but I was not complaining because it's not like my car was sitting on jackstands for 2 weeks waiting for my bushings to arrive. You need to be patient because assaultech is overwhelmed with orders and they can only order so many at a time. So support a sponsor and CL by being patient!
BTW I am not associated with assaultech in any way.
BTW I am not associated with assaultech in any way.If I was that one guy I would be
. Big brother has good communication and great customer service, I just wish they had more SC specific parts.
for real, you would really wait all that extra time knowing you could have it within days for practically the same price, and knowing if its unreasonably backordered you wont have to pay any money to cancel the order.
Bare with us and keep the orders coming so we have a reason to keep stocking these two part numbers.
$.02
When it comes to checking the condition of ball joints, the first thing to check is the condition of the rubber grease boot. The next thing and very important!, is the UP and DOWN movement of the ball joint in the socket! Of course the ball joint should rotate smoothly and tightly both on a left and right rotation. If it is VERY loose on this rotation them it is showing signs of wear (but maybe not completely worn out). The real test... the UP and DOWN slop or movement is best tested with a BIG *** pair of channel lock pliers grabbing the ball joint by the top of the mounting post and the base of the ball joint. Squeeze the pliers and there should be no up and down movement of the said ball joint. If there is up/down movement then ball joint is toast regardless of its other conditions. BTW, as far as I know, NOBODY makes replacement ball joints for LEXUS SC front lower control arms. So, if your front lower ball joint on your SC's FLCA's is TOAST then the COMPLETE front lower control needs to be replaced, period.. end of story.
mcmaster.com usually have a lot of good spec on their stuff.
