Prothane front control arm bushing , 53$
Old Jul 10, 2011 | 06:20 PM
  #196
CCC-TT's Avatar
CCC-TT
The sleeves on 97+ LCA's seem to be different after burning out the actual rubber bushing; Any ideas as to the modifications I may need to do to make these work?
Old Aug 12, 2011 | 11:01 PM
  #197
IRRELEVANT's Avatar
IRRELEVANT
Originally Posted by FiSta
instead of just torching them off, get some circular drill bits and take off as much rubber as you can. That will make the torching part go by a lot faster.
And those two larger sleeves (metal insert flanges) are for the lower front. If your kit (prothane) did not come with them then you're suppose to reuse the old one. I barely could get the new bushing in so i didn't reuse it.
Does anyone know where I can get just the two metal shells from? I aleady have the prothane kit and took it to a machine shop were the screwed up the old shells. I actually need 4, 2 for each side.
Old Aug 17, 2011 | 02:01 PM
  #198
MySc4fever's Avatar
MySc4fever
^^^^^When u find out, let me kno....mechanic screwed up all four of mine.
Still at the shop, can't move it now.
Old Aug 26, 2011 | 12:19 PM
  #199
sc4demon's Avatar
sc4demon
Originally Posted by SOLID300
Ive read that the kit will also work on 97-00 as well. Is anyone able to confirm?
does anyone know if the jeggs lower control arm bushing kit will also fit 97+?
Old Aug 26, 2011 | 01:05 PM
  #200
pieisgude's Avatar
pieisgude
I'm with you, i wanna know if it fits my 98.
Old Aug 26, 2011 | 01:43 PM
  #201
88supramki's Avatar
88supramki
If you can reuse the sleeves then it may work. The 97+ LCA replacement bushings come with replacement sleeves (daizens do at least)
Old Aug 26, 2011 | 09:52 PM
  #202
pieisgude's Avatar
pieisgude
Ugh...the Prothane ones are so cheap though. Lol. I just don't wanted to buy them and get shafted upon install. Hope someone who has tried it chimes in.
Old Aug 30, 2011 | 02:39 PM
  #203
Blkexcoupe's Avatar
Blkexcoupe
Are you saying the inner sleeve or the outer shell is different?
If the outer shell is different have you tried placing the bushing into the arm yet? Is it loose or a tight fit?
Old Sep 2, 2011 | 12:46 AM
  #204
soarer13oy's Avatar
soarer13oy
Just got my set for jegs. Waiting for some time to get them installed.
Old Sep 12, 2011 | 07:03 PM
  #205
Sc1Uz's Avatar
Sc1Uz
just ordered my kit from jegs! payed through pay-pal. just noticed today (after getting back from vacation last night) that my lower bushings are GONE!! guess i was just used to it before but, backed out of the garage this morning and felt the jerking or (slack feeling) in the front end. had my friend get in car, and back it up and tap the brakes and you could easily see that my bushing is GONE! Immediately came inside and got on clublexus and found this write up. Thanks to all of you on here! Anytime i have a question about my SC i come to this site. I've learned so much and will continue to learn every day! Thank you all!
Old Oct 27, 2011 | 11:00 AM
  #206
formosa927's Avatar
formosa927
just got it installed yesterday and what a difference! wished I had it done at first day I picked up the car. I highly recommend.
the car accelerate better, getting better mpg, brake better, handles great! the car feels way sportier than an old heavy slow response car. down side is that you feel road bump easier and now feel rear end is soft (rear is still stock)
FYI, i took it to a shop and got it done (upper and lower) for about $450 with alignment. I am too lazy to do it by myself and it took them 5 hours with 2 mechanics (1 busy burning and cleaning LCA and 1 busy in pressing upper arm).
Old Dec 13, 2011 | 08:17 PM
  #207
BeansIS's Avatar
BeansIS
Someone try this set on a 97+ and let us know!
Old Jan 12, 2012 | 12:13 PM
  #208
BeansIS's Avatar
BeansIS
Bumping sort of an old thread,
Does anyone actually know the difference between the 92-96 LCA bushing ( OD ) than the 97-2000 ( OD )?
Is the 92-96 bushing bigger or smaller than the 97-2000?!?!
Old Jan 12, 2012 | 01:16 PM
  #209
xspsi6's Avatar
xspsi6
97-00 bushing is bigger and will NOT accept the prothane bushings, I know from 1st hand exp!
Old Jan 12, 2012 | 05:27 PM
  #210
xspsi6's Avatar
xspsi6
Here are some photos as to why you can not use them...
these need to become these in order to work in the new bushings
